想買後級推 Penaudio Cenya
hi ,小第看中了
densen b-330 and simaudio moon 330A 後級
兩部的出力也是240W /4Ω
有沒有用家可給些意見? thx
DENSEN B-330
POWER AMPLIFIER
DESCRIPTION
The B-330 is a direct descendent from the top of the line B-350 monoblocks.
The B-350 monoblocks act as the internal reference at Densen.
Basically, the B-330 is a stereo power amp based on the B-350's technology, and uses the distinct monoblock cabinet with its recessed heatsinks as the basis for an extremely affordable reference power amplifier.
The B-330 contains several exciting features. Externally on the backpanel there is a switch to adjust the gain, so it either works perfect with a traditional preamp or with a CD with variable output.
There is also a D-Sub15 connector, allowing for Link connection to other Densen products, and for auto power on/off.
The D-Sub connector can be daisy-chained in multiroom systems.
B-330 is also prepared for the SAXO electronic crossover. This is done by mounting the crossover internally in the B-330 in a socket. The SAXO crossover will fit all passive speakers on the market.
SPECIFICATIONS
Power output in 8 ohms: 2 x 120W
Power output in 4 ohms: 240W
Power supply size: 750VA
Storage capacity: 110.000uF
THD + Noise @ rated output: Less than 0.1%
Weight/shippingweight: 15/17 Kg
Product dimensions (WxDxH): 440x310x64mm
MOON SERIES
330A Stereo Power Amplifier
Significant Design Features:
· 12 Volt Trigger input and output
· A "no overall feedback" design resulting in genuine real-time amplification, a more accurate
musical reproduction with respect to tonality, virtually non-existent intermodulation distortion
and the elimination of common phase errors resulting from feedback
· An oversized power supply
· Custom proprietary toroidal transformer design with lower magnetic, electrical and thermal
loss, yielding an improved power transfer and lower regulation factor. The result is increased
current speed and better dynamics
· Balanced differential circuitry
· Class A output to 5 watts for greater efficiency
· Proprietary MOON Bipolar output transistors with unprecedented gain linearity resulting in
improved bass response and even more accurate sonic reproduction
· A high damping factor yielding superior musical dynamics, improved signal speed and refined
timbre accuracy
· RS-232 port for (i) full unsolicited bidirectional feedback and (ii) firmware updates
· PCB w/ pure copper tracings & gold plating that yields low impedance characteristics
· Extremely rigid chassis construction to minimize the effects of external vibrations
· Accurate matching of the very finest high quality electronic components in a symmetrical
circuit design
· Designed to be powered up at all times for optimal performance
· Low operating temperature to ensure a longer than normal life expectancy.
| MOON 330A Power Amplifier Specifications |
| Type |
Solid State |
| Configuration |
Stereo |
| Power Supply Transformer |
400VA |
| Power Supply Capacitance |
85,000µF |
| Class Of Operation |
A/AB |
| Single-ended Input |
RCA - 1 pair |
| Balanced Input |
XLR - 1 pair |
| Input Device Type |
J-FETs |
| Input Impedance |
47,500 Ω |
| Input Sensitivity |
800mV RMS |
| Output Device Type |
Bipolars - 4 per channel |
| Output Binding Posts |
5-way / Gold-plated / Shielded |
| Output Power @ 8 Ω |
125 Watts |
| Output Power @ 4 Ω |
250 Watts |
| Output Power @ 2 Ω |
325 Watts |
| Output Power - Bridged Mono |
400 Watts |
| Frequency Response |
10Hz - 125kHz (+0/-3dB) |
| Output Impedance |
0.02 Ω |
| Damping Factor (static) |
400 |
| Gain |
31dB |
| Signal-to-noise Ratio |
> 100dB @ full power |
| Maximum Output Voltage |
40 Volts |
| Slew Rate |
42V/µs |
| Maximum Current - Peak / Continuous |
28 amperes / 13 amperes |
| IMD |
Unmeasureable |
| THD @ 1 watt / @ 125 watts (20Hz-20kHz) |
< 0.02 % / < 0.05 % |
12 Volt Trigger Operation
Direct Logic (0V = off, 12V=on) using a
1/8" mini-jack with an input impedance of
1K Ω and current requirement of 12mA |
| Available Faceplate Finishes |
Black and Silver |
| Power Consumption @ idle |
36 Watts |
| AC Power Requirements |
120V / 60Hz 240V / 50Hz |
| Fuse Replacement - 120V |
6A long fast blow |
| Fuse Replacement - 230V |
3A long fast blow |
| Shipping weight |
33 lbs / 15 Kgs |
| Dimensions (W x H x D) |
16.9 x 3.5 x 14.0 in. (42.9 x 8.9 x 35.6 cm.) |
Features & specifications are subject to change without notice. |
DENSEN..聲底乾淨 透明度高........DENSEN B-330+1票
