第5頁,共5頁 第一第一 ... 345
顯示結果從 41 到 48 共計 48 條
  1. #41
    LUMIN iPAD APP 1.2.4 is released today.
    New in this version: Support for untagged music.
    Previously, untagged music was not shown in the LUMIN App and could not be played.
    This might include some music formats that don't support tagging such as DFF or WAV file.
    MinimServer puts all untagged music into a folder called [untagged]. Now LUMIN App will create an album called [untagged] and place the contents of this folder within it so that it can be browsed and played.
  2. #42
    預設 marantz na 11s1
    請問lumin與 marantz na 11s1相比,聲音上面的差異大嗎?
  3. #43
    沒聽到marantz
    就以前的印象 兩者聲音走向會有很大不同
    lumin動態大 解析能力很強
  5. #44
  6. #45
    住址
    A, A
    Polish (of course in English) review of Lumin: http://soundrebels.com/artykuly/rece...in-english-ver
  7. The Following User Says Thank You to Marcin Olszewski For This Useful Post:
  8. #46
    LUMIN Firmware v4.0 is available now.
    New feature: LUMIN USB Server.
    Connect a USB disk or flash drive to any LUMIN USB port.
    "LUMIN USB Server" will be available as a Music Library.
    Browse USB Server in standard UPnP mode using latest LUMIN App or any UPnP Controller.
    Play music on the connected LUMIN player, or on any UPnP Renderer on the network.
    Supported audio file formats are WAV, AIFF, FLAC, ALAC, MP3, AAC, DFF, DSF and DoP files.
    LUMIN USB Server will stop and disappear when USB storage is removed from LUMIN.
  9. #47
    LUMIN is now available in Black anodised finish.
    It comes complete with a matching black anodised PSU.
    Due to the extra manufacturing processes needed, LUMIN Black is special order only. Please contact your retailer for costs and lead time.
  11. #48
    LUMIN App 2.0.3 is available on iTunes now. New feature: Search Filter Mode When Search Mode > Filter is selected from the settings menu, the LUMIN App will now filter search results in realtime as you type. As before, please select the appropriate tag from the tabs before searching. https://itunes.apple.com/us/app/lumin/id524332800
