第249頁,共268頁 第一第一 ... 149199239247248249250251259 ... 最後最後
顯示結果從 2,481 到 2,490 共計 2677 條
  1. #2481
    窮人,今天入手60D, 600閃燈,副廠手把
    為什麼新閃燈貴這麼多
    到處旅遊別帶太貴重物品 負擔重,鏡頭好技術好才是重點
  2. #2482
    雖然住在小城市但野外活動方便,常看到專門照風景的[腳架+快門線]用Canon相機很多。
    這有一退休老人攝影團[照鳥、風景、~~]也是很多用Canon相機[色彩自然]。
    5DII沒有仔細資訊但沒有看到或聽到有不好或不良的反應!!!
  3. #2483
  4. #2484
    樓上的網友:您家的兩位小公子好可愛喔!
  5. The Following User Says Thank You to kevintran For This Useful Post:
    wu
  6. #2485
    Traditional camera bags, which utilizes Velcro to create removable and adjustable padded sections, sounds quite practical in theory but not that much in real use. That’s why we need some innovative ideas such as the user-configurable gear protection system. Designed by a Denver-based startup called TrekPak, the protective bag is velcro-free but instead uses U-shaped pins and exposed sidewalls as connection points. As a result, it can not only help the users to organize their items more freely and conveniently, but also compatible with almost any existing bags.
  8. #2486
    那家的產品啊!應該來團一下
    虛空有時盡 我願仍無窮
  9. #2487
    引用 作者: kib 查看文章
    那家的產品啊!應該來團一下
    http://article.dcview.com/newreadart...ype=0&id=10598
  10. #2488
    miss 訪客
    小弟最近想購入GF-3價格約12,000只含定焦鏡,
    對相機完全不懂所以想請教各位前輩有比這c/p值高價錢也不會差太多的嗎?
    預算約20,000~25,000!!
  11. #2489
    黃醫師那台隨身小雞雞優,型號我又忘了
  12. #2490
    miss 訪客
    謝謝小葉大!!
    有請黃醫師解惑了!!!
