第21頁,共77頁 第一第一 ... 1119202122233171 ... 最後最後
顯示結果從 201 到 210 共計 761 條
  1. #201
    just buy a Seagate - Free Agent Desk HDD. It Ok now. Buy directly rap to USB , It was no error correction ?
  2. #202
    Rip process is the same, no matter where you store at.
  3. #203
    I choose reap to USB, It was found no any error correction. Just restart the mechine and show update software. Already 30 Min. How long it need ?
  4. #204
    It depends on the size of the updated file.:)
    引用 作者: alanvinsa 查看文章
  5. #205
    hi, Leo . Are you sure direct rap to USB is same to the internal. Any USB cable recommand
  6. #206
    You could email to Bladelius for sure.
    I have not try any USB cable yet, sorry that I have no comments now.
    Many High End brands have USB cable now.
  7. #207
    Confirm the same rap to internal & USB.
  8. #208
    congratulation (party)(party)(party)
  9. #209
    Any idea sharing for set up the HDD by directory . by singer, by type or others.......
  10. #210
    It's a hard work and a good question.
    I classified by the album first, the second folder is the artist.
    Embla uses the same ideal as the file management program in computer.
