顯示結果從 1 到 5 共計 5 條
    預設 Electrocompaniet PD 1 DAC
    As the major general in the use of computers and iPods as storage medium for music, think Electrocompaniet sound deserves a bit more - their solution is called PD 1 DAC.
    In the 37 years Electrocompaniet has existed, those that most people already know, produced amplifiers and CD players and other devices for playback of music, and it is the experience Electrocompaniet claimed to have "built" into their new DAC.
    PD 1 DAC handles all popular digital input signals from PC to portable MP3 players to TVs and CD players, and there are 5 inputs of exercises which can be either wireless, optical, coaxial, or USB. Wireless use is only possible via additional module in the form of a USB adapter, which in turn makes it possible to download music directly from the PC and even through the remote control, controlling basic functions such as back and forth on the PC, and audio volume and input selection.
    PD 1 DAC signal processing of all digital inputs should lift the sound to new heights, and disseminate the music dynamic, open and rich in detail.
    Specifikationer:
    Specifications:
    • Channels: 2
    • Output impedance: 100 ohms
    • Output Level: 3.4 Vrms
    • Noise Ratio (20 - 20 kHz): <- 140 dB
    • Frekvensrespons: 1 – 48 kHz
      Frequency response: 1 - 48 kHz
    • THD + N: <0,003%
    • DAC resolution: 192 kHz, 24bit
    • Digital / Analog Conversion: 192 kHz, 24bit
    • Outputs: unbalanced RCA / phono and balanced XLR
    • Weight: 4.3 kg.
    Supported sampling rate:
    • SPDIF 192 kHz, 24 bit
    • USB 48 kHz, 16 bit
    • RF Link 48 kHz, 16 bit
    Digital inputs:
    • 2 x SPDIF Coax
    • 1 x SPDIF TOSlink
    • 1 x USB Type B
    • 1x RF
    www.electrocompaniet.no
    由挪威Electrocompaniet推出的Prelude PD-1這台平衡DAC即將到貨,其非常容易安裝,所附的遙控器可切換訊號來源與音量大小,搭配主動式喇叭或是直入後級都很合適,也可選配USB Music Streamer無線介面,透過無線與PC/MAC結合。數位輸入有3組,包括SPDIF (192 kHz, 24 bit)、USB (48 kHz, 16 bit)及RF Link(48 kHz, 16 bit),均升頻到192 kHz, 24bit。類比方面有平衡、RCA各1組
    www.ansbach.com.tw
    遙控器好像還直接控制電腦選曲........這就有意思了
    看店家展示過的確可以遙控 (當時是iTune)
    RF傳輸規格如果再高些就好了,畢竟都已經改用自己規格的RF :)
  5. The Following User Says Thank You to izawamakoto For This Useful Post:
  6. #5
    獲得英國HIFI Choice 5顆星評價
