顯示結果從 1 到 5 共計 5 條
主題: 【訊源】Meridian Control 15 (Sooloos Digital Media System)
    預設 【訊源】Meridian Control 15 (Sooloos Digital Media System)
    同時擁有500GB硬碟、播放與17"觸控螢幕,iPad可下載專用的控制軟體Core Control
    若加上Meridian的DSP數位喇叭,就是一套完整的系統了
    或是可用同軸數位輸出到系統的DAC進行解碼
    http://www.meridian-audio.com/sooloos/control15.php
    英國製造
    直覺的控制,說明書根本不用看
    螢幕後面使用了許多散熱片
    ripping,專輯資訊自動抓取
    使用台達電的
    Outline Specifications
    Network Interface
    • 1 Ethernet (RJ-45) or Neutrik EtherCon
    Audio Connections
    • Meridian SpeakerLink (RJ45)
    • 1 S/PDIF coaxial digital output, RCA type
    Additional Control Connections
    • Meridian Comms (DIN)
    • IR input (3.5mm jack)
    • Trigger out (3.5mm jack)
    Audio Processing
    • Ultra-stable clock for lowest possible jitter
    • “Apodising” upsampling filter for ultimate digital performance
    LCD Display
    • Screen Size: 17 inch diagonal (43cm)
    • Resolution: 1280 x 1024 pixels
    • Brightness: 350 cdm2
    • Viewing Angle: 150º
    Touch Panel
    • Type: Analogue resistive 5-wire
    • Activation Force: < 50g
    • Structure: Film/Glass
    • Lifetime/Durability: 35 million touches
    Dimensions
    • 457 x 345 x185mm / 18 x 13.6 x 7.3in (WHD)
    Tilt
    • Adjusts from 0º (vertical) to 50º (tilted)
    Weight
    • 10.75kg (23.6lb)
    Power
    • 12V DC 12.5A, 150W (mini-DIN) via external AC adapter 110-230V (supplied) with removable IEC 3-prong power cable
    【燒喔】MY-HIEND FACEBOOK "讚"
    【教學】如何使用本站相簿與貼圖
    【好康】與商家交關時請報是MY-HIEND會員,以享有更好的服務喔!
    免費的iPad APP: Core Control
    【教學】如何使用本站相簿與貼圖
    Dear Sir,
    Just want to confirm if the unit can import CD with Chinese title and artist name correctly or you have to touch up after importing ?
    I'll make sure again..................and tell you later
    【教學】如何使用本站相簿與貼圖
    sooloos本身只能顯示英文
    但iPad端則是各種語言都OK
    【教學】如何使用本站相簿與貼圖
