第33頁,共52頁 第一第一 ... 23313233343543 ... 最後最後
顯示結果從 321 到 330 共計 516 條
  1. #321
  2. #322
    Opals
    System overview
    Opals are fully 4-way active integrated monitor systems that can be applied to a range of applications including domestic, studio monitoring, commercial and PA. Designed to give the highest fidelity performance technically achievable, the Opal systems are also crafted to suite most environments. Custom Opal systems can be consigned for more specific applications and environments.
    All Opal systems are supplied with in-built solid-state amplification and internal 4-way active crossovers. For those wanting a sweeter, warmer experience, fully 4-way active valve towers can be added.
    The Opal system structure is based on a 3-way center speaker system consisting of a 2in compression driver for upper voice, ribbon or compression tweeters for harmonics and 12in flared cabinet or front loaded 15in for lower voice. Completed as a 4-way with 2 x 15in, 18in or 21in bass speakers.
    Lenard 4-way active integrated sound systems create a 3D, virtual reality, fully dynamic experience. The effect is breathtaking. Hearing complete clarity and detailed separation, as though the musicians are actually present.
    The Classic Black Opal system cabinets are crafted from the finest Australian hardwoods. The exponential horns are CNC machined from solid 100 year old redgum. This system is equipped with two valve amplifier towers.
    The Classic Black Opal system can be replicated as a Custom Opal system.
    The way we hear the natural world
    4-way active is the application of dividing the music spectrum into 4 registers: bass; lower voice; upper voice and harmonics. Fully 4-way active is when the music signal is divided by an electronic cross-over prior to it being sent to the dedicated amplifiers and speakers. This allows for an experience as we hear sound in the natural world.
    4-way active achieves every criteria without compromise.
    Valve Amplifiers
    Overview
    Each amplifier cabinet consists of five 100 Watt Ultra-linear valve amplifiers. The amplifiers are mounted vertically. There is a separate amplifier for each speaker. The 2 two lower amplifiers drive the bass speakers and top amplifiers drive the higher frequency speakers; the order is logical to follow.
    The amplifiers for the cone speakers (bass and lower voice) are in class AB which enables 100 Watts of power to be achieved. However the amplifiers for the upper voice 2in compression driver and tweeter are in class A which limits power to 40 Watts.
    The efficiency of the compression driver and tweeter is approx 100 times greater than the lower frequency cone speakers and only requires 1/100 the power to achieve the same level.
    The high frequency drivers are very sensitive to detail and it is essential for the amplifiers to be as close to class A as possible to achieve the lowest distortion figurers.
    The 4 four way active crossover is at the top of the cabinet and the controls easily accessible. The crossover frequencies are calibrated to achieve the best performance from the speakers.
    The level controls of the crossover are calibrated for free field which means zero room reverberation. The controls can be easily re-adjusted to give the best performance to suit the room environment and music.
    The crossover is Linkwitz-Riley 4th order time aligned
    官網 http://www.lenardaudio.com/opal.html
  3. #323
    Z:Axis Audio
    Ariya-Sacca ~ EIGHT
    Specifications:
    Available in Black Maple shown, or Wenge.
    ‘MEDS’ damping & isolation technology in each shelf.
    Adjustable centre shelf height.
    Each Shelf is individually isolated from the frame by Silicon Gel inserts.
    Adjustable feet for levelling.
    Weight is approx 180 Kgs.
    http://zaxisaudio.com
    £7600
    Available in Black Maple or Wenge
    Adjustable center shelf height
    Adjustable feet for leveling
    Design & Construction
    Acrylic, well regarded as one of the best micro-vibration isolators available, is used as the main support surface on all layers, and incorporates our unique ‘Mass Energy Dissipation System’ (MEDS©).
    Most other racks work to isolate the component being supported, whereas ours not only isolates, but is also designed to dissipate residual energy (transformer vibration) from the audio component. This energy can be highly detrimental to ultimate sound quality if left within each component, so it therefore became necessary to dissipate as much as possible into a multi layer system of a custom ‘micro metallic particle’ via the 25mm acrylic top surface. Further isolation occurs at the base of the ‘tray’ shelf by a proprietary soft compound elastomer (30 duro) designed to isolate from all frequencies above 9Hz. This is then all contained in a Valchromat & hardwood base.
    Our ‘mass energy dissipation system’ is the result of significant testing of media & materials, and the results really surprised us. We were aware that residual energy, caused by transformers literally vibrating at micro level inside the component (producing an audible hum), would degrade the signal passed through each component, but the result of connecting that vibrational energy to a micro metallic particle mass surprised us all.
    Configurations
    Single width, 3 shelf, Wenge or Black ~ Ariya-Sacca THREE
    Single width, 4 shelf, Wenge or Black ~ Ariya-Sacca FOUR
    Double width, 3 shelf, Wenge or Black ~ Ariya-Sacca SIX
    Double width, 4 shelf, Wenge or Black ~ Ariya-Sacca EIGHT
    Triple width, 3 shelf, Wenge or Black ~ Ariya-Sacca NINE
    Single width, Amplifier stand, Wenge or Black ~ Ariya-Sacca ONE
    Shelf sizes are approx 575mm wide x 475mm front to back.
    Also to be available will be isolation plinths designed to dampen residual energy in floor-standing loudspeakers. Using the same construction techniques as the shelves, these plinth’s will help to reduce coloration from the actual speaker enclosure, resulting in improved definition, clarity & dynamic ‘slam’ when used on a suspended or wooden floor.
    Each base is fitted with either 3 or 4 height adjustable feet for perfect levelling and rake angle fine tuning.
    Weight is approximately 22kgs each.
  4. #324
    Kyron Audio Gaia Dipole Loudspeaker System
    Loudspeaker Type: 3 Way, DSP Controlled Active Dipole Loudspeaker System
    Frequency Response Range: 20Hz to 30KHz
    Polar Response Pattern: Figure 8 response
    Tweeter: 4x 1 inch ring radiator with patented symmetrical drive motor Midrange 4x 7 inch neodymium dipole mid-woofer
    Woofer: 12x 12 inch dipole long throw woofer
    Preamplifier: Inputs S/PDIF, AES/EBU, Balanced XLR, Unbalanced Eichmann RCA 6x Digitally controlled analogue volume control
    Digital Signal Processing by DEQX™: High Definition Speaker Correction Linear Phase Crossovers
    Advanced Room Measurement and Correction
    Amplification: High – 2x 200 Watt amplifiersMids – 2x 500 Watt amplifiersSubs – 4x 250 Watt
    amplifiers Total amplifier capability including headroom – 5000 Watts RMS
    http://www.kyronaudio.com.au/
    此篇文章於 2013-07-15 04:04 PM 被 Ted Chen 編輯。
  5. #325
    Audiophile Technology Theoreme 4 and Amplitude 4
    €6000
    Specifications
    - Inputs: 4 unbalanced inputs
    - Outputs: 2 unbalanced outputs
    - Input Sensitivity: 280 mV
    - Frequency response: 10 Hz to 150 kHz ± 3 dB
    - Gain: 11 dB
    - Dimensions: 430 mm x 135 mm x 355 mm
    - Weight: 9 kg
    €7000
    Specifications
    - RMS Power: 2 x25 W into 4 Ω or 8 Ω
    - Input Sensitivity: 560 mV
    - Input impedance: 220 kΩ
    - Frequency response: 10 Hz to 80 kHz @ - 2 dB
    - Weight: 19 kg
  6. #326
  7. #327
  8. #328
  9. #329
    Abendrot Audio STUTE True 10MHz Rubidium Master Clock
    The fundamental product of Abendrot Audio, a rubidium master clock placed in a beautiful aluminium cabinet, finally came to completion. STUTE is a master clock of supremacy designed for high-end digital audio system as well as a fruition of state-of-the-art technology of space development. Having the potentiality only can be actualized by a unique adjustment circuit, this rubidium oscilator with accuracy of 1 second in 1,000 years enables floating satellites to travel through several light years correctly. STUTE by Abendrot Audio, designed by the few existing professionals well versed in this secret technology, is the only genuine rubidium master clock. It is an ultimate collection for your audio system as well as an invitation to the deep, profound universe of sound.
    Specs
    Output:
    Output frequency 10MHz sine wave
    Output channel 2 output
    Output connector BNC female
    Amplitude 1V peak to peak 50ohm
    Accuracy at shipment ±5×10-11
    Warm-up time < 10 minutes ( time to lock and practical accuracy)
    Electrical:
    Input voltage AC100V 50/60Hz
    Maximum wattage 120W
    Environmental:
    Operating temperature 5C to 35C
    Storage temperature -10C to 65C
    Magnetic field < 2x10-10 for 1 Gauss field reversal
    Relative humidity 95% (non-condensing)
    MIscellaneous:
    Size 440mm X 420mm X 90mm (HWD)
    Weight 11 kg
    Warranty 3 years
  10. #330
    Abendrot Audio
    Abendrot Audio is a high-end audio company established in 2010 by the world’s most prominent engineers from the aerospace industry and the leading designers of the audio industry. “What will the shape of supreme stereo audio reproduction be like?” Here we provide an answer to this infinite question, a centennial milestone in audio history, products developed by a master engineer with more than 30 years of experience in designing top quality circuits near the boundaries of human intelligence. We are launching these fruit of timeless audio technologies and pursuit for perfection which fulfills the dreams of supremacy-seeking audiophiles. Abendrot Audio products are designed by professionals from Japan and the UK, manufactured carefully one by one alike the ancient Japanese samurai swords and British knight armors which are hightened to the levels of art.
    SPEC
    Output:
    Warm-up time < 10 minuites ( time to lock and practical accuracy)
    Electrical:
    Environmental:
    Operating temperature 5℃ to 35℃
    Storage temperature -10℃ to 65℃
    Magnetic field < 2×10-10 for 1 Gauss field reversal
    Relative humidity 95%(non-condensing)
    MIscellaneous:
    Weight 11 kg
    Warranty 3 years
