第18頁,共268頁 第一第一 ... 816171819202868118 ... 最後最後
顯示結果從 171 到 180 共計 2677 條
  1. #171
  2. #172
    光月夜也 來了....
    哇不知不覺已經30好幾小葉要去嗎
  3. #173
    你不要跟我說你從小看到大.......:|
    我那天已有行程,可能沒辦法爽到
    你代表去,回來分享好康的:*
    引用 作者: 統元音響 查看文章
    哇不知不覺已經30好幾小葉要去嗎
  4. #174
    Nikon D5000
    D5000ボディ ¥OPEN(予想実売価格88,000前後)
    D5000レンズキット ¥OPEN(予想実売価格100,000前後)
    D5000ダブルズームキット ¥OPEN(予想実売価格130,000前後)
    Effective pixels: 12.3 megapixels CCD
    23.6 × 15.8 mm size CMOS sensor
    Nikon DX format 12.9-megapixel total pixels
    Recording Media: SD / SDHC card
    ISO Sensitivity: ISO 200 ~ 3200 (1 / 3 step-step)
    Dimensions: approximately 127W × 104H × 80Dmm
    Weight: 560g
    http://www.nikon.co.jp/main/jpn/what...4_d5000_01.htm
  5. #175
    Nikon D5000
    Weight: 560g
    小葉大大辛苦了,很晚睡喔!:):):):):)
  6. #176
    沒辦法 |-)|-)|-)|-)|-)
    引用 作者: twc 查看文章
  7. #177
    Pentax's "K7D"?
    * Same sensor as the K20D
    * Up to 6400 ISO with better noise treatment
    * 5 images/sec
    * 100 % viewfinder
    * Better weatherproofing
    * Mirror lockup
    * Liveview and HD Video
    * Better stabilizer .
    * Better DRE mode
    * 77 zones light metering
    * Much better AF system even with non-SDM lenses
    * 3 inches/ 920 000 pixels screen with in-body editing (crop…)
    * 1/8000 shutter with 1/250 sync
  8. #178
  9. #179
    Olympus will release the digital camera to comply with the Micro Four Thirds standard
    SEOUL, Korea (AVING) -- <Visual News> Olympus announced that it is going to release its new digital camera based on the 'Micro Four Thirds System' in early July.
    (Picture: a concept mock-up of the camera unveiled at Photokina 2008 )
    Development of the camera will bring dramatic reductions in size and weight to the Olympus E-System due to the removal of the mirror box.
    The Micro Four Thirds System standard was established by enabling the development of radically more compact and lightweight interchangeable lens type digital camera systems. The camera expected to be officially announced on June 15th will be the first Olympus camera to comply with the Micro Four Thirds System standard, and interchangeable lenses that comply with the standard are also moving ahead. In addition, users will be able to mount existing Four Thirds System wide-angle, telephoto, and macro lenses on Micro Four Thirds System bodies via an adapter.
  10. #180
    歡迎本社的新成員(clap)(clap)(clap)
    http://www.flickr.com/photos/whitehouse/
    小豬與山爺也入手啦!!!!!!!!!:P:O:O
