2014-08-09, 12:52 PM
#661
小高老闆,很高興能在香港音展跟你碰上聊天!保持聯繫!
小饒。![winking](images/smilies/winkn.gif)
![](http://i1363.photobucket.com/albums/r702/icefox_r33bucket/Placeholder%20A/20140808_162733_zpsfptbakpl.jpg)
此篇文章於 2014-08-09 01:33 PM 被 zoltm 編輯。
2014-09-14, 12:22 PM
#662
Pre Audio GL-1101 黑膠唱盤: 零循軌誤差
來自波蘭的作品,讓人耳目一新的設計與創意,從運送包裝之細心就讓人可以感受到主設計者心思之細膩
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8188ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8191ss.jpg)
下方的螺絲是固定唱盤,讓唱盤於運送過程中不會晃動損傷
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8198ss.jpg)
經過約10多分的外箱螺絲拆卸,唱盤本體現身了,可看出這是直切臂的設計
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8205ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8210ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8217ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8219ss.jpg)
注意有三個小鋼珠在手上,作為兩個承盤中間的支撐,這點子真是超酷的
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8220ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8225ss.jpg)
兩個驅動皮帶的轉軸,對應不同電源條件使用
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8229ss.jpg)
VTA調整開關在底部,很像保險箱外面的鎖
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8232ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8237ss.jpg)
check一下轉速
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8242ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8246ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8280ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8287ss.jpg)
這個保固貼紙很有意思
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8300ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8317ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8320ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8394ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8402ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8419ss.jpg)
TECHNICAL DATA:
Granite: sub-chassis
Tone arm: GL-1101
Downforce range: 5-30mN
Optional couterweights: cartridge weights 5-10g
Drive method: belt drive
Motor: synchronous AC
Gilt: RCA , GND
Turntable speeds: 33,33/ 45,11 r.p.m
Speed variance: (+/- 0,4 %)
Wow and flutter: (+/- 0,05 %)
Speed adjustment: manual
Tracking error: 0%
Skating force: 0
Height Adjustment (VTA): (+/- 25 mm)
Arm Height Adjustment range: (+/- 30 mm)
Turntable Platter Height Adjustment: (+/- 10 mm)
Turntable Platter: diameter: 310mm / mass: 3,5kg / height: 45mm
Dimensions: 540mm x 360mm
Weight: 55kg
Power supply: 110V-240V / 60Hz-50Hz
Power consumption: 5W
其實這次到貨有三種型號,同場加碼另一台BT-1301/G
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8178ss.jpg)
![](https://www.my-hiend.com/leoyeh2/2014c/IMG_8432ss.jpg)
2014-10-07, 01:38 PM
#663
2014-10-07, 01:57 PM
#664
我只知道我用的okki nokki約二萬左右
2014-10-07, 02:13 PM
#665
因地區電壓不同:
中國: 海恩音響 18010656888 曾r
![引用](images/misc/quote_icon.png) 作者: benz500
洗唱片幾請報價,所有型號
ˇ
2014-10-07, 03:52 PM
#666
這一台 BT-1301/G 不知道有進了嗎?不知道要多少?
2014-10-07, 03:54 PM
#667
2014-10-07, 04:45 PM
#668
是的..就是那一台..
![引用](images/misc/quote_icon.png) 作者: Leo Yeh
是指上面的那台pre audio唱盤嗎?
2014-10-07, 11:30 PM
#669
目前只有備展一台!!!
![引用](images/misc/quote_icon.png) 作者: nthu800423
是的..就是那一台..
2014-10-07, 11:31 PM
#670
當然有進的,這就是在小高音響開的箱
價格不貴,問一下小高應該會有驚喜
