第1頁,共158頁 1231151101 ... 最後最後
顯示結果從 1 到 10 共計 1578 條
    預設 LP研究社 (黑膠唱盤、黑膠唱片收藏分享)
    20141027: Moving Magnet (動磁) vs Moving Coil (動圈) vs Moving Iron (動鐵)
    20140731: 冰雪奇緣原聲帶黑膠豪華版 Frozen Deluxe Edition Soundtrack Vinyl
    20140725: 王若琳 Joanna 午夜劇院-玩賞珍藏限量版(黑膠唱片)
    20140724: Transfigurati 變容唱頭
    20140723: 義大利設計師Ivan Tancorre的點子,將唱盤直接安裝在牆上
    20140722: Ortofon SB-2 新款唱盤測速儀
    20140718 三隻唱片刷比較
    20140717 德國警方破獲歐洲最大的違法黑膠唱片工廠
    20140715 Clone Records vinyl stabilizer 唱片鎮
    20140710 加拿大黑膠銷售統計
    20140707 Original Soundtrack Godzilla (Gatefold Sleeve) [180 gm 2LP black Vinyl]
    20140706: How It's Made - turntables 唱盤的生產
    20140706: How Vinyl Records Are Made (黑膠唱片的製作生產)
    20140614: CBS報導:黑膠是去年唯一銷售成長的音樂媒介,成長了32%
    20140611: Headshell Koetsu Onyx
    20140609: 寺垣プレーヤ
    20140608: Ad-Fontes
    20140606: FROZEN DELUXE EDITION SOUNDTRACK 黑膠大碟限量套裝
    20140605: Einstein the pickup
    20140605: 鐵三角新推出 F 系列 MC 唱頭 AT-F2
    20140528: Do Analogue Stone turntable NEW
    20140525: Reed Muse 3C
    20140525: Men of Records
    20140522: 超過三萬張黑膠收藏
    20140503: 淺談黑膠系統 - 唱臂篇第一集 Vinyl Playback
    20130429: TechDAS 六月份將開始發售 Air Foece Two唱盤,TDC01 Ti MC唱頭
    20140413: Financial Times: A new age of analogue
    20140413: 十張最貴的唱片
    20140407: The archon© time-aligned moving coil phono cartridge
    20140317: Ikeda 9TS, SAI MC唱頭
    20140317: Abis SA-1, TA-1 Tonearm
    20140306: Thales發表新唱臂"EASY"
    20140226: Wilson Benesch unveils 25th anniversary Circle 25 turntable
    20140223: Yamamura Churchill J
    20140216: Stanton ST150
    20140215: Swedish Analog Technologies
    20140215: Early Western Electric Turntable
    20140214: Special Edition Fully restored 'Midnight Oil' Garrard 301 by Audio Grail
    20140211: LP大屋頂
    20140211: LP腳踏車
    20140209: jakutis-analog
    20140209: 老B&O唱盤
    20140208: JA Michell Hydraulic Transcriptor
    20140205: nakamichi tx-1000
    20140204: Pete Riggle Audio Engineering
    20140131: LP Girls
    20140128: ZXY Premium 唱頭
    20140127: Nipper Record
    20140127: 雷史畢基:希巴女王 (200 克 LP)
    20140122: Plinth Design
    20140119: LP聆聽 Lyn Stanley - Lost In Romance
    20140119: LP沙灘女孩
    20140114: LP甜點
    20140114: Simon Yorke Designs new S45 recordplayer
    20140103: IKEDA SOUND LABS. - IKEDA SAI(彩)
    20131230: Langer No.7 Direct Drive Turntable
    20131225: Teragaki Labo 寺垣武
    20131224: Kronos Sparta Turntable
    20131217: 漂亮的LP Girl與盤
    20131211: 巧克力唱片
    20131210: Lautlos Rein LP washing machine
    20131206: Vertere Reference Record Player
    20131127: LP概念圖
    20131120: Ortofon technology 影片
    20131118: 蛋型MC放大唱頭,TechDAS TDC01
    20131114: Nessie 黑膠清潔機
    20131105: LP Girls
    20131101: Saskia Reference II Idler Turntable
    20131030: 2台VYGER
    20131028: Reed 3P tonearm structure
    20131025: V.Y.G.E.R Atlantis turntabl
    20131023: VPI 3D列印出來的唱臂
    20131017: Lyra Etna cartridge
    20131015: Keith Monks discOveryOne Record Cleaner
    20131009: 貝拉方提不同版本
    20131005: LP女孩訪問
    20131005: Puresound Motus II
    20131005: The Transrotor Falcon turntable
    20131005: The disc rotator
    此篇文章於 2014-10-27 04:04 PM 被 Ted Chen 編輯。
    :*搶頭香~~~~~~~~~~:P
    小葉大,
    LP到底比好的CD系統好在哪裡?能否分析一下?
    一直聽朋友說LP有多好多好,即使平價系統,都比價格高很多的CD系統好聽很多?
    是這樣嗎?
    添加一套入門平價LP系統需要花多少費用(包括唱盤,唱臂,唱頭與唱放),才能聽出與一套訂價數十萬的CD的不同?
    最近想加入LP一族,但仍有疑慮.
  5. #4
    其實不用太在意跟CD比如何如何
    LP與CD是兩個世界
    只要聽過大致就能馬上明白
    預算入門建議抓個15萬左右會比較好,應該就會有很好的效果
    不妨走趟店家聽聽看聲音感受一下是否很明顯的聽出不同,再上來分享一下您的想法
    對我而言
    CD與LP都很好聽,但好聽的感覺不一樣 :)
    引用 作者: watson0612 查看文章
    小葉大,
    是這樣嗎?
    最近想加入LP一族,但仍有疑慮.
  6. #5
    我個人的主觀看法是:
    在乎中頻的,LP比CD容易好聽;
    在乎超高頻與超低頻的,CD比LP容易好聽;
    在乎雜音與清晰的,CD比LP容易好聽;
    在乎『有味道的』,LP比CD容易好聽;
    至於真的要講究『進階級』的 HI-FI 性能,兩個都一樣難以好聽,各有各的強項與『現實問題』。所謂的『現實問題』最簡單的講法就是:
    錄音不夠頂級的唱片,通常LP遠遠大勝CD;
    現代最頂級的錄音唱片,只有CD而沒有LP;
    老大師只好找LP,現代高手只好找CD;不過我一定要強調,所謂現代高手『遠比不上』老大師這種事情其實非常非常非常非常.....非常罕見!....
    所以我個人認為玩LP有兩個很大的『入門陷阱』得克服:
    第一個就是:只聽到中頻,從而找不到真正錄音頂級的LP。
    第二個就是:容易以『好古非今』的態度來造成欣賞音樂的偏差....:o
  8. #6
    我個人的主觀看法是:
    在乎中頻的,LP比CD容易好聽;
    在乎雜音與清晰的,CD比LP容易好聽;
    在乎『有味道的』,LP比CD容易好聽;
    psycho大師,落落長啦.....
    小弟已轉投LP懷抱,只有一個原因,聽了舒服.....:P:P
    CD?忘了,只記得好像很久沒開機了....|-)
  9. #7
    其實要不要有LP系統
    我覺得最好決定的方法是
    直接去聽LP,看是否能帶給您感動
    其他的就都是後話了 :)
  10. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  11. #8
    其實要不要有LP系統
    我覺得最好決定的方法是
    直接去聽LP,看是否能帶給您感動
    其他的就都是後話了 :)
    最好就是不要聽,聽玩心裡一直想,
    想完手就會一直癢,癢完小朋友就一直跑......
  12. #9
    引用 作者: maxist 查看文章
    psycho大師,落落長啦.....
    我知道你轉投 LP 了,有空的話把相關討論轉貼來這裡,我們共同交流如何?玩LP我只是小咖,所以放心,不會落落長啦!....
  13. #10
    這個網頁有如何製作LP的影片
    http://blog.makezine.com/archive/201..._are_made.html
