第1頁,共4頁 123 ... 最後最後
顯示結果從 1 到 10 共計 34 條
    預設 【配件】立竿見影:瑞士AUDIOTOP唱針清潔液
    有聽LP的人,強烈建議一定要試試瑞士AUDIOTOP唱針清潔液
    不僅可以清潔,使用後的聲音效果驚人 :O:O:O
    Audiotop Stylus: Special cleaner for diamond cartridges / 10 ml.
    Formula: Mixture of an highly purified (99,999%) non specified substance and special nonionic tensides.
    Instructions: Gently clean the diamond on the cantilever with brushstrokes (moving from back to front, i.e. not against the cantilever). Repeatedly brush untreated or used pickup (about 8 times). Subsequently, brush the needle with one or two strokes after every record side has been played.
    Recommendation: Don't use the complete 10 ml content of the bottle as the power to clean may be reduced in the last 1 ml of the bottle due to residue from the needle left in the bottle. Clean carefully and only touch the diamond with the tip of the brush. We renounce any liability for any harm afflicted to the cartridges caused by inappropriate treatment!
    Characteristics: Stylus remains neutral to metals, plastics and adhesives made on the basis of cyanide (no guarantee exists for other materials). The cleaner carefully and effectively dissolves all residues on the diamond and is antistatic. The result is a defined diamond surface, which allows for optimal retrieval of information from the micro grooves. Soundwise you can expect increased channel separation, a spatially stable image, extended resolution over the entire frequency range as well as increased dynamics!
    原廠網站
    www.audiotop.ch
    使用後的聲音效果驚人 :O:O:O
    這一罐有看過沒用過
    看來你的黑膠有在play喔
    剛剛看了價格,夭壽貴
    USD 99......:|:|:|
    不過真的有厲害到 (smoking)(smoking)(smoking)
    引用 作者: michael99 查看文章
    這一罐有看過沒用過
    看來你的黑膠有在play喔
    剛剛看了價格,夭壽貴
    USD 99......:|:|:|
    你沒用唱片鎮喔:O:O:O
