第204頁,共355頁 第一第一 ... 104154194202203204205206214254304 ... 最後最後
顯示結果從 2,031 到 2,040 共計 3546 條
  1. #2031
    引用 作者: 將軍 查看文章
    去我媽家向老人家請安....:)
    你的髮色與一旁的美女太醒目了~~~:P
  2. The Following User Says Thank You to Musk For This Useful Post:
  3. #2032
    引用 作者: Musk 查看文章
    你的髮色與一旁的美女太醒目了~~~:P
    超感謝你的讚美.:*
  4. #2033
    暴風雨前的寧靜
    將軍 - Evolution
    Coming Soon.....
    MM7? :O
    I really like the sound of MM2 & 3 but never had a chance to listen to MM7.
  5. #2034
    引用 作者: 將軍 查看文章
    Decca/London,坦白說,我有一顆3支腳的,但卻從未聽過.
    這顆3支腳的問題,在於接線時極不方便,所以入手後就一直躺在防潮箱裡.
    我記得年輕時,音樂與音響裡的老前輩們都極為推崇Decca/London,
    除了他是真正的無針桿的鼻祖之外,應該是極為好聽才是.
    前些日子,這無聊的小高就神秘兮兮的告訴我要進口Decca/London,而且還是4支腳的Reference.
    哈,當然要4支腳的,3支腳的你就留著自己慢慢玩吧!!
    明天,大工程就要施工了.
    乘著今天還要空閒,拿出來照個相,改天再和Reed的3Q接起來聽.
    令人期待的聲音!!
    Congrats 將軍 on your latest cartridge acquisition.
    A good friend of mine has this London Reference for over a year now. He explained to me that it is probably the hardest cartridge to dial-in due to no cantilever - tip is hidden directly under the cartridge shell where you can barely see. And if the cartridge is not adjust properly, it will pick up quite a bit of vinyl surface noise - even with the brand new record.
    When the cartridge is finally aligned(with high power magnifier and ear), it presents a totally different sound than anything I've heard. Direct, dynamic yet detail presentation. The overall sound signature however lean a tad towards hard & bright. But I guess that has to do with the matching of tonearm, turntable, phono cables, phono stage and its loading choices.
    Please review the sound when your system is setup.
    Cheers,
  6. The Following 2 Users Say Thank You to Edgarhorns in LA For This Useful Post:
  7. #2035
    預設 Arrakis升級
    是時候了,期待了將近2年的Arrakis升級套件終於在幾天前到了台灣.
    這組套件從構思到和Rockport溝通,花了將近半年時間.
    之後的等待,又幾乎等了快1年又9個月.
    真不知是何原因,Rockport的作業速度始終就是著麼慢!!
    我一直認為Rockport的Andy很是固執.
    我的構思與希望,是傳統的BI-AMP,或甚是Tri-AMP.
    但,這類條件似乎不受Andy青睞,他胸有成足的硬是要將低音搞成增益可調式.
    不過這樣,並不代表分音器部份是主動式,因為Arrakis的分頻點還是被Rockport固定的.
    因此,升級後的Arrakis,分音器會有2組.
    第一組(中高頻)是在SP裡,另一組(低頻)就要放在外頭.
    而低頻這組因為要有增益可調,所以必須插電.
    嗯,是有些複雜....
    這樣說明,或許有些人會有聽沒有懂,不過沒關係,這不是重點.
    重點是,他還是和傳統的BI-AMP相同,需要2組後級;
    因此後級要再增加一組.
    此外,12M的訊號線要再增加一組,SP線也要再增加一組.
    所以重點應該是,很傷本.
    至於路線是如何搭,晚些,我再將Rockport原廠的搭線圖供大家參考!!
    現在,低音的網罩還在等黏膠乾固當中,只偷偷聽了一下.
    明天再繼續吧!!
  8. The Following 17 Users Say Thank You to 將軍 For This Useful Post:
  9. #2036
    太靚啦~~~~~~~~~~~~:O:P
  10. The Following 2 Users Say Thank You to 小佐 For This Useful Post:
  11. #2037
    Rockport Arrakis 終極升級
    被動式分音Bi-Amp
    在經過許久的計劃與到今日真正實現,將軍終於完成了Arrakis的升級這個超大工程,將Arrakis改為被動式分音Bi-Amp版本,除了要加一台Arrakis的被動式分音外,Arrakis原本的內部分音線路也要全改,當然改完之後,還要再加一對後級,還有一對喇叭線、一對與訊號線,這次的升級可能花費要逼近千萬,代價可謂不小,不過今日有幸聆聽初步發聲後...個人認為在原本已經逼近滿分的系統上,提升了3成以上,這簡直是非常困難的事,在原本這麼高水準下,透過這次的升級,居然還能提升這麼多!
    這次運作的原理
    CD訊號進入前級→Cello調色盤→Arrakis被動式分音器(125Hz以下一組訊號輸出、另一組PASS全頻段訊號輸出)→後級兩組(4台),1組推中高音、1組推125Hz以下的15"低音→喇叭中高音一組、低音一組,也就是說原本的125Hz低音不再透過內部分音,而是經由Arrakis被動式分音處理。
    看到後級有兩對4部嗎?當然其中有兩部將會換成最新的Gryphon旗艦:曼非斯特
    聲音呢?完全是另外一個境界了,真的無法形容了!
  12. #2038
    先恭喜將軍前輩兩年的等待終於有了結果, 期待將軍前輩或是小葉更多的分享:)
  13. The Following User Says Thank You to chsiang For This Useful Post:
  14. #2039
    看的熱血沸騰....
  15. The Following User Says Thank You to hjleea For This Useful Post:
  16. #2040
    這樣的系統下,更證明空間的重要性
    當聲音驚天動地時,空間仍然穩如泰山!
  17. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
