第2頁,共31頁 第一第一 123412 ... 最後最後
顯示結果從 11 到 20 共計 302 條
主題: 音響兩三事
    Crystal Cable「Arabesque」
    ・Passive two-way design
    ・1.9cm thick facets of cut transparent glass
    ・RAAL ribbon tweeter
    ・3×Audio Technology/Crystal Cable drivers
    ・Crossover frequency:1.6kHz
    ・Nominal impedance:4Ω
    ・Power handling:450-watt RMS
    ・Frequency response:27Hz to 100kHz -3dB
    ・<0.5% THD at 1kHz
    ・Voltage sensitivity:93dB
    ・Max SPLs:115dB
    ・Weight:80kg
  2. #12
    引用 作者: musk 查看文章
    No 532後級應該趕得上11月參展:P
    的確....!!
    比較希望看到的是新5系列的前後級!!
  3. #13
  4. #14
    Esoteric D-03 支援USB與無線傳輸的Kit
    預計2009年上市,價格約USD 1,200
  5. #15
    THORENS 將在倫敦2008 Audio and AV Show全球首度發表Jubilee
    15.09.2008
    Conceived and designed to celebrate the 125th anniversary of the most famous and established name in analogue highfidelity, the Thorens Jubilee turntable makes its debut at the 2008 Audio and AV Show (former London Sound & Vision Show) at the Park Inn Hotel, Heathrow Airport, London.
    From 19th-21st September the Jubilee will be unveiled for the first time ever with the renowned high-end Thorens electronics range. The Jubilee is one of the highest performing turntables ever designed and will be a landmark product in the history of audio. Attendees will be able to experience the Jubilee and Thorens electronics system in room Syndicate 10.
    It’s an experience not to be missed. We hope to see you there!
    http://www.thorens.com/news/latest-n...ow-london.html
  6. #16
    看起來挺精緻的....:*:*:*
  7. #17
  8. #18
    MARTEN
    Coltrane Momento 110,000 euro
    Coltrane Soprano
  9. #19
    Nice move, esoteric...(y)
  10. #20
    類似的商品DCS也已經推出了,Scarlatti Upsampler 售價高達數十萬台幣.
