第30頁,共79頁 第一第一 ... 20282930313240 ... 最後最後
顯示結果從 291 到 300 共計 790 條
  1. #291
  2. #292
  3. #293
    Question
    . 同一張專輯撥完無自動接著撥下一張
    (利用撥放清單克服)
    . 撥放清單無法編輯,只能全部刪除重設
    . 升級軟體後,網路電台反而會中斷,要如何改回舊版本?
    . Olive 2透過NAS,無法顯示封面
    . 透過foobar一次只能放一首 (NAS OK)
    . Olive 2沒有maestro控制功能
    . 中文介面: 網路電台我的最愛只能加不能刪 (要用英文介面)
    . maestro中文介面的bug
    (1) 歌曲分類不能用中文
    (2) "撥放"翻譯成"重覆撥放"
    (3) 從『專輯名稱』-> 『你的專輯名稱』->『編輯』的話,就無法編輯作曲家名稱
    . CD rip完,有時後CD會自動退出,有時候不會
    . 面板反應慢 (這個是硬體問題,可能要等貴一點的Olive出世了)
    . 找新加入的rip專輯不好找,是否能有一個新加入的選單出現,方便編輯與找尋
    . 備份可以增加用NAS嗎?USB太麻煩嘍
    . 正在播放歌曲,依然可以操作面板到其他功能,但卻無法回復到正在播放的畫面,電台無此問題,只要按一下橘色3角play即回復
    . 播放NAS資料庫,希望能像電台一樣有跑馬燈
  4. #294
    謝謝小葉的匯總, 將Olive目前的問題一次反應給廠商.
    不過若是能將較重大的bug優先處理的話,新的firmware
    也可早一點出來.
    ex:. 升級軟體後,網路電台反而會中斷,要如何改回舊版本?
  5. #295
    Release notes Olive 4/4HD and Olive 2
    Olive 4 and 2 were formerly named Opus 4 and Melody 2.
    Changes in software version O.4.1.1 and M.4.1.1, released 01/28/10
    New Features
    • Redesigned popup-menu for the play screen with the ability to burn/delete a complete album and create a new playlist
    • Redesigned popup-menu for when a CD is inserted with the option to eject the CD
    • The Olive 4 can now be accessed with iTunes (note: FLAC is not supported by iTunes)
    • MAESTRO Software
      • An alphabet jump for the artwork view is now available
      • Possibility to change the artwork within the edit section within the tab “Recording”
      • Tracks are accessible and editable within their own list
      • A search has been implemented for artists, albums, tracks and playlists
      • The order of tracks within a playlist can be changed
      • Songs can be deleted from a playlist
    Improvements and bug fixes
    • Enhanced internet radio playback of stations with weaker connection
    • Autoeject of CDs after ripping/burning
    • Overall burning feature has improved in handling logic
    • The detailed information in the playscreen has increased in length and has been altered to accommodate for Twonky
    • The European time is applied consistently to all appropriate languages
    • The popup confirmation after a CD has been ripped now stays to pass on the information properly
    • Tracks are now all sorted by their original track number
    • MAESTRO software
      • Tracks of a playlist are now all listed in one set
      • no more limitation to 64 items within an album/work
      • Scrolling performance improvements within the artwork view specially for huge libraries
    Additional changes for Olive 4 HD to the one above
    New Features
    • HDMI video out background color is now set to black
    • Improved burning process of HD Tracks (note: 24bit WAV Files are not supported yet)
    • Enhanced music playback of HD Tracks (Hyperion)
    • Metadata of mp3 tracks ripped with iTunes is imported to the Olive
    • Shuffle algorithm changed in order to prevent the playback from stopping after a few songs
    • HDMI video out on certain LCD and Plasma TVs should not tear or jitter any more
    Additional changes for Olive+ to the two ones above
    New Features
    • Digital-in playback pauses local playback when selected and is resumed whenever user decides to disconnect digital-in source
    • Analog volume level and mute setting is preserved when user switches from local to digital-in playback
  6. #296
    你的USB要是FAT32
    1. Olive 4: Software update image 4.0.3 | Date: 10/21/09 | DownloadOlive 4: Software update image 4.0.3
      Download: SWUpgrade_opus.tar
      Filesize: 102.5 MB
    2. Olive 2: Software update image 4.0.3 | Date: 10/21/09 | Download
    1. 關機
    2. "中" "下" 一起按,開機
    3. 依指示插入USB
    http://www.olive.us/contact/software/installation.html
    引用 作者: ericguu006 查看文章
    也可早一點出來.
  7. #297
    官網的方式,我已經試了10次了, "中" "下" 一起按,開機
    可是就是沒出現要我插入 USB Stick的訊息.
    我也有寫信給 Olive 4HD跟CC 小高. 不過還沒收到回信.
  8. #298
    後方電源整個關掉再開也沒用?
    那會不會4HD沒有這功能...|(|-
  9. #299
    我剛試了4HD,有出現插入USB的畫面
    (1) 先打開4HD
    (2) 按中、下
    (3) 一直按電源等其自己重開 (中下都不要放喔)
  10. #300
    若覺得中文翻譯不好
    4HD設成英文後
    maestro進去也是英文的
