第3頁,共158頁 第一第一 123451353103 ... 最後最後
顯示結果從 21 到 30 共計 1578 條
    將軍大說得好
    要有意義,不要流於空談
    我覺得,沒錢想聽LP,也不是太難
    我實際用過便宜的唱盤,雖然不久長,只要理論和實務上能開大門走大路
    當然沒法子和高價系統一爭長雄
    但是以入門來說
    真的不必一定要到多少多少萬
    要聽LP
    不必擔心那一點學費的!
  2. #22
  3. #23
  4. #24
    MUSICAL SURROUNDINGS
    FOSGATE FOZGOMETER
    AZIMUTH RANGE METER
    量方位角用
    要搭配測試片用
    Unit Price: $249.99
    Coming in Mid-March 2010! Order Yours Today!
    The Musical Surroundings Fosgate Fozgometer Azimuth Range Meter is a very simple and easy-to-use small portable battery powered unit that is used in conjunction with a Test Record and perfectly aligns your cartridge's azimuth for optimum sound! It measures channel separation, channel balance, and signal direction quickly and accurately.
    Jim Fosgate's passion for analog led him to apply his extensive engineering knowledge, designing an affordable meter to adjust cartridge azimuth (Axial Tilt). The battery operated Fosgate Fozgometer ARM Azimuth Range Meter incorporates operating principals similar to surround processor logic steering circuits, is simple to use, and reads channel separation and channel balance, as well as signal direction.
    To obtain high performance from a modern phonograph system, the tonearm and pickup cartridge must be properly adjusted to within a few thousands of an inch. There are several alignment gauges available to adjust overhang and offset. To adjust cartridge azimuth (Axial Tilt), it has been necessary to use lab quality equipment and a test record. Azimuth may be adjusted using an oscilloscope, AC voltmeter, or computer program. These methods can be expensive and time consuming.
    The Fosgate Fozgometer Azimuth Range Meter represents a breakthrough for adjusting phono system azimuth. The Fozgometer incorporates a "Log Ratio Detector" developed for surround processor steering logic circuits to measure channel separation over a wide range of signal levels down to -70 dB. The readings are virtually independent of overall signal levels, and can be made with a wide range of input signals without effecting accuracy.
    Readings are taken without touching the meter, leaving your hands free to work with the tonearm. The meter reads channel separation in both directions, and channel balance. The LED’s indicate Left, Center, and Right signal (test tone) positions. Simply plug your tonearm cables directly into the Fozgometer and cue up your test record!
    The Fosgate Fozgometer works well with the Analogue Productions Ultimate Analogue Test LP or the Hi-Fi News Analogue Test LP: The Producer's Cut or your Test LP with an Azimuth Test Cut.
    www.musicalsurroundings.com
  5. #25
    葉哥哥給我帳號吧~~~~~~:P
  6. #26
    我們可以約出去用掉嗎
    引用 作者: 小佐 查看文章
    葉哥哥給我帳號吧~~~~~~:P
  7. #27
    我們可以約出去用掉嗎
    那要找將軍大嗎~~~(party)
  8. #28
    那個消費太高........:|:|:|
    引用 作者: 小佐 查看文章
    那要找將軍大嗎~~~(party)
  9. #29
    大家認為調整LP
    第一步是什麼????(happy)
  11. #30
    大家認為調整LP
    第一步是什麼????(happy)
    穩定的擺放和調整水平...:)
