第33頁,共48頁 第一第一 ... 23313233343543 ... 最後最後
顯示結果從 321 到 330 共計 475 條
  1. #321
  2. #322
  3. #323
  4. #324
    • WD RE4 2TB
    • Samsung EcoGreen F3 2TB
    • Seagate Barracuda LP 2TB
    • Seagate Barracuda XT 2TB
    • Seagate Constellation ES 2TB
    • WD Caviar Black 1TB
    • WD Caviar Black 2TB
    • WD Caviar Green 2TB
    • WD AV-GP 2TB
    • WD RE4-GP 2TB
  5. #325
    真的世界第一啦!!!!!!!!!!!:O:P
  6. #326
    果然愛用WD RE系列是對了...XD
    (WD RE4 2TB打死不降價...還很貴)
    目前PC內4個硬碟由RE2到RE4都有...=_="
    不過對於怕死的我...WD RE系列是唯一的選擇..(還要配Oline UPS)
    WD的RE系列的弱點是不穩定的供電
  7. #327
  8. #328
    Opera audio D-Linear 7
    High Definition digital music interface
    Key Functions:
    1. Digital stream master network audio interface (24Bit/192KHz)
    2. Digital stream Hard Disk recorder (24Bit/96KHz)
    3. WI-FI/LAN Internet radio
    4. Upgrade operating system from USB
    The Linear 7 High Definition digital music interface contains audio coding and decoding software that can process 24Bit/192KHz high bit rate digital master tape audio streams at very high speeds and supports the decoding output of all types of digital audio formats, such as (WAV//WMA/ APE/FLAC/ALAC/ACC ). In the future, through firmware upgrading, the device will support even more audio formats.
    It can also be used as a network music server center. It can support any network hard disc NAS and can share network resources through WI-FI/LAN. It can also be used as an Internet radio. With a built-in channel list, it can receive over ten thousand digital Internet radio stations from all over the world.
    The linear 7 adopts the specialized 32-bit high-performance embedded multi-media processor CPU, multimedia DSP chip solution and the reference clock system of the industrial-class digital phase-locked loop (DPLL) system, effectively reducing clock jitter in transmission of digital audio signals so as to achieve an ultra-low jitter index.
    The Linear 7 has an LCD display with a touch screen allowing the user simple operation. The screen can display the artist's name/internet radio station information and the sampling rate. It also includes an easy to use high quality fully functioning remote control.
  9. #329
    Opera audio D-Linear 8
    24bit/192khz Decoder
    Key Functions:
    1. USB wireless DAC digital receiver
    2. Universal DAC for CD transports, The Consonance HD interface, DVD players, Blu-ray players, cable TV decoders and satellite receivers
    3. Hi-end Headphone amp
    4. RCA and Balanced outputs for analog
    The newly designed Consonance Linear 8 Decoder is more than simply a new product, it is also a new concept in audio enjoyment. The heart of the linear 8 is the PCM1792 24-Bit chip running at a 192kHz sampling rate. Our decoder uses the Transceiver has a low jitter analog PLL, and a PLL lock range from 32khz to 192khz .
    There are 4 selectable digital inputs on the rear panel consisting of a coaxial RCA, AES, Toslink and an antenna for digital USB computer input. The basic signals are displayed through the front panel meter. This meter will also indicate when the signal is locked in.
    The Linear 8 has a wireless USB 2.4G ISM license free band, adaptive frequency hopping random ID pairing and non-compressed 48k/16bit sampling. This wireless system is like a secondary music system that will compliment your existing main setup. It can be operated at a considerable distance (up to 25m) from your primary system, there are no bothersome cables. Your computer can be used as a main source of your music playback allowing you more freedom and worry free operation in your musical enjoyment.
    The Linear 8 includes a hi-end headphone amplifier, 32ohm to 600ohm.
    Its size is unobtrusive so it can be positioned anywhere, and it has a very user friendly interface.
  10. #330
    以音樂來說 USB 1.1 就可跑到24/96,USB 2.0 到24/192已沒問題
    沒什麼規格戰吧?
