第33頁,共69頁 第一第一 ... 23313233343543 ... 最後最後
顯示結果從 321 到 330 共計 681 條
  1. #321
    run-in CD run 過一遍的CD系統和新線材組合
    讓我昨天買了不少發燒CD片
    Dorian不錯
    老虎魚更是棒
    很活的聲音!!
    音響就是要用來聽好聽的音樂
    有好音響可以聽
    可以不受限制日夜的聽(假日)
    感謝家人和鄰居的包容
    真是幸福!!
  2. #322
    沒有圖.....:^):^):^)
    引用 作者: lyyoung 查看文章
    但附近的飲料攤辣妹頗有看頭
  3. #323
    沒有圖.....:^):^):^)
    留點想像空間...
  4. #324
    昨天到新竹找葉教授聽音樂
    重點當然是我沒聽過的 Roksan DARIUS
    葉教授的Darius擺在實驗室中一張桌子的兩側
    用CEC5100和Sonus Faber quid
    就發出了極為平衡悅耳的好聲
    什麼音樂都好聽
    是Roksan最大的特色
    沒太強烈的染色
    適度的精準
    適度的韻味
    足夠的低頻
    適合不只是聽古典的重度雜食性樂迷!!:):)超值中的超值!
    The Darius loudspeaker
    The Darius loudspeaker was designed alongside the original Xerxes in early 1985. As with the Xerxes, the Darius was the first loudspeaker design which tackled the adverse effects of induced vibration between drive unit, cabinet, and stand/support.
    The Darius was the first loudspeaker with a sprung tweeter. This innovative design isolated the tweeter from unwanted vibrations in X, Y and Z directions. (Suspension frequency: X< 4Hz, Y<3Hz and Z<2.5 Hz).
    The Darius was the first loudspeaker to use a 10mm internal spike to fix the resonance of the bass driver magnet and it was the first loudspeaker to have an exoskeletal stand, specifically designed to support the Darius cabinet at the 8 apexes (the primary nodes of the cabinet) via 8 adjustable spikes to ensure direct coupling of the cabinet to ground with negligible movement. It used a setup arrangement rather like a microphone pair setup which when combined with the above design features resulted in a performance second to none.
    The Darius was soon becoming a reference for many, where dynamics, depth, absolutely stables pinpoint imaging and amazing bass response from such a small cabinet mesmerized the audiences around the world.
    20 years later today, the pioneering principals of this amazing loudspeaker are still being used and admired in some of the best designs around.
  5. #325
    继续没有圖.....
  6. #326
    忘了照實際照片
    補個網路照片
  7. #327
    擴大機電流是否夠大足以面對阻抗變化大的喇叭....
  8. #328
    葉教授使用Naim的前後級推JMR和EA1
    Quid推Darius
    因為Naim推Darius轉大聲聽搖滾會發高熱甚至當機
    Sonus Faber推Darius很OK
    甚至比我以前用quid推credo溫度還低!!
    推測Darius需要大電流控制....
  9. #329
    剛剛從台北回來
    謝謝小葉和廖兄
    謝謝小高和大嫂
    也謝謝Jimmy, 音逸黃老闆,38度C蔡小姐...讓我滿載而歸
    軟體頗有收穫
    聲音也因為新配件有正面提升
    特別介紹Taipei101小林新產品
    鍍白金加鐵氟龍屏蔽的端子保護套
    確實有效提高形體感和樂器人聲分離度
    非常有效提升音質!
  10. #330
