讓售全世界只有30對的 Hegel H10 300W後級
系統升級,讓售全世界僅有 30對的 Hegel H10
300W 後級擴大機。(讓售價格 NTD$200,000)
品相新,原廠配件,說明書及外箱。
報導:挪威的HEGEL為了慶祝出口第10週年,決定推出一組讓該公司專利技術SoundEngine發揮到極致的產品:限量30套的P10與H10前後級組合。P10與H10使用了HEGEL專利的錯誤消除技術,讓動態更大、更低的靜態與動態失真。為了達到SoundEngine最高表現,HEGEL必須要對4種不同的FET電晶體進行手工測量配對,30套的H10,HEGEL買了3萬顆的FET電晶體,只有1/100的機率。
規格:Voltage amplifier:Hegel SoundEngine FET proprietary design
Output amplifier:Hegel SoundEngine Bipolar proprietary design
Power output:300W + 300W at 8 Ohms、570W + 570W at 4 Ohms、1000W + 1000W at 2 Ohms
Minimum load:Loudspeaker impedance down to 0.5 ohms can be connected.
Input Sources:RCA / phono inputs and balanced XLR selected by input switch
Input Terminals:Gold plated RCA / Phono unbalanced and gold plated XLR balanced
Output Terminals:Two sets of gold plated speaker terminals each channel
Channel balance:Less than +/-0.1dB deviation
Frequency response:Less than +/- 0.2 dB deviation 20Hz-20kHz
Phase response:Less than 2 degrees deviation 20Hz-20kHz
Signal-to-noise ratio:More than 100dB
Crosstalk:Less than -100dB
Distortion:Less than 0.003% @ 100W 8 Ohms 1kHz
Intermodulation:Less than 0.01% (19kHz + 20kHz)
Damping factor:More than 1000 ( measured at centre point of power output stage )
Dimensions:21cm x 43cm x 55cm (HxWxD), 58 kg shipment weight.
意者洽: [email protected] tel:0920-864310 陳先生
此篇文章於 2012-10-29 11:23 AM 被 fcchen00 編輯。
原因: 忘了寫價格
聲音非常出色,我用它來跟 ARYE的 MXR 後級比,動態跟音質真的差不了多少。因為買了MRX(虛榮心),感覺聲音走向非常類似,真是很不錯的後級。
此篇文章於 2012-11-09 04:59 PM 被 fcchen00 編輯。
