第708頁,共728頁 第一第一 ... 208608658698706707708709710718 ... 最後最後
顯示結果從 7,071 到 7,080 共計 7280 條
  1. #7071
    估不到 Server 2019 + RAM disk + JPLAY 的長期用戶亦察覺到(免費的)Win11PE 有多強大,最後還是乖乖的使用 foobar2000 了:
    http://jplay.eu/forum/index.php?/top...guide/?p=66863
    I was so criticaly wrong about PE it`s just superior. I don`t know what was wrong in the last time I tryed it. Server 2019 Core Ram and PE are just different planets. It`s so natural. so realistic. I`ve got the harmony wiyh PE. With server core ram and JPlay it was great but I was constantly trying to tweak it to sound right. Stripping PE from running services and drivers is so easy - just disable as much as you can, "less is more'' is the rule for PE but not with Server core where disabling some services could break the sound, make it harsh or unpleasand. And the second thing that shocked me is that Foobar is sounding so good with it. I refused using JPlay for now. I couldn`t believe it will ever be possible. Thank all of you leading this thread. PE brought me peace!
    http://jplay.eu/forum/index.php?/top...guide/?p=61077
    I think Internethandle does it with Spotify, so loading Roon supposes that it will be possible, I will tell you that the different
    players change their behavior with respect to the "normal" Windows.
    In my system (Win11 PE) I have tried 4 players: HQPlayer desktop 3 and 4; JRiverMC 28, Foobar2000 and Bughead
    Emperor (Infinity Blade); And the results were, from better to worse, the following:
    INFINITY BLADE> FOOBAR2000 >>> HQPLAYER4> JRIVERMC28.
    Instead, in Windows "normal" they were very different, from better to worse:
    Bughead Emeperor (Infinity Blade) >>> HQPlayer4 >> JRiverMC28> Foobar2000.
    As "normal" Windows versions I have used the following:
    Server Core 2022 (RAMDISK)> Server Core 2019 (RAMDISK)>>> Server 2022 Desktop>Server 2019 Desktop>Windows 11 Pro 22000.194> Windows 10 from initial versions to 20H1.
    All were much lower than Win11 PE and Win10 PE.
    http://jplay.eu/forum/index.php?/top...guide/?p=63862
    I have removed "iertutil.dll" and "imageres.dll" , contained in \windows\system32, which has allowed me to get a boot.wim size of 99.7 MB, with my ASIO drivers and F2k and BugHead installed. Without ASIO drivers and without audio apps the size is 84.4 MB !!
    另外還有一個相對簡單的方法可以用來製作 Win11PE 的 WIM 檔,看來還是變得比較方便的說:
    http://jplay.eu/forum/index.php?/top...guide/?p=66982
  2. The Following 2 Users Say Thank You to seeteeyou For This Useful Post:
  3. #7072
    關於DT2
    看之前大家在找DT2的貨源。
    我有批貨好便宜(X
    在鹹魚上看到有庫新品
    https://m.tb.cn/h.5lWw6U9?tk=12hyW4SE9U2
    不保證品質,也無法幫代買,有興趣的可以去聯絡看看。
    此篇文章於 2023-12-03 06:09 PM 被 a5401920 編輯。
  4. The Following 4 Users Say Thank You to a5401920 For This Useful Post:
  5. #7073
    這個笨蛋是我帶出來的學生,我們都會買DT2屯貨,所以有機會就要買....
    外接時鐘也想屯貨,不過構造相對簡單,不知道有沒有人可以提供『訂製』該外接時鐘的?高價收購哩!.....
    原先有段時期會覺得外接時鐘相差有限,剛剛測試過有沒有外接時鐘相差太大了!猜想是『六個大電容+1500W+電源隔離』的最佳效果。所以連外接時鐘也要屯貨了.....
    引用 作者: a5401920 查看文章
    關於DT2
    看之前大家在找DT2的貨源。
    我有批貨好便宜(X
    在鹹魚上看到有庫新品
  7. #7074
    Higuma 使用那種討厭的文字顏色讓人閱讀困難,欠扁!.......
    我找到管道多屯貨了一個DT2,999人民幣!!漲了3倍還是得買啊!!而該管道己被我與學生清光了,別想再買......
    考驗信仰的時刻到了,會不會又像鄉民說的:萬人響應,一人到場...
    如果有買到原價或是沒漲那麼多的DT2,這種價格當然買不下手;但是像我這種大後期才進來討論串的人,再貴都得吞下去,我還當兩次盤子呢...
    左邊是9月中旬購買,花了CNY1499
    右邊是11月底購買,花了CNY2000,但是賣家綁個CNY300的時鐘,DT2本體只要CNY1700
    今天收到新購入的DT2後,馬上上機測試是否正常,跟第一個DT2相比很明顯被RUN開,看來第一個DT2賣家也沒說謊,他說一個月只通電一次,近全新。
    另外,除了價格外,我不看好馬上被買光的原因是:大家不見得能接受老師的音響理念。我就曾經在蝦皮買過600V 1800uF大電容+香堡DC線呢...
    要不是最近花不少錢買了相機跟鏡頭,我一定用人民幣好好教訓那位學生
  8. The Following 2 Users Say Thank You to termdoxa For This Useful Post:
  9. #7075
    引用 作者: termdoxa 查看文章
    真的是『信仰』......
    我本來也不會屯貨,只是第一:XU316的聲音居然是垃圾...(或者SMSL與TOPPING這種跑分機根本是垃圾....)。第二、樂之邦隨時可能倒閉。第三,DT3眾籌失敗。所以這下子我不敢賭了,趕快屯貨......
    此外,也是因為DT2在我的音響室的表現實在太強大,所以更不能賭,只能屯。現在正在想要訂製性能超強的DT2專用外接時鐘......
    以前為了傳教,傳這個『正確的JPLAY CAT』教,所以一切都是『只買』大家都可以買到的器材。現在己經覺得獨孤求敗了,所以開始動歪腦筋去購買『訂製品』了..... 因為數位系統花個一萬元得到的改善,類比端可能要花十萬元以上都未必有改善....
  11. #7076
    我是覺得樂之邦不太妙...隨時有可能倒閉的那種,只能期待有新的救贖(類似DT2的DDC)。
    現在連新天新地也經營不善的樣子。
  12. The Following User Says Thank You to gangster.tank For This Useful Post:
  13. #7077
    請問教授, 並聯在COSEL PBA1500F的薄膜大電容還買的到嗎? 可否分享訂購的連結? 我打算用來接BURSON C3XR的耳擴。
    我找到的電容如下, 請問是這種嗎?
    https://item.taobao.com/item.htm?spm=a1z0d.6639537/tb.1997196601.24.3d387484DM7kJP&id=704999734514
  14. #7078
    引用 作者: jasont 查看文章
    我找到的電容如下, 請問是這種嗎?
    可以用的大電容到處都買得到,麻煩的至今還是無法確認那一種『最好』?不過只要是像你買到的上面那個,一定可以用!
    『薄膜无极电容』,900vdc,這兩個關鍵字句完全正確。
  15. The Following User Says Thank You to psycho For This Useful Post:
  16. #7079
    建議大家有空可以考慮去圓山音響展聽一些目前最頂級的數位訊源系統。我在九月音響展的時候去聽了一些最知名的,雖然環境和類比部份影響聲音表現非常大,還是能大致了解目前這些「超弩級」數位訊源是怎麼一回事,也對我們 DT2/超強運算力電腦/外接3.5吋硬碟/超低 CPU-memory latency/外灌切換式電源的 JPlay 訊源系統水準有更客觀的認知。
  17. The Following 2 Users Say Thank You to dequad For This Useful Post:
  18. #7080
    引用 作者: dequad 查看文章
    你要不要說說看你的看法?老實說那些「超弩級」數位訊源如果是走『特色』,那麼特色就會透過電源線污染所有器材;如果走『HI-FI』,那就會為了避免污染別的器材而導致性能大幅下降、性價比嚴重降低。如果有做到『大電供』與『電源隔離』,還有什麼「超弩級」數位訊源是可以讓我們參考的?這到是很有興趣.....
