第25頁,共77頁 第一第一 ... 1523242526273575 ... 最後最後
顯示結果從 241 到 250 共計 761 條
  1. #241
    USB up to 96 la.
  2. #242
  3. #243
    引用 作者: alanvinsa 查看文章
    already update with Filter A, B , C
    這個選項我怎找不到B/C...
  4. #244
    Once upgrade you will the the USB input is 96. But when plug in a cable. It become 48 Again ?????????
    Filter B, C is great......
  5. #245
    Filter B, C should be the options for complete version,
    This upgrade only focus on the cover art issues.
  6. #246
  7. #247
    Its not option now. Once upgrade. You will get it............
  8. #248
  9. #249
    Once upgrade==> Hardware, not firmware upgrade...:|
  10. #250
    遙控器應該快要出了ㄅ......
    When. How much............
