第77頁,共80頁 第一第一 ... 27677576777879 ... 最後最後
顯示結果從 761 到 770 共計 797 條
  1. #761
  3. #762
    這個月iphone5會正式發表嗎???但四吋感覺不很吸引人.......
  4. #763
    http://venturebeat.com/2012/08/28/ap...rplay-upgrade/
    Apple is planning some big changes for how people listen to music via iOS devices, according to a Telegraph report.
    At its rumored Sept. 12 press event, the company is planning to announce a new feature update called “AirPlay Direct,” which allows you to stream music from your iOS devices wirelessly to speakers without the aid of a Wi-Fi connection. Currently, the Airplay feature only allows you to stream media from an Apple device (iPod Touch, iPhone, iPad, and some Macs running Mountain Lion) to Airplay speakers or an Apple TV while on the same Wi-Fi network.
    The “AirPlay Direct” upgrade would simplify streaming media for iOS users, since they won’t have to worry about being on the same network as an Airplay device. The new feature could also lead to some quality improvements, though Apple’s Airplay is already better quality than Bluetooth streaming for music (which has to compress the dynamic range of audio).
    The company is likely pairing the new Airplay functionality with the new smaller dock connectors rumored to be in future Apple devices, the Telegraph report indicates. And while speaker accessories with the old dock will be much less useful, even with the rumored adapter to support the new dock connector, upgrading to a new one could be more palatable with the AirPlay Direct upgrade.
  5. The Following 2 Users Say Thank You to 小余 For This Useful Post:
  6. #764
    預設 出現了! 蘋果宣布「iPhone 5」發表會就在12日
    眾說紛紜的蘋果新機發表會日期終於塵埃落定!稍早由蘋果對外證實了發表會的訊息,本次邀請函一如往常秉持蘋果的簡約風格,除了明顯的數字「12」象徵了 9 月 12 日的發表會日期,下方宛如倒影般秀出的「5」雖然沒有明示,但似乎在預告「iPhone 5」的降臨?
    各界原本猜測蘋果可能會按照近年來的習慣,選在 10 月發表下一代 iPhone,但隨著時間推進,陸續有消息指稱蘋果會提前在 9 月舉行,一直到前陣子傳出蘋果發表會日期已經定案後,「9 月 12 日」瞬間成了呼聲最高的發表日期候選,現在則是有來自蘋果官方消息證實,是的!蘋果要在 9 月 12 日舉行新機發表會!
    根據外電媒體取得的蘋果邀請函內容,這場發表會地點選 在舊金山的 Yerba Buena 藝術中心,也是過去「發表歷代 iPad 的場地」。按照先前傳聞所指,蘋果應該會在這場發表會上「iPhone 5」,以及 7 吋的 iPad mini。這場發表會將於 9 月 12 日早上 10:00 舉行,約為台灣時間 9 月 13 日凌晨 1:00。
    http://www.nownews.com/2012/09/05/339-2851310.htm
  7. The Following 2 Users Say Thank You to Ted Chen For This Useful Post:
  8. #765
  9. The Following User Says Thank You to 小余 For This Useful Post:
  10. #766
  12. #767
    推薦用HRS
    DPII-05545 壓在macmini上面!!!
  13. #768
    遜掉了!今天發現iphone喇叭一邊沒聲音?
    查了一下才知道!原來只有mono沒有stereo的單邊設計
    http://www.ezplay.mobi/?p=10192
  14. The Following User Says Thank You to 小佐 For This Useful Post:
  15. #769
    這東西挺有趣的....
  16. #770
    media:connect($180)
    https://itunes.apple.com/tw/app/medi...335036887?mt=8
    iphone+NAS試過AAC, MP3, Apple Lossless 可以顯示專輯封面
    QMobile(免費)
    不支援Apple Lossless ,無法顯示專輯封面,只在播放時顯示
  17. The Following User Says Thank You to wu For This Useful Post:
