2018-02-15, 02:33 PM
#211
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (安裝)
來看一下這個龐大系統的安裝過程吧,要有專業還要有體力!
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2708mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2717mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2731mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2733mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2735mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2738mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2740mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2745mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2746mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2747mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2748mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2753mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2754mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2756mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2757mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2759mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2766mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2768mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2769mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2774mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2776mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2782mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2784mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2796mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2801mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2805mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2807mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2808mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2810mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2814mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2815mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2818mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2820mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2826mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2827mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2831mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2842mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2848mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2849mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2857mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2858mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_2868mm.jpg)
2018-02-15, 03:39 PM
#212
終於等到了: 殺手級的數位串流轉盤 AURALiC ARIES G2
AURALiC G2系列發表後,市場上馬上造成缺貨搶購狀態,除了需求買家多外,高難度的全鋁挖空本體加工也是出貨量有限的原因,等了好久終於等到代理商有空檔將器材借出給我們試聽。ARIES G2技術特點:「無線傳輸」最高支援DSD512 & PCM 32bit / 384 kHz、AURALiC TESLA G2運算平台、採用雙飛秒時鐘,一個提供44.1Hz頻率,一個提供48Hz頻率,'不同取樣率的音樂切換時,時鐘頻率會自動切換、隔離電路最重要便是上述的物理性電氣隔離晶片、雙線性電源、Lightning Link連接技術,可選配加裝硬碟,前方一個大型彩色顯示螢幕,Airplay, Bluetooth, Roon Ready,自家開發的Lighting DS APP播放軟體也不斷進化,非常好用!
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8289aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8290aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8292aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8296aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8302aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8307aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8311aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8319aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8323aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8331aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8334aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8338aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8354aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8359aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8361aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8366aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8370aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8372aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8378aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8365aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8367aa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8374aa.jpg)
![](http://my-hiend.com/wp/wp-content/uploads/2017/12/Auralic-G-Series-8.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1530.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1534.jpg)
2018-02-16, 12:35 PM
#213
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (二)
mbl N31 CD-DAC CD唱盤與數位類比轉換器
全新Noble Line貴族系列在外觀上更具有時尚質感,標準配色有三種,本次試聽是mbl經典最受歡迎的黑金配色,N31除了可播放CD外,也是一台功能完整的DAC,N31與前級N11造型幾乎完全一樣,中間是一個5"大型的TFT彩色顯示螢幕(無觸控功能),螢幕兩旁都有六個按鍵,兩者唯一的差別就是N31的螢幕下方是吸入式的CD口、N11則是音量旋鈕。
實際操作N31的特點:
(1) 吸入式CD的讀取速度很快
(2) 若CD有TEXT資訊,會顯示在螢幕上
(3) 裝置有紅外線感應,只要有手接近,就會自動顯示選單讓用家操控,很有未來科技感
(4) mbl SmartLink 2.0,整個系統的控制是連動的,資訊也可彼此交換串連,例如只要按下開關就可以完成整個系統的開機與關機。
(5) 若要切換輸入來源(CD、AES/EBU、S/P-DIF、TOSLINK、USB),需透過前級切換。
(6) 機器上方的mbl標誌是可按的,控制顯示螢幕的亮度,透過Smartlink的連接,整個系統的顯示亮度會同步連動調整。
(7) 類比輸入有平衡與RCA各一組。
技術資訊方面
(1) CD傳動系統是經過mbl最佳化,消除空氣的干擾與機械的震動
(2) 取樣頻率轉換的過載的保護設計(Intersample Overload Protection)
(3) 自動關閉沒在使用輸入的振盪器(oscillators)
(4) 三級時基誤差消除(3-stage jitter reduction)
(5) 物理及聲學最佳化的數位與類比濾波
(6) 整體延遲最佳化的類比輸出濾
(7) 三種數位濾波模式可選 ((minimum phase / smooth transition, slow rolloff/ linear phase)
(8) 4路徑的DA轉換,在delta-sigma與multi-bit間的處理能輕鬆應付
(9) 全平衡線路
(10) 如果使用iPhne/iPad當訊源時,N31會跳過他們內部的DA,改用N31高品質的DAC,保證Bit-True與零時基誤差,最高可支援到24Bit/192kHz與DSD64。
(11) 所有的輸入與輸出都有Galvanic isolation隔離。
(12) 光學隔離的USB輸入,擁有自己的供電
(13) 解碼能力最高為24bit/192Khz、DSD64
(14) SD插口供未來Firmware升級之用。
(15) 德國設計生產。
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8788mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8791mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8795mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8782mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8785mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8773mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8769mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8775mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8750mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8740mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8754mm.jpg)
此篇文章於 2018-02-17 10:52 AM 被 Leo Yeh 編輯。
2018-02-16, 03:36 PM
#214
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (三)
UNITY GAIN
在N11前級上,mbl使用了全新的「UNITY GAIN」的技術,將底噪降低,動態提升,使得聲音的透明度與解析度更好,用家可以選擇要不要啟用這個功能。當「UNITY GAIN」啟動時,前級的放大會下降8 dB,達到提升聲音表現的效果,尤其在低音量時也能享受到大音量時才有的動態!
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8805mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8807mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8813mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/unitygain.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8821mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8825mm.jpg)
2018-02-17, 10:25 AM
#215
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (四)
mbl N11前級
實際操作上的特點:
(1) 與N31一樣,SmarkLink、紅外線感應、5"彩色螢幕跟SD插槽升級功能,這裡就不再重複
(2) 非常完整的輸出入介面,包括平衡與RCA。
(3) 不使用的輸入可設定關閉,減少輸入間的干擾。
(4) 可設定開機時最大的音量,避免不小心的大音量損害系統或小孩的耳朵。
技術部份:
(1) 新的UNITY GAIN技術,可提升聲音表現。
(2) XLR優先,以最大化共模拒斥比(Common Mode Rejection Ratio, CMRR)
(3) 高頻寬的單級增益,極低的底噪與失真
(4) 類比音控、級進式馬達與電位器
(5) 可選配唱放輸入、並有接地設計
此篇文章於 2018-02-17 10:51 AM 被 Leo Yeh 編輯。
2018-02-17, 11:50 AM
#216
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (五)
LASA 2.0 (Linear Analog Switching Amplifier)
LASA是mbl研發最新的放大線路、最早運用於2011年發表的Corona系列,而在2016年發表的Noble系列上使用是更新的LASA 2.0。LASA研發的目標是在結合傳統A類、AB類與D類擴大機的優點,並且要能同時避免他們的缺點,找出新一代的放大線路,更重要的是,mbl是以不斷實際的聆聽做最後的表現確認!
經過不斷的研究與聆聽,LASA完成了這個不可能的任務,結合了A類擴大機的聲音表現與D類擴大機運作的效率,而且LASA還有一個很重要的特性,就是能應付喇叭複雜的阻抗變化,無論在什麼音量下都可以應付而不會產生不協調的失真。mbl使用4QT能力來衡量LASA的表現特性(4QT = four quadrant test, current and voltage in phase, off phase, leading and lagging to each other)。
LASA擴大機裡,環型變壓器使用了極為特殊的MU金屬具有靜電、電磁雙層屏蔽的效果,使用高品質的交換式電源與許多不同的電子元件與線路。(電解電容)。
LASA 2.0
(1) 在4QT的表現更好。
(2) 動差放大輸入,改進了最大化共模拒斥比(Common Mode Rejection Ratio, CMRR),讓後級、前級與D/A不會相互干擾。
(3) 導入低阻抗接地概念到電源功應與輸出級中,提升了聲音的透明度與頻率響應範圍的控制能力。
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8873mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/mbl_lasa.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8882mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8888mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8890mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8895mm.jpg)
2018-02-17, 12:04 PM
#217
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (六)
mbl N15單聲道後級
實際操作上的特點:
SmartLink的好處,基本上後級安裝好後根本不需要再去碰他了
技術部份:
(1) LASA 2.0放大線路
(2) 對稱的線路擁有更佳的共模拒斥比(Common Mode Rejection Ratio, CMRR)
(3) Spft Clipping,即使是很大音量,擴大機也是溫和的運作,不會聽起來刺耳
(4) 電源供應的巨大環型變壓器使用MU金屬屏蔽。
(5) 4歐姆下輸出560W,電流高峰達36 Amp,在高音量時也能確保聲音表現。
(6) 低復原損失的整流器。
(7) 擁有可外接後級的XLR輸出,允許Bi-Amping。
(8) 兩組XLR輸入對應前級或是訊源。
(9) WBT喇叭端子。
2018-02-17, 01:14 PM
#218
當代High End音響的工藝典範: mbl noble line與101 E MKII喇叭 (七)
mbl 101 E MKII喇叭
連續看了全新noble line的介紹,最後我們來看一下這對101 E MKII旗艦喇叭(不算巨大的101 X-treme四件式),mbl自家專利的360度發聲葫蘆單體(Radialstrahler)是最具特色的,只要想到葫蘆單體就會想到mbl,只要想到mbl,就會想到葫蘆單體。葫蘆單體的結構是垂直的,從上方固定一瓣一辮的振膜,驅動振膜的磁鐵在下方,101 E MKII由上而下共採用高音、中音與低音三個葫蘆單體,原廠有製作了介紹影片(https://www.youtube.com/watch?v=HJdHq3gw1Iw),看了會更瞭解其運作方式。若有興趣知道其製作過程,這裡也有影片可以觀看(https://www.youtube.com/watch?v=G5EMrFsT7V4)。高音與中音單體的振膜是碳纖維,低音單體是鋁鎂合金。
Radialstrahler單體超越了傳統單體的單向發聲,將聲音的構面變成全方位360度的構面,因此mbl的喇叭聽起來在音場與空間感上特別優異,而且雖然是360度,但左右喇叭仍是對稱的,在定位結像上仍是非常清楚的,甚至更為豐富。101 E MKII為四音路設計,除了三顆葫蘆單體外,下方還有一顆12"的鋁盆超低音,整體頻寬24~40kHz,阻抗4歐姆,效率82dB,分頻點在105.600/3500Hz,單隻重80kg。在喇叭的後面下方有跳線可調整高音與中低音的特性,用家可依喜好好試試。
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8916mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8911mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8930mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8934mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8939mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8942mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8944mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8949mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8952mm.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_8955mm.jpg)
此篇文章於 2018-02-17 01:23 PM 被 Leo Yeh 編輯。
2018-02-17, 07:18 PM
#219
不需高價也能準時了: TEAC CG-10M主時鐘產生器
除了SACD/CD唱盤外,主時鐘產生器一向是Esoteric主要產品之一,只要體驗過就能感受到外加精準的時鐘能讓聲音顯著的提升,現在自家品牌TEAC也首度推出平價版本的主時鐘產生器,讓一般用家也能體驗更精準時鐘所帶來的好處,市場上熱賣的TEAC 5系列,最新發表的UD-505 USB DAC及NT-505網路串流DAC,也都標準配有10MHz的時鐘輸入(CLOCK SYNC),以外接CG-10M,當然,不僅TEAC,只要有10MHz時鐘輸入的器材都能使用CG-10M。CG-10M主要使用一個高品質的OCXO恆溫晶體振盪器,提供高精度10MHz的時鐘訊號,–±3 ppb内的頻率溫度特性和 ±0.1 ppm內的頻率精度。前方有一個類比指針顯示,可隨時觀察其運作的狀態,顯示燈的亮度是可以調整的。CG-10M可同時輸出4組訊號供4台器材同步使用,要注意的是輸出阻抗為50Ω,熱機約10分鐘可達穩定狀態。
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9032tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9033tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9035tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9049tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9046tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9066tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9072tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9075tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9079tt.jpg)
2018-02-18, 09:17 AM
#220
就是要領先: TEAC NT-505音樂串流DAC
TEAC自從發表5系列以來,就以性價比傲視市場對手,造成熱賣,這次新一代的五系列更是繼續提升,NT-505與上一代的NT-503相比增加了:
(1) 更新的VERITA AK4497 DAC晶片
(2) 解碼能力直接到頂: DSD 24.5MHz(DSD512),PCM 384kHz / 32bit
(3) 更多組的PCM, DSD數位濾波選擇
(4) 高品質Bulk Pet USB傳輸技術
(5) MQA支援、Roon支援
(6) 更好的藍芽傳輸LDAC™,aptX™HD
(7) 獨立的耳擴線路,並改為3.5mm 4極端子
10MHz的時鐘對應輸入則是在NT-503就有的。透過TEAC HR STEAMER APP可以很方便的進行操作播放網路設備中的音樂,如NAS或是線上串流TIDAL、Qobuz等等,Airplay也非常方便。
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9093tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/SGH_9111tt.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1536.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1537.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1538.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1539.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1540.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1544.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1546.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1547.jpg)
![](https://www.my-hiend.com/leoyeh2/2018a/IMG_1549.jpg)
此篇文章於 2018-02-18 10:09 AM 被 Leo Yeh 編輯。
