第102頁,共158頁 第一第一 ... 25292100101102103104112152 ... 最後最後
顯示結果從 1,011 到 1,020 共計 1578 條
  1. #1011
  2. #1012
    His Master's Voice by Michael Sowa
  4. #1014
  7. #1016
    Townshend Audio Excalibur II
    Max Townshend has gone right back to the beginning for this long awaited tonearm. The Excalibur II is essentially the original Cranfield Institute of Technology design, created at the same time as the first Rock turntable in 1979. It’s as different as one would hope with overhang adjustment via the base plate, fixed tracking angle, space-frame outrigger to the damping paddle and separate counterweight and downforce adjusters. The bearings are apparently ball races with enough play to allow the 1000 centisoke oil to get in between every metal to metal contact and allow the arm to effectively float. Price is expected to be around £4,000 and parts have been ordered for a production run, so this time it will happen! Pictured below is the latest Rock 7 complete with Merlin power supply and Excalibure II.
    http://cms.the-ear.net/show-reports/...EKPmo.facebook
  9. #1017
    其實THORENS應該將這些超級藝品重新再製作.
    絕對比現在的產品強上許多!!
  10. The Following 3 Users Say Thank You to 將軍 For This Useful Post:
  11. #1018
    請教師兄..,
    最近小弟剛收了一支 Ortofon MC Anna...
    建議阻抗好像是大於10歐姆都適用...
    請問有師兄對這針有瞭解嗎??哪一個特定阻抗不錯???
    小弟的 phono 是 Audionet PAM 一代跟 J C Verdier Control B...
    謝謝!!~
  12. #1019
    Rui Borges Turntables
    Unico
    Ultimo
    Primo
    Uno
  13. #1020
    引用 作者: fyl0206 查看文章
    請教師兄..,
    建議阻抗好像是大於10歐姆都適用...
    謝謝!!~
    只要不是升壓器,30~100皆可.
    個人偏向90~100,但要看你個人的生理和器材搭配來決定!!
  14. The Following User Says Thank You to 將軍 For This Useful Post:
