第47頁,共64頁 第一第一 ... 37454647484957 ... 最後最後
顯示結果從 461 到 470 共計 631 條
  1. #461
    引用 作者: sam0402 查看文章
    我比較有興趣的是 MPD上的SlimProto plugin,小弟的功力不夠,目前看來沒什麼機會。
    This is an ALSA plugin required by SlimStreamer
    https://github.com/gimesketvirtadieni/slimplexor
    SlimStreamer is an audio streaming software for Linux with multi-room functionality. SlimStreamer captures audio playback from ALSA and broadcasts it to connected Squeezebox devices (real or ‘virtual’ like squeezelite).
    https://github.com/gimesketvirtadieni/slimstreamer
    已經好幾年沒有任何更新了,大概就是被放棄的說,且看有沒有甚麼可取之處吧:
    https://www.diyaudio.com/community/t.../#post-5285442
    I use SlimProto (SlimProto TCP protocol - SqueezeboxWiki), the same protocol used by Logitech Media Server (Logitech Media Server - SqueezeboxWiki). In other words, SlimStreamer mimics Logitech Media Server. This protocol came a long way; companies like Slim Devices and Logitech put a lot of expertise into it: SlimProto is the next version of SLIMP3, it supports lots of codecs, it allows using various sample rates, synchronisation, DSD over PCM (have not tested), … However the main reason I have chosen using it – players can be Pi Model A or Zero with decent DAC running a single SW player (squeezelite). The rest of the music functionality is done on server (regular player, MPD, Mopidy, Spotify, ShairPlay, …).
    https://forums.slimdevices.com/forum...ox-com-servers
    After a more than ten year journey, as of February 2024, we will discontinue our UESmartRadio.com and MySqueezebox.com servers. We would like to thank you for your loyalty and support throughout this time.
    短期內也不會有重大的變動,畢竟 LMS 實屬開源的軟件,但是前景還是比較堪憂。
    另外 Apple Music 提供的無損 ALAC 檔案已經被「大補帖」化:
    https://github.com/WorldObservationLog
    實際上 Apple Music 和 TIDAL 的 Dolby Atmos 格式還有這種好處:
    https://www.audioholics.com/news/son...ew-format-wars
    Both formats solve problems associated with the so-called "Loudness Wars" by being mastered at significantly lower volume than most stereo tracks. According to Mastering Engineer Ian Shepherd, Atmos specifies mastering at an integrated loudness of -18 LUFS. From lurking audio pro communities I've learned that's as much as 10dB lower than the many of today's stereo masters. You'll have to turn-up the volume, but for your effort you may hear more dynamic range and subtle detail missing in so much of today's two-channel recordings.
    https://web.archive.org/web/20230922...-why-with-fix/
    The low volume level requires listeners to turn up their system in order to hear the same average loudness, but this results in improved sound quality and clarity when compared with traditional stereo mixes.
    https://www.travsonic.com/why-dolby-atmos-is-quieter/
    The lower volume level may require listeners to turn up their system to achieve the same average loudness as previous stereo releases. However, this adjustment improves sound quality and clarity compared to traditional stereo mixes.
    當然最重要的事情就是如何利用兩聲道的系統欣賞 Atmos 格式:
    https://audiophilestyle.com/forums/t...omment-1265920
    The traditional two channel and the Atmos two channel cometimes can me very similar, but other times can be very different. It all depends on the mix. With the two channel Atmos, you still have the rendering process to place all the channels and objects. This is NOT as simple as a fold down or downmix, there is a lot of math involved and grouping of objects for the best quality or smallest file size etc... It's a totally different world from something like a 5.1/7.1 downmix to 2.0.
    [SOFTWARE] How to play Dolby AC4 IMS/DD+JOC files on Windows/macOS
    https://bugmenot.com/view/sharemania.us
    https://sharemania.us/threads/softwa...-macos.201269/
    How To Decode and Play Dolby TrueHD Atmos on Windows and macOS
    https://audiophilestyle.com/ca/immer...d-macos-r1092/
    Lossless TrueHD Atmos Just Got Much Easier
    https://audiophilestyle.com/ca/immer...-easier-r1170/
    Music Media Helper (Tools for Multichannel Audio & Music Videos)
    https://www.quadraphonicquad.com/for...-videos.22693/
    下載那個 DRP 之後就可以動工了,channel_layout 是 2.0:
    https://gist.github.com/Plazik/e9502...1ea7879aaa3d5d
    等同 MMH 的這個選項:
    https://audiophilestyle.com/forums/t...omment-1262840
    TIDAL 的 Dolby Atmos:
    https://github.com/ebb-earl-co/tidal...-file#features
  2. #462
    音樂資訊的挖掘、傳遞和維持
    在小弟的系統到了滿意的境界後,會常常發出囋嘆,原來這張專輯竟有這種聲音出來。
    最近對這張專輯(ZZT 050901)感到訝異,怎麼2004年的CD,竟有如此多的資訊量!小弟在教會的會堂裡,也因此注意到資訊量的問題。
    在教堂裡有足夠大的空間,管風琴會產生許多反射音。在許多管子(樂器)同時發聲下,除了直接音外,會感受到反射音是由前方以填滿空間的方式湧過來。
    但能全面錄下這些反射音的專輯似乎不多,小弟意外的收了這套管風琴的專輯(應該是我根本不知道有買它)。
    小弟想談的是,資訊量的問題。小弟回想在系統不斷進化的歷程上,是那些因素才能把大量的音樂資訊播放出來?或者是說,真正的把現場的音樂資訊給播出來。
    第一是錄音:要有完整資訊的錄音。這不是廢話嗎?不過小弟發現有完整資訊量的錄音可能少之又少,因為很多資訊在錄音、後製、傳遞過程中被吃掉了!這在後面會提到。
    第二資訊的挖掘:要有ArchQ等級的播放器,配合性能夠強的電腦,才能把好錄音的資訊完整的送出。沒到位的軟硬體,播出的內容就是會少資訊。反之,錄音時的軟硬體也會面臨相同的問題。
    第三資訊的傳遞:電腦播出的資訊要用對的傳遞方式才能以最少損失的方式送進後端。如香堡寶級的同軸數位線,USB 4 線的大頻寬(這也是小弟堅持用的原因)配合 Type-C HUB。而錄音時一樣會遇到。
    第四資訊的維持:這就有點意思了,可能不好解釋,但用過就知道:香堡寶電源線。它是不會掉資訊的電源線,也就是小弟第一次用它時的描述:水把沙子填滿了。但應該是反過來講,用不好的線材,水被倒掉了,剩下沙子。另一個能維持資訊的是DC(AC)接地線,它能維持資訊不被干擾,聲音就不會暈開散掉。同樣的,若錄音時沒用上香堡寶等級的電源線,想必也是會掉資訊。
    最後還有一張CD是資訊量錄好錄滿的,就是教授推的Hortus 226。
  3. The Following 8 Users Say Thank You to sam0402 For This Useful Post:
  4. #463
    最佳化 Linux Kernel Project -- Liquorix Kernel,它對有影音需求的 Linux 系統做了一些最佳化的 patch。
    感到興趣的網友們可以試看看,Linux Journal 上的介紹文如下:
    https://www.linuxjournal.com/content...iquorix-kernel
  5. The Following 3 Users Say Thank You to mybruce For This Useful Post:
  6. #464
    Diretta Host Install Instructions
    https://gist.github.com/famish99/04a...8ce4e77878400d
    基本上就是到這個網站隨意輸入名字和電郵,然後下載兩個檔案:
    https://www.diretta.link/preview/
    MemoryPlayHostLinux_0_123_3.tar.zst
    DirettaALSAdriver_0_123_3.tar.zst
    代碼:
    ./DirettaALSAdriver/
    ./DirettaALSAdriver/driver/
    ./DirettaALSAdriver/driver/alsa_bridge.c
    ./DirettaALSAdriver/driver/alsa_bridge.h
    ./DirettaALSAdriver/driver/Makefile
    ./DirettaALSAdriver/syncAlsa_arm64
    ./DirettaALSAdriver/syncAlsa_arm64_16k
    ./DirettaALSAdriver/syncAlsa_x64
    ./DirettaALSAdriver/logcatch_arm64
    ./DirettaALSAdriver/logcatch_arm64_16k
    ./DirettaALSAdriver/logcatch_x64
    ./DirettaALSAdriver/find_arm64
    ./DirettaALSAdriver/find_arm64_16k
    ./DirettaALSAdriver/find_x64
    ./DirettaALSAdriver/setting.inf
    ./DirettaALSAdriver/diretta_bridge_driver.service
    ./DirettaALSAdriver/diretta_bridge_host.service
    ./DirettaALSAdriver/direttaHost.sh
    ./DirettaALSAdriver/readme.txt
    那是 Diretta Host 的部分,理論上 ArchQ 亦可以把它的 ALSA driver 吧?
    GentooPlayerXfce-UEFI-OpenRc-8.60.img.xz
    https://drive.google.com/file/d/1jsX...LLoJC9rBk/view
    Gentooplayer Target Activation
    https://help.diretta.link/support/di...cs/73000778931
    至於 Diretta Target 的部分則需要付費,否則每次只有 6 分鐘的試用:
    https://gentooplayers.com/Download/
    https://gentooplayers.com/Download_link/
    且看有沒有方法把試用版的功能移植到 ArchQ:
    https://gentooplayers.com/myhtml/Registration.pdf
  7. #465
    Elecom 的線材好像真的比較優秀,不知道這種線材是否適合長芯盛的 U3TT 呢?
    https://kakaku.com/item/K0001185294/
    https://www.elecom.co.jp/products/UC-TV6BK.html
    另外 Elecom 亦於半年前推出了 GaN II Plus 方案的 100W 電供:
    https://kakaku.com/item/K0001592564/
    https://www.elecom.co.jp/news/new/20231212-05/
    https://www.elecom.co.jp/products/ACDC-PD65100BK.html
  8. The Following User Says Thank You to seeteeyou For This Useful Post:
  9. #466
    Avier / Delock 之聲
    日前樂友拿了一條 Sommer USB4 給小弟試試,是德國一家專賣影音設備的產品。編織網線身、金屬接頭,價位與Avier 相近。接在硬碟和HUB之間後,發現性能相當好,解析和透明度佳,算是一條好線,小弟聽來與鐵殼線相仿。
    聽了一段時間後,換回Avier。疑?少了一點數位性能,但音樂的韻味出來了!這是我喜愛Avier USB4的原因,它展現了音樂的情感和韻味,是其它線缺少的。所以Elecom...等,小弟都興趣缺缺了。
    另外,Type-C 的線接頭有正反面之分,轉個面有時聲音會更好,不妨注意一下。
  10. The Following 5 Users Say Thank You to sam0402 For This Useful Post:
  11. #467
    ArchQ ISO Seagate 版
    上個月,小弟突發奇想:ArchQ kernel 用Seagate 硬碟量子加持過後,聲音提升很多,若是整個安裝 iso檔也比照處理結果會如何呢?
    於是手癢就用Seagate 硬碟打包給幾位樂友測試,結果反應很好,回應如後:「空間自然又寬鬆、堂音完全放開不做作。」
    「這張專輯在之前的版本裡面不太容易聽到很好的空間,Seagate的版本則遊刃有餘。」
    而小弟很久沒有重灌,前兩週重灌後也發現聲音細膩且圓潤很多,把空間的殘響也都播放的很完整。
    下載點:ArchQ-202405.iso
  12. The Following 5 Users Say Thank You to sam0402 For This Useful Post:
  13. #468
    abcde 新增專輯編號
    新天新地的樂友常有個習慣:記錄/住CD專輯的編號,這也是方便搜尋的方式之一。
    新版本在編輯CDDB資訊時,會多一項 "DCATALOGNO=",樂友可以自行加入編號;若是抓取Qobuz資料時,也會自動帶入。
    更新方式:先 su
    1.
    代碼:
    wget -P /tmp https://raw.githubusercontent.com/sam0402/ArchQ/main/pkg/abcde-2.9.3-6-any.pkg.tar.zst
    pacman -U --noconfirm /tmp/*.pkg.tar.zst
    2. nano /etc/abcde.conf ,/etc/abcde.conf 第82,83行改成下面的;第86,87行移除 # 也行,原來的加上 #。也可修改次序,成為你喜歡的資料夾名稱格式。
    代碼:
    OUTPUTFORMAT='${ALBUMFILE}.[${ARTISTFILE}].${DCATALOGNO}/${TRACKNUM}.${TRACKFILE}'
    VAOUTPUTFORMAT='${ALBUMFILE}.[${ARTISTFILE}].${DCATALOGNO}/${TRACKNUM}.${TRACKFILE}'
    這樣產生的資料夾尾就會多了專輯編號如下:
    此篇文章於 2024-08-09 12:40 AM 被 sam0402 編輯。
  14. The Following 2 Users Say Thank You to sam0402 For This Useful Post:
  15. #469
    發現軟路由對串流播放的提升可以說是很明顯的
    http://erji.net/forum.php?mod=viewthread&tid=2343233
    小弟昨天把軟路由折騰好,軟路由是一台8代i5的,800元不到收的二手,加一百多塊錢買了根d4 2666頻率的三星16g內存條,電源方面,只用著明緯GSM90和國標機線,插公牛排插,且機身只放在書桌上,試了試通過Airplay聽蘋果音樂,頓時感覺有很明顯的提升,解析、頻寬、結像凝聚度、能量感、流暢度、自然度等等都有提升......可以說是全方位提升了,尤其是低頻,到了更加不轟頭,也更不渾濁,而且有力,泛音也恰到好處的水平。
    在此特別鳴謝本壇用戶“野有蔓草”,小弟是因為看了這位大哥說英特爾8代u的軟路由更好聽才買的,而沒有選擇N100之類的新型號,雖然也沒有對比過,但是現在聽著很滿意,感謝!
    https://www.headphoneclub.com/forum....6&authorid=312
    樹莓派不行的一定要intel i5 i7這級別cpu的軟路由
    越新代的 解析就越好
    另外網卡能上2.5g的最好上2.5G
    至少華碩路由器 2.5G和他的千兆口 聲音差距非常大
    近來看到 ArchQ 的 DHCP 這個 package,假如 sam0402 兄能夠考慮建立一個路由器專用的 ArchQ 版本就太好了:
    https://github.com/sam0402/ArchQ/blo...64.pkg.tar.zst
    雖然 Intel Core 13 代和 14 代的災情嚴重,但是 AMD 的主板也支援 USB4,因此用 40Gbps 的 USB4NET 也不錯。
  16. #470
    引用 作者: seeteeyou 查看文章
    ...恕刪...
    用Linux做路由,是另一個領域了,設定介面、安全、Multi Route...,一堆應用和 ArchQ完全不同。還是直接找現成的Linux 路由distribution比較快。
    小弟會用上DHCP Server是因為3D Labs 和ArchQ 點對點連接時,無法指定ip,只好用啟用DHCP Server來應付,所以別想太多了。
    若是找一個好用的Router distribution,小弟倒是可以試試把ArchQ的kernel 補回Route 相關的功能來替換,或許可以提升Linux 架構的軟路由效能。有空小弟來找看看那個好用。
    另外,ArchQ Kernel 已內建USB4NET,但沒實測過就是了,因為沒硬體可測。
