Burmester new 113 D/A Conveter incl. Bluetooth and USB input
數位流的趨勢似乎在Hi-End廠家上, 也不得不跟進了
http://www.burmester.de/en/index.php
The Burmester 113 D/A converter was designed in the course of developing the MMI
module for our 061, 069 and 089 CD player models. The result is an independent D/A
converter with maximum high-end quality, which not only features electrical and
optical digital inputs but also supports wireless data transmission. The 113 has two
digital inputs and two analogue outputs, as well as a Bluetooth® (even supporting
aptX® codec for best sound quality via Bluetooth® ) and a USB input (class 2 audio) to
ensure that you can enjoy all of your digital music sources in the best-possible audio
quality. Moreover, the 113 contains balanced circuitry, with a fully DC-coupled signal
path and no coupling capacitors getting in the way of the signal. The sophisticated
analogue output stages obtain their signal from a converter stage of the latest
generation, with switchable sampling rates (48kHz, 96kHz and 192kHz) to guarantee a
highly defined and musical sound.
In addition to the outstanding audio quality resulting from the D/A conversion, the 113 DAC
features comfortable wireless integration of all audio sources equipped with A2DP
(Advanced Audio Distribution Profile) into an existing system. The 113 then functions as a
Bluetooth® receiver and music is transmitted to the system by connecting a laptop,
microphone, etc. to the Bluetooth® interface.
虛空有時盡 我願仍無窮
虛空有時盡 我願仍無窮
Music stored on an iPhone®, Blackberry® or other mobile telephone device can now be
played back through the system via a wireless connection. This feature is extremely useful
for ensuring uncomplicated and spontaneous music enjoyment in any situation.
In order to achieve maximum sound quality with the limited bandwidth of a Bluetooth®
connection, the 113 DAC supports the aptX® codec. Of course it is also possible to connect
your computer to the 113 D/A converter via its USB interface. A USB connection supports
the lossless transfer of uncompressed data, and therefore promises audio reproduction of
the highest quality.
Features:
- Upsampling of all digital audio signals switchable between 48kHz/24 bit, 96kHz/24 bit
and 192kHz/24 bit - Phase reversal of 180° available at output
- Bluetooth® SBC & aptX® codecs
- USB input to allow connection of a computer:
- o Class1audiowithupto96kHz/24bit
- o Class2audiowithupto192kHz/24bit
- Trusted Burmester reference converter technology with balanced conversion
- Fully DC-coupled signal path with no coupling capacitors in the way of the signal, for
precise bass reproduction with no phase shift in the audible spectrum - “Green“ power supply with a very low, environmentally-friendly power consumption of
- less than 1W in standby mode
- Galvanic isolation between the analogue and digital sections
Connections:
Digital inputs - 1xRCA
- 1xTOSLINK
- 1xUSB
- 1x Bluetooth®
Digital outputs - 1x RCA
- 1x TOSLINK
Analogue outputs - 1x RCA stereo
- 1x XLR stereo
Technical Specifications:
Dimensions (W x H x D) - 200 x 60 x 165 mm
- 7.9” x 2.4 x 6.5”
WEIGHT - 1.5 kg
- 3.3 lbs
虛空有時盡 我願仍無窮
Burmester 113承襲了061, 069與089 CD唱盤的精華設計,不但有傳統的的數位介面,還有24/192 USB (Class 2)與藍芽無線傳輸,並使用平衡線路設計,還48kHz、96kHz與192kHz的升頻選擇。令外還有輸出180度向位反轉的選擇。
