第53頁,共55頁 第一第一 ... 3435152535455 最後最後
顯示結果從 521 到 530 共計 545 條
  1. #521
    lsmod結果跟我的Z790 Q352WU 開機是一樣的。我真的看不出網卡不能用的原因是什麼。
    1. Cuhulong兄電腦上插了幾支ssd ?
    2. 執行一次,會要密碼,但不會顯示什麼。完成後用Q441開機。
    代碼:
    sudo sed -i '$ itouch /root/$(uname -r)' /etc/rc.local
    3.Q352WU開機,
    sudo ls /root
    結果貼出來,小弟確認一下Q441 是否完成開機。
  2. #522
    電腦上插了幾支ssd ?--->一盒兩隻 Klevv DDR5-6400 16G !但是controlled 0 disabled!
    剛剛拔掉靠內側CPU那一隻,Q441也是無法連線!
    2.
    [ll@ArchQ:Q352WU ~]$ sudo sed -i '$ itouch /root/$(uname -r)' /etc/rc.local
    [sudo] password for ll:
    [ll@ArchQ:Q352WU ~]$ reboot
    完成後用Q441開機。Connection to 192.168.1.20 closed by remote host.
    Connection to 192.168.1.20 closed.
    PS C:\Users\ll> ssh [email protected]
    ssh: connect to host 192.168.1.20 port 22: Connection timed out
    3.
    Q352WU開機
    [email protected]'s password:
    [ll@ArchQ:Q352WU ~]$ sudo ls /root
    6.12.12-12-Q352WU
  3. #523
    結論是 Q441 沒有開機成功,不是網卡問題。
    BIOS 請重置為原廠值,再試試Q441 能否連上,一樣 sudo ls /root,看結果。
  4. #524
    BIOS 請重置為原廠值,再試試Q441 能否連上--->還是無法連上!
    安裝Q441,訊息如下:請查看有沒有問題?
    Install Kernel Q441-6.12.12-12...
    --2025-04-12 14:51:07-- https://raw.githubusercontent.com/sa...64.pkg.tar.zst
    Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
    Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.109.133, 185.199.108.133, 185.199.110.133, ...
    Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.109.133|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 10535197 (10M) [application/octet-stream]
    Saving to: ‘/tmp/linux-Q441-6.12.12-12-x86_64.pkg.tar.zst’
    linux-Q441-6.12.12-12-x86_64. 100%[=================================================>] 10.05M 3.05MB/s in 3.5s
    2025-04-12 14:51:12 (2.84 MB/s) - ‘/tmp/linux-Q441-6.12.12-12-x86_64.pkg.tar.zst’ saved [10535197/10535197]
    loading packages...
    resolving dependencies...
    looking for conflicting packages...
    Packages (1) linux-Q441-6.12.12-12
    Total Installed Size: 26.87 MiB
    Net Upgrade Size: 15.73 MiB
    :: Proceed with installation? [Y/n]
    (1/1) checking keys in keyring [########################################] 100%
    (1/1) checking package integrity [########################################] 100%
    (1/1) loading package files [########################################] 100%
    (1/1) checking for file conflicts [########################################] 100%
    (1/1) checking available disk space [########################################] 100%
    :: Running pre-transaction hooks...
    (1/1) Removing linux initcpios...
    :: Processing package changes...
    (1/1) upgrading linux-Q441 [########################################] 100%
    :: Running post-transaction hooks...
    (1/3) Arming ConditionNeedsUpdate...
    (2/3) Updating module dependencies...
    (3/3) Updating linux initcpios...
    ==> Building image from preset: /etc/mkinitcpio.d/linux-Q441.preset: 'default'
    -> -k /boot/vmlinuz-linux-Q441 -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-Q441.img --microcode /boot/intel-ucode.img
    ==> Starting build: '6.12.12-12-Q441'
    -> Running build hook: [base]
    -> Running build hook: [udev]
    -> Running build hook: [autodetect]
    -> Running build hook: [modconf]
    -> Running build hook: [kms]
    -> Running build hook: [keyboard]
    ==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
    ==> ERROR: module not found: 'usbhid'
    -> Running build hook: [keymap]
    -> Running build hook: [consolefont]
    ==> WARNING: consolefont: no font found in configuration
    -> Running build hook: [block]
    -> Running build hook: [filesystems]
    -> Running build hook: [fsck]
    ==> Generating module dependencies
    ==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-Q441.img'
    ==> WARNING: errors were encountered during the build. The image may not be complete.
    ==> Building image from preset: /etc/mkinitcpio.d/linux-Q441.preset: 'fallback'
    -> -k /boot/vmlinuz-linux-Q441 -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-Q441-fallback.img -S autodetect --microcode /boot/intel-ucode.img
    ==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-Q441-fallback.img'
    error: command failed to execute correctly
    Generating grub configuration file ...
    Found linux image: /boot/vmlinuz-linux-Q441
    Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-Q441.img
    Found linux image: /boot/vmlinuz-linux-Q352WU
    Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-Q352WU.img
    Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
    Warning: os-prober will be executed to detect other bootable partitions.
    Its output will be used to detect bootable binaries on them and create new boot entries.
    logger: socket /dev/log: Connection refused
    Adding boot menu entry for UEFI Firmware Settings ...
    done
  5. #525
    這個Q441 安裝沒問題。
    我製作新的Qdbug-6.12.126,config -> kernel -> install 安裝試試,看看能不能本機登入使用。
    先移除不能使用的kernel Q441, Q396 ....,清出一些空間。
  6. #526
    對了。Q441開機時,可能有時不成功,看網卡的橘黃燈是否有亮。
    若沒亮,關電源後,再試一次。通常重開一至二次就會成功。
    若一直一樣,那真的有問題,我也想不出原因。
  7. #527
    1.Q441開機時,都不成功,看網卡是亮綠燈。
    2.Q352WU、Qdbug-6.12.12開機時,都成功,看網卡亮橙黃燈。
    3.Qdbug-6.12.12 ArchQ login:可以本機登入使用!後續如何使用?
    4.不知有哪位先進跟我一樣是ASUS ROG B760-I 的板子,如果安裝Q441開機時,並成功連線,請告知!那表示是我的主機板子有問題要報修!
  8. #528
    引用 作者: cuhulong 查看文章
    麻煩再確認一個kernel ,Qrip-6.12.12,本機是無法登入,只能遠端登入,看它是否可用。
    Qrip 與 Q441 的差異,只有工作頻率。
    若Qrip 正常,試試 Q44-6.12.12,若Q44也不行,小弟猜想可能是BIOS 要調成 沒有鍵盤時,也能開機的狀態。
    Boot (Menu) -> Boot configure -> Setup Mode -> Advenced Mode 調成這個試試,我不確定。
    Qdbug 可以移除了,小弟只是用來判斷失敗的可能性。
  9. #529
    1.Qrip-6.12.12,Q44-6.12.12,都不行無法遠端登入!看網卡是亮綠燈。
    2.BIOS 要調成 沒有鍵盤時,也能開機的狀態--->不知如何設定?
    3.Boot (Menu) -> Boot configure -> Setup Mode -> Advenced Mode 調成這個試試--->設定了!只是BIOS畫面是Advenced Mode!
    找不到沒有鍵盤時,也能開機的狀態?
    此篇文章於 2025-04-12 11:03 PM 被 cuhulong 編輯。
  10. #530
    我也不知道,問AI 看看,先試試 鍵盤拔掉後,能不能開機進Q352WU。
    若仍能正常開機,就要另查原因了,八成是BIOS 調整問題。
    Q441, Q44, Qrip 等,都是無法在本機操作的版本,在你這裡都無法開機成功。
    換去年的BIOS 試試。
