第44頁,共59頁 第一第一 ... 34424344454654 ... 最後最後
顯示結果從 431 到 440 共計 581 條
  1. #431
  2. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
  3. #432
  4. The Following User Says Thank You to chsiang For This Useful Post:
  5. #433
    等了很久,gryphon 器材終於入住音響室了,下週搬家就可聽啦。
  6. The Following 3 Users Say Thank You to bmw330ci For This Useful Post:
  7. #434
    Gryphon Audio Designs • Trident Loudspeakers
    Semi-active speakers that excel at "bringing the performance home."
    by Roy Gregory | February 5, 2013
    artially active speakers, once so rare, are becoming increasingly common, not least because the formula offers (and often delivers) very real benefits. Installing amplifiers to drive the bass leg in a three-way design promises to increase low-frequency extension from a given cabinet, improve bass control by direct-coupling the driving amp to the drivers, and create the possibility for low-frequency adjustment and room compensation. In addition, there are fringe benefits to be enjoyed by the system’s main amplifier, which has a far easier time of it, now that it doesn’t have to answer the demands imposed by heavy low-frequency transients. So, it should be a win-win situation, from both the designer's and owner’s point of view, right? You’d think so, but in audio, nothing is quite what it seems, and even surefire success strategies can easily be undermined by poor execution -- or misapplication.
    http://www.theaudiobeat.com/equipmen...on_trident.htm
  8. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  9. #435
    上禮拜有一天, 拿起Mirage遙控器, 突然發現怎麼長毛了!?
    原來, 是電池漏液了! 電解液流出來乾掉結晶........
    想換電池卻發現......應該是電解液有漏進螺牙裡咬住螺絲了, 居然崩牙了......只好送修!
    代理商亞柏利檢查之後, 發現機板有點問題, 必須要更換, 年關將近, 當然也是來不及跟原廠調來機板了,
    亞伯利主動提議借我一支備用的遙控器, 讓我等待的期間還是可以好好聽音樂,
    當然, 沒了遙控器還是能用, 只是不太方便而已拉~~~
    總之, 跟各位分享只是想讚揚一下亞柏利的售後服務, 亞柏利大可以只是幫我維修而已, 但是他們更貼心了想到了我的不方便, 主動提出解決辦法,
    小問題就是如此了, 萬一日後遇到更大的問題, 有沒有良好的售後服務所造成的差異會更大,
    這也是一種隱性的成本, 很多人或許沒有仔細去想到這一點.....
    或許用家一輩子都不會遇到我這樣的狀況, 但是一旦遇到, 就會知道當自己是位被用心對待的客戶時, 整個送修的經驗會有多大的不同!
    亞柏利真得是很好的代理商, 值得大家支持!
  10. The Following 10 Users Say Thank You to chsiang For This Useful Post:
  11. #436
    希望自己的Gryphon綜擴遙控器不要遇到漏液,但是聽音樂時,音量調整也沒那麼頻繁,應該是頗難將電力耗盡,看來只能自己算時間來換電池,不過代理商的服務如此週到,忐忑不安的心也就比較平靜了!
  12. The Following User Says Thank You to hidoson For This Useful Post:
  13. #437
    遙控器這種低耗電量的電器,盡量使用碳鋅電池即可避免漏液的問題
  14. The Following 3 Users Say Thank You to jackiex For This Useful Post:
  15. #438
    引用 作者: jackiex 查看文章
    感謝jackiex提供的訊息,目前遙控器的電池從買入Gryphon後就沒打開換過,還不知道裡面用的是什麼電池,等時間差不多了,就給他換上碳鋅電池來一勞永逸。
  16. #439
    春節試聽線材,MAGNUS PRIME 喇叭線竟然放不進我GRYPHON 後級,殘念。
    我覺得吼~~~~
    不論要買甚麼牌子, 喇叭線再往上一個等級, 真的, 日後比較不會成為系統的瓶頸......
    原因, 我自己的心態是......喇叭線好貴, 如果不跟系統這種"大條"的一起開下去.......單獨買真的覺得很.......orz
    您參考看看瞜~~~
  17. #440
    我也遭遇過同樣的問題
    也受到亞柏利同樣貼心的禮遇服務
    音樂是我的信仰我的宗教
