第30頁,共52頁 第一第一 ... 20282930313240 ... 最後最後
顯示結果從 291 到 300 共計 516 條
  1. #291
    The Pivetta Opera Only project
    No, when you look at the pictures, it‘s not Captain Kirk‘s oversized ion hairdryer on the
    Starship Enterprise, nor is Dr. Emmet Brown‘s latest model of the flux capacitor from the
    time machine!
    This project was created all thanks to the Italian, Andrea Pivetta and his passion for
    music. Andrea Pivetta is an Italian electronics designer who has worked with a diverse
    range of Italian companies in different areas for over 20 years. When the imagination of
    an electronics designer becomes overpowering and finds a way for these wild fantasies
    to be realised, the result is exactly what the visitors of this year‘s HIGH END in Hall 4 will
    experience live and in colour.
    On the one hand, his latest “creation” is certainly a culmination of his more than 20 years
    of working in electronics design, but it also reflects his desire to link art and technology
    closely together. What visitors to HIGH END 2013 experience, is an amplifier, which can
    quite literally be “walked in”. We jokingly spoke of “walk-in” amplifiers back in the seventies
    with the large, massive and monstrous American amplifiers, and this is now a reality in
    Munich. Many of you will be reminded of the saying that there‘s a fine line between genius
    and madness, but where else would an exhibit like this be displayed, if not at the HIGH
    END?
    The huge dimensions of the Pivetta Opera Only are not just due to the technical reasons
    of being able to achieve 160,000 watts, but also come from the desire to create something
    that is very special and unique from a visual point of view. The Pivetta Opera Only reflects
    an expression of design creativity (friendly paraphrased), supplemented by high-quality
    audio technology in its interior. Its special characteristic features are: style, form and design.
    The external structure is made of aircraft-grade aluminium, the openings or connections
    are not visible from the outside, and if he or it is switched on, we feel the “Phoenix
    from the ashes” equivalent – the spectacular act of awakening, which you just have to
    experience personally.
    Initially the 6-channel amplifier is a twelve-sided cylinder, but its structure completely
    changes once the power is switched on. It divides itself into six separate sections to reveal
    all the electronics at a glance. You suddenly have the impression that you are looking at
    space technology. The electronics can also be converted into two identical mono blocks
    if required. As you can‘t always find a power supply which provides 160 kW, a bi-power
    system was installed so that the amplifier can also be operated with an output of 3 kW. All
    the components were made entirely in Italy.
    A sum of over €1,500,000 has been invested in the construction of this work of art. The
    product is currently not for sale, by the way.
    The Pivetta Opera Only is on show at the HIGH END 2013 in Munich for the first time.
    Come and be enchanted and visit the premiere of this extraordinary creation on site, live
    and in colour.
    Technical data:
    Power input: 230/400V 50/60 Hz 800 A
    Power supply: 6400 amps – 1,000,000 mF
    Power output: 6 x 20,000 watts RMS Class A
    (max. total power output: 160,000 watts)
    Dimensions:
    1250 x 1900 x 1250 mm (width x height x depth, closed)
    1850 x 2500 x 1850 mm (width x height x depth, open)
    Weight:
    1,500 kg
    Housing:
    No visible connection boxes or inputs, aeronautical, high-grade NECE treated aluminium.
    Dual mono block connection possible.
  3. #292
    AEDLE
    VK-1 CLASSIC EDITION
    ABOUT
    VK-1 Classic Edition combine minimalistic and refined design with high-definition custom made titanium transducers. 500 units available for second batch. Shipping on May 6th 2013.
    PRICE :
    EU Customers: 320 EUR tax included
    Non EU Customers: 270 EUR / 350 USD tax excluded
    More information about Shipping & Taxes in our FAQ Section.
    IN THE BOX
    3.5 mm detachable cable + Microphone
    Additional 3.5 mm Audio Cable
    Aedle Serial Number Metal Card
    Travel Pouch
    Airline adapter + 6.5 mm adapter
    Booklet
    http://www.aedle.net/
  5. #293
  6. #294
    LessLoss Laminar Streamer Direct Drive SD Card Player
    Plays any .wav or .aiff file from FAT32 formatted SD cards. About the size of a postage stamp, a Secure Digital High-Capacity (SDHC) card is a flash memory device that can hold up to 32 gigabytes (GB) of data. These cards are a form of removable memory that can be used with many different digital devices, including camcorders and computers.
    44.1 kHz–192 kHz
    Plays any standard sampling rate files, from 44.1 kHz through 192 kHz files.
    16/24 bit
    Plays 16 or 24 bit files at any standard sampling rate.
    Instant SD Card Playback
    Instantly recognizes the SD card. Boot time is less than 0.2 seconds. Nothing to configure, ever. No buffering, synchronicity, latency, or compatibility issues, ever. Nor viruses. Just plug and play the perfect audiophile stream, and keep your pristine audio off the noisy grid.
    Essential Information Display
    Small screen displays folder names, file names, sampling rates, absolute phase polarity, playback mode, and time.
    Functions
    Screen functions include: text scroll animation stop and Pure Laminar mode (screen off).
    Phase Polarity Switching
    On-the-fly 100% digital realm absolute phase polarity switching during playback.
    Pure Laminar Mode
    In Pure Laminar mode: screen data, active position monitoring, and back-light are all disengaged. The sole active operation remains Direct Drive clock-to-data pairing. The Direct Drive OS runs off of the active precision audio clock.
    Playback Features
    Playback features include: Pure Laminar mode, phase reversal during playback, repeat track, repeat folder, repeat SD card, play track and stop, play folder and stop, play SD card and stop, random track, fast forward while playing, rewind while playing.
    Expansion Port
    Optically decoupled expansion port for future remote control functionality without introducing any EM interference to the subtle audio streaming process. No onboard IR or Wi-Fi sensors.
    Outputs
    S/PDIF output on RCA;
    AES/EBU output on XLR;
    I2S output on 5-pin connector.
    Microvibration Control
    Superlative microvibration control through precision milled solid steel and Panzerholz construction.
    Dimensions & Weight
    423.2×400×160.5 mm (16.66×15.75×6.32 inches), approx. 24 kg (53 lbs).
    Price: to be announced.
    http://www.lessloss.com/laminar-stre...yer-p-207.html
  7. #295
  8. #296
    Norge highend audio products.
    Our new baby....THE NORGE PRE/POWER 1200 PRO Combo.@ only Rs.22,500/- THD: 0.04% output 150 watts per channel.
    http://www.norgeaudio.com/
  9. #297
  10. #298
  11. #299
  12. #300
