作者: maxist
就在某一天夜裡,突然瞄到一小顆當初在38度C買唱片時附贈的不知名FILTER,拿回家後一直都是掛在PS3的HDMI連接線上,影像的效果會變得稍為銳利。
閒來沒事,就開始拿著這顆FILTER開始從唱放至綜擴的訊號線一一測試,感覺似乎有那麼一點效用,原本RF廣播聲在左聲道較為明顯,夾上左聲道訊號線廣播音量會變小,但夾上右聲道時左聲道卻變更明顯吵雜了起來。接著再往前測試PHONO線,先從末端的左右聲道開始,結果與唱放輸出端的測試一致。再往前至PHONO線前端一夾,YA,BINGO!!!!
至少在正常甚至再大些許的音量裡,再也不用被催著買藥。
連睡覺都在偷笑。
這 audin 的屏蔽似乎不太可靠?:P
從圖片看來像是訊號線沒甚麼屏蔽,加個那玩意來解決RF干擾,感覺治標沒治本|-)
作者: hojuiyang111
作者: muzic1960
有可能,但換過好幾條PHONO線,似乎RF干擾的情況都還是會有。
居家環境的影響推估不小。
換個環境是最治本的方法啦,但現實面也只能屈就 囉....:P
作者: hojuiyang111
這 audin 的屏蔽效果大慨是最先進的了....當初是日本人發明的
整個導體由銅鍍銀箔完全包覆
請看原廠說明:
The Total Signal Control (TSC) Breakthrough
One of the “Dirty Little Secrets” in the hi-fi industry is that shielding affects the sound of your cables. Because no shield is perfect, a small bit of the audio signal will be carried on the shield while a little RFI and EMI inevitably pass through the shield and affect the conductor. Unfortunately, in a world filled with cell phones, microwaves, radar and dozens of other HF contaminants, interconnects need a shield in order to function at all.
Enter Total Signal Control (TSC). This extremely complex technology yields the industry’s first and only, purpose designed audio cable to achieve 100% shielding! Starting with a precision solid core conductor, Nordost applies its dual micro mono-filament technology and then jackets each conductor with an interleaved, overlapping wrap of thin, flat, silver-plated Oxygen-Free Copper. It requires super precision and incredibly tight tolerances to maintain the geometrical accuracy necessary to guarantee perfect performance from the minimum material. After all, anybody can throw a mass of metal at the problem, but it doesn’t work and ruins the sound!
The result of this exercise in precision engineering is a cable that achieves a perfect shield against external EMI and RFI while simultaneously preventing any leakage of audio signal from the conductors. The most important breakthrough in the history of high performance cable design, Total Signal Control keeps all of the signal in and everything else out! A proprietary and patented technology, TSC is exclusive to the Odin Supreme Reference family of cable products.
The Following 2 Users Say Thank You to peter1956 For This Useful Post:
講到AUDIN,小弟就知道可以把常大哥引出來了.....
濾波環愈往前端愈有效
小弟估計應該是由唱頭,唱頭引線,臂內線到DIN輸出端感應到的RF居多...
The Following User Says Thank You to peter1956 For This Useful Post:
