2012-01-13, 07:58 AM
#111
Acapella Violon MK VI
一對喇叭可以一直出到第6代真是不簡單,Acapella確實是德國的老品牌呃
The Following 5 Users Say Thank You to Leo Yeh For This Useful Post:
2012-01-13, 08:02 AM
#112
Acoustic Fields 聲學產品
在T.H.E Show的一些展房可以看到這家公司的聲學產品
其中一個很有趣的是把聲學產品做成跟窗簾一樣
The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
2012-01-13, 08:05 AM
#113
非常美派的PBN Audio
這家美國音響公司每次在T.H.E Show都展得非常大
有多美派,從這台後級的彩繪圖案就可看出來
聲音也是屬於美派的走向
The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
2012-01-13, 08:28 AM
#114
非常好聽的HeadRoom平衡耳擴
不管是用那隻耳機聽,包括Audez's LCD-2或是HD800
他們家的Balanced Ultra Desktop AMP(USD 1,699)都有很好的表現
2012-01-13, 08:35 AM
#115
JH-3A DSP Amp with JH16 Pro Custom In-Ear Monitor
體積雖然小,但know how可很多,有24/96 SPDIF DAC內建,也有類比輸入
32-Bit DSP,6聲道輸出專為JH16耳機設計
也可用轉接頭給一般耳機用
有音量與低音調整
圖中為JH總裁也是設計者Brittany Harvey
Starting At: $1,748.00
NEW ORDERS SHIPPING IN 4-6 WEEKS
If you didn't think our IEMs could get any better, think again. Our new DSP Amplifier will take your JH16s to a new toe-tingling audio level.
Details
JH16 Pro, perfectly tuned with the JH-3A Amplifier
10HZ to 23k Frequency Response (No, that's not a typo; 23k!)
+ or - .25dB Resolution for Predetermined Audio Signature
Phase and Time Correct
Unsurpassed Detail, Soundstage, Accuracy
Available in Midnight Black
Offered with 48" or 64" Clear Cable
2 way mode allows for perfectly flat response flat low end to 10Hz
Optional JH16 Adapter (8pin to 3.5mm) allows use with any source
Technical Specifications
2-Channel Analog Input or SPDIF 24/96 Digital
6-Channel Amplified Analog Output (>100mA per channel)
Digitally Controlled Volume Level
Digitally Controlled Variable Bass Output - 0dB to + 12dB Boost
32-Bit DSP Resolution
Sample Frequency up to 192KHz
72-Bit Accumulators
300,000,000 MAC/S
2012-01-13, 08:54 AM
#116
M Audio Model 10
這是新的美國喇叭,用鋁、碳纖維與玻璃纖維為材質,現場使用Oilve當訊源
2012-01-13, 08:56 AM
#117
值得注意的唱頭放大: 美國Zesto Audio Andros PS1
2012-01-13, 08:59 AM
#118
Zu Audio Definition MK IV
Zu Audio真是一家年輕化的美國喇叭公司
現場不僅直接架起了DJ臺播放,曲目也都很Rock與另類
喇叭看起來相當不錯
臺灣好像剛有新代理了
2012-01-13, 09:02 AM
#119
很多調音道具的highend-electronics
這家美國的代理商有很多產品是屬於周邊與調音的
可上他的網站看,我就不一一列了
http://www.highend-electronics.com
2012-01-13, 09:04 AM
#120
