顯示結果從 1 到 6 共計 6 條
    預設 Ruark Audio R7 aims to reinvent the radiogram
    靈感來自60年代,新的R7旗艦擁有Ruark Audio的radiogram設計,再加入無線串流,成為all-in-one的2.1聲道系統。
    比起以往較小型的產品,R7的設計為客廳使用。用核桃木、鋁、玻璃製成的R7支援aptX藍芽、DLNA、DAB、FM、網路和優良的CD player。
    2.1的揚聲系統由兩個新製程5.5吋的雙同軸單體,包含高音和中低音單體配合一個8吋的超低音。AB類輸出,和高容量電源,提供了160瓦的功率,兩個類比輸入,一個數位光纖和數位同軸輸入,也可連接智慧型手機。
    Take a look at the Ruark Audio R7, Ruark's £2000, modern-day take on the iconic radiogram.
    Inspired by 1960s design, the new R7 flagship model in the Ruark Audio range brings the radiogram design bang up to date, adding wireless streaming to an all-in-one, 2.1 stereo system.
    Better known for more compact products, such as the Ruark Audio R4i and the R1 MkII radio, the R7 has designs on a larger chunk of your living room.
    Made from real walnut, aluminium and glass, the R7 supports aptX Bluetooth, DLNA streaming thanks to integrated wifi, DAB, FM and internet radio and good ol' CD playback.
    The 2.1-speaker system is powered by two newly developed, 5.5in dual concentric drivers, with the tweeter mounted centrally within the mid-bass driver, and an 8in long throw subwoofer.
    Ruark Audio's own Class A-B amplifiers and high capacity power supply complete the audio system, which delivers 160 watts of power.
    Connections come in the form of two stereo analogue inputs, plus one digital optical and one digital coaxial input. There's a "charge port" for smartphones and tablets, too.
    There's a fresh take on Ruark's familiar RotoDial remote control, plus a high contrast fluorescent display.
    The Ruark R7 comes with spindle legs if you want the system to stand loud and proud in your room, or you can use the supplied puck feet for mounting the R7 on a sideboard or AV rack (provided it can make take the 30kg weight).
    Due for release this Autumn, the Ruark Audio R7 comes with a £2000 price tag. Let us know what you think in the comments below...
    R7 features
    DAB, DAB+ and FM Tuner with RDS
    Ultra black, high contrast fluorescent display
    Dual aerial inputs
    Comprehensive Internet Radio functionality
    Slot loading CD player plays CD-Audio, MP3 music disks
    Full Wi-Fi capability allows wireless networking and music streaming
    Bluetooth with aptX allows CD quality direct streaming with compatible devices
    Charge-port for charging smartphones and tablets
    2 × 5.5” dual concentric stereo drivers
    1 × 8” long throw subwoofer
    160 watts nominal power output
    Adjustable EQ settings
    Enhanced 3D sound processing
    Stereo headphone output
    Dimensions (without legs): H175 × W1000 × D400mm
    Weight: 30kg
    Supplied with spindle legs for free standing mode or puck feet for mounting R7 on existing sideboard or AV cabinet
    Optional TV mount (available 2014)
    Rich walnut veneer cabinet and black lacquer legs
    Designed, developed and engineered in Britain
    SRP UK: £2,000
    原廠網址 http://www.ruarkaudio.com/
  2. The Following 2 Users Say Thank You to Ted Chen For This Useful Post:
    最近很流行這種造型/產品的,放在家裡擺著也很好看!
  4. The Following User Says Thank You to Morrislee For This Useful Post:
  5. #3
    真想在辦公室放一台.......
  6. #4
    台灣已有代理商了,不知道聲音如何,真想買一台放在臥房!
  7. #5
    上星期五有順便去發表會看一下, R7的外觀做工不錯, 遙控器手感也有水準
    但聲音水準是床頭音響等級的
    線材出孔在後方故連接時櫃體無法緊靠牆也是個遺憾
  8. The Following User Says Thank You to BHMzero For This Useful Post:
  9. #6
    如果聲音水準是床頭音響等級的,那就殘念了........
    定價也要NT$148,000元
