第277頁,共355頁 第一第一 ... 177227267275276277278279287327 ... 最後最後
顯示結果從 2,761 到 2,770 共計 3546 條
  1. #2761
    引用 作者: kingyan 查看文章
    hi c7c hing, 我明天應會再去睇
    Sorry, sorry, 而家至睇到。
  2. #2762
    Rockport 最新工廠專訪
    Rockport Technologies Features Summary
    Introduction to Rockport Technologies
    In the northeast corner of the United States you'll find the state of Maine, which is one of six states that make up New England. If you look up "History of Maine" on Wikipedia.org, you'll find many interesting facts, most of them revolving around the American Revolution and the War of 1812 -- history buffs undoubtedly love the place. But absent from the Wikipedia entry are two interesting facts that we learned during our visit on August 10, 2012. The first is that the state lays...Read More
    Rockport Technologies' Production and Testing
    All Rockport Technologies speakers are designed in-house by Payor using a combination of computer-based modeling, acoustical and electrical measuring, and listening. Payor also designs almost all of the speakers' individual parts (including little things like the crossover capacitors!). But many of the specialized manufacturing tasks, including cabinet making and finishing, are the work of highly skilled local craftsmen, a number of whom also work in the high-end marine industry....Read More
    Rockport Technologies' Listening Room
    One of Rockport Technologies's goals is to make best-in-class loudspeakers. To do so, they back it up with an in-factory listening room that is undoubtedly one of the finest that you'll find at any company. The room, like almost everything else at Rockport Technologies, was designed from scratch by Andy Payor. He used unique materials and construction techniques for the walls, floor, and ceiling, the likes of which we've never seen before. The attention to detail in this room is...Read More
    Listening Impressions at Rockport Technologies
    We did more listening at Rockport Technologies than at any other company we've toured before, which was partly due to the quality of Rockport's fabulous listening room, but mostly to do with Andy Payor wanting to show off his speakers in the way they matter the most to him -- playing music. We listened to two speaker systems: the Aviors (in photo above), a four-driver, three-way design with all drivers front mounted that retails for $29,500 per pair . . . . ....Read More
  3. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
  4. #2763
    引用 作者: 將軍 查看文章
    我和何兄都算是很願意公開的人,但難免還是有遺漏之處,就請多包涵.
    其實這類資訊在國內外的專業音響雜誌多少都一定有討論到,只是零零散散是要花些精神和時間去消化並理解!!
    另外,有些不可改變的法則是必須一定要做的.
    例如:喇叭的背牆若是落地窗,那即使多會調教VTA或針壓等秘技,聲音說會好聽也是自欺欺人.
    空間,除了造型,用料不能造成共振也更是重要,有玻璃之類的窗戶或落地窗,在音響室原本就不應該存在的.
    如果情況許可,既是專用音響室,建議amy.adon兄不妨考慮將1/5窗戶封板,改採空氣交換機.
    "音響論壇"這本音響雜誌談論過很多相關的文章,只是很多人認為是商業文章不肖罷了!!
    其實有些商業文章還是有其可取之處,建議不妨上網搜詢,一定有收穫.
    將軍兄,落地窗一樣是可以存在的,但要作一些處理,前一陣子剛過世學者馬大猷,他發表的微穿孔板理論
    就可以應用在落地窗上,德國國會的為了讓民眾參觀並觀看國會議員開會的狀況,就使用玻璃作為建材,
    結果反射造成回音,最後用的就是微穿孔板解決這部份的問題!
    很多車上的排氣管也是利用他的理論降低排氣的聲浪,而不用再像以前一樣用吸音綿吸音。
  5. The Following User Says Thank You to carsound For This Useful Post:
  6. #2764
    引用 作者: carsound 查看文章
    感謝告知.
    只是,對我個人來說,就算能用其他方式解決落地窗的問題,我個人仍只會採取封板.
    原因只是單純的喜歡對稱+密閉式的空間!!
    我個人不喜歡音響室有透光!!
  7. The Following 2 Users Say Thank You to 將軍 For This Useful Post:
  8. #2765
    Native playback of DSD format has become possible with firmware update 2.5.
  10. #2766
    TechDas Air Force One Turntable
    Price from €64000
    Optional HRS base
    Everything is air here - air-vacuum, air-bearing and air legs.
    And it has a belt tension adjuster.
    Buttons on the right side - Stop, Speeds 33 1/3 + 45, Bright and Suction.
    TechDas has no sound of its own.
  11. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  12. #2767
  13. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  14. #2768
    小葉似乎是在暗示+提醒我甚麼!!
  15. The Following 2 Users Say Thank You to 將軍 For This Useful Post:
  16. #2769
  17. The Following User Says Thank You to chsiang For This Useful Post:
  18. #2770
    不要再玩GTR 了~~~
    吼...你也知道我還在玩!!
    還要玩一陣子啦!!
    因為空力套件+動力輸出都還沒完整!!
  19. The Following 4 Users Say Thank You to 將軍 For This Useful Post:
