【線材】Nordost Leif: Purple Flare 8字電源線
The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
![](https://www.my-hiend.com/leoyeh2/2013a/DSC05953ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2013a/DSC05961ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2013a/DSC05963ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2013a/DSC05971ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2013a/DSC05979ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2013a/DSC06018ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2013a/DSC06020ss.jpg)
When you listen to your system, you are actually listening, quite literally, to the AC mains supply, which makes the most important cables in your system the ones feeding power into the equipment. They are responsible for the raw material that gets turned into the sound you hear and as befits this critical function, Nordost employs FEP insulation and its proven, proprietary high-speed, low-loss Micro Mono-Filament construction to deliver the best possible power source for your system.
The Purple Flare power cord employs a dedicated, two-core topology designed to maximize the performance of screens and electronics using Figure-8 AC inputs. If you've never seen your video display fed by a high-quality power cord, Purple Flare is the one to try. UL approved, it is available in a full range of AC plug options.
Insulation: Fluorinated Ethylene Propylene (FEP)
Construction: 2x 16AWG Micro Mono-Filament
Conductors: 65 strand 99.9999 OFC solid-core
Capacitance: 10.0pF/ft
Inductance: 0.155uH/ft
