第2頁,共2頁 第一第一 12
顯示結果從 11 到 14 共計 14 條
    引用 作者: michael99 查看文章
    24000美金耶
    不是24000台幣
    到我這來 那我把boulder網路照片貼到我的cd機器面板給你們聽嗎
    改成越幣我就買的起啦.................(sweat)
  2. #12
    預設 1021 軟體升級可支援NAS了
    Boulder has since upgraded the 1021’s software to allow it to connect to
    a local network specific to a home audio system or to a home
    network of the kind now common to anyone with a modern
    Internet connect, and to use an Ethernet connection to decode
    digital audio directly from a computer or a NAS media server.
    As a result, a user can both play regular CDs or DVDs with
    high-res material up to 192kHz or 32-bits, and play music files
    at the same resolutions from a computer or external hard drive.
    (The 1021 can play WAV, AIFF, FLAC, OGG Vorbis, ALAC,
    and MP3 from its internal disc mechanism at native resolution
    up to 32 bits or 192kHz.)
    Boulder notes that data are delivered
    asynchronously and in packetized form, so there is no difference
    between reading from a disc and streaming from a drive.
  3. #13
    chsiang兄, 可以出手了~~~:P
  4. #14
    搭Gryphon也有調合作用,100分....
