第7頁,共26頁 第一第一 ... 5678917 ... 最後最後
顯示結果從 61 到 70 共計 259 條
  1. #61
  2. #62
    何大,
    請教一下,這是座位背牆的處理嗎? 可以問一下裡面是包吸音棉還是G+H?
  3. #63
    是側牆的處理,蔡醫師說吸音柱.
    實際使用上,我以為兩種均可,
    只是吸的頻段略不同.
  4. The Following 2 Users Say Thank You to hojuiyang111 For This Useful Post:
  5. #64
    兩喇叭間的距離,還有喇叭距側牆的距離有點近!
    跟我之前的空間和擺位有點像!!
  6. The Following User Says Thank You to dandy For This Useful Post:
  7. #65
  8. The Following User Says Thank You to chsiang For This Useful Post:
  9. #66
    any details report of Dent 兄? very good hi-end system!
  10. The Following User Says Thank You to Prince For This Useful Post:
  11. #67
    Dent 兄生活規劃有了大變動,
    但發燒,卻是一點都沒改變,
  12. The Following 5 Users Say Thank You to hojuiyang111 For This Useful Post:
  13. #68
    Thank you!
  14. #69
  15. The Following User Says Thank You to hojuiyang111 For This Useful Post:
  16. #70
    twc 兄的系統
    風趣可親的 twc 兄
  17. The Following 5 Users Say Thank You to hojuiyang111 For This Useful Post:
