第18頁,共52頁 第一第一 ... 8161718192028 ... 最後最後
顯示結果從 171 到 180 共計 516 條
  1. #171
    意大利Rosso Fiorentino揚聲器, 書架形号Fiesole
    分音器
    座地形號Volterra
    旗艦座地形號Sienna
    設計師/創立人Francesco Rubenni
    意大利佛羅倫斯製造
    http://www.rossofiorentino.com/en/home.asp
  2. The Following 3 Users Say Thank You to alhw845 For This Useful Post:
  3. #172
  4. #173
    Apetura
    April 2012 - Apertura Enigma - The French company unveils its new flagship model, the 2-way 3-driver Enigma floorstander. "Two 2-inch Isotactic matrix drivers are loaded into a hybrid bass-reflex/TL enclosure. A massive 5-inch professional ribbon tweeter handles frequencies above 2kHz. The crossover is based on a 'DRIM' structure designed by well-known acoustic engineer Christian Yvon. Enigma combines a stylish design with multi-layer high density molded panels, ten internal braces, a heavy metal plinth and specific internal treatment for standing wave cancellation. Available are four high gloss real wood veneers of cherry, piano black, rosewood and figured maple.
    Dimensions are 40.4 x 134.6 x 44.6cm and weight is 76kg."
    法國品牌,Enigma為最新發表的旗艦機種-2音路3單體的落地式喇叭~兩個2吋的Isotactic matrix單體安裝在複合式低音反設/TL箱體。另外還有一個大型5寸專業絲帶高音單體處理高於2KHz的頻率。 而分音器則是由知名音學工程師Christian Yvon根據「DRIM」結構設計。另外還有許多優秀的特色,大家可以研究研究唷~~
    http://www.apertura-audio.com/index.html
  5. The Following 2 Users Say Thank You to cica zhou For This Useful Post:
  6. #174
  7. The Following 2 Users Say Thank You to chsiang For This Useful Post:
  8. #175
  10. #176
    彤彤很專業的翻譯
    幫小葉做事根本大材小用
    有很多是問小葉哥哥的啦!!
  11. The Following User Says Thank You to cica zhou For This Useful Post:
  12. #177
    彤彤很厲害喔!
    不過,原來的新文稿可能有誤 “Two 2-inch Isotactic matrix drivers are loaded into a hybrid bass-reflex/TL enclosure”?低音只有2-inch,不會吧?
    在這個網站http://canadahifi.com/index.php/aper...a-loudspeaker/,他們說是“using two 8″ isotactic matrix drivers loaded in a hybrid bass-reflex/line acoustic enclosure”。後面這個看起來比較有可能。
  13. The Following User Says Thank You to kevintran For This Useful Post:
  14. #178
    做人方面不懂的話,我可以深入的教.......
  15. #179
    彤彤很厲害喔!
    喔!! 謝謝你唷!!
  16. #180
    完全的比小葉還有用.....站長可以去QK了....
  17. The Following 2 Users Say Thank You to 小余 For This Useful Post:
