第80頁,共284頁 第一第一 ... 3070787980818290130180 ... 最後最後
顯示結果從 791 到 800 共計 2832 條
  1. #791
    引用 作者: DeadHeart 查看文章
    Fretboard顏色淺了些,個人淺見:)
    到時請我專家朋友鑑定下什麼木質,不過這把琴買時我自帶音箱和我自己的Gibson比較試音,這把琴音質音色特別好~柔美今天我來回開車110英里賣方開車270[432公里]英里,回到家在用好Amp Tone King試聲音非常好,特別再打電話給賣方 謝謝他開車長途送來,年輕小伙子人不錯為了要到鹽湖城讀書 賣琴做讀書費用。
  2. #792
    Is fingerboard
  3. The Following User Says Thank You to 999369 For This Useful Post:
  4. #793
    這是賣方提供的資料:
    This is a like new cherry red wine finished gibson les paul studio. I bought but haven't had time to sit down and play. It has very few nicks and scratches, that you don't even notice. Its practically brand new. I don't want to sell this beautiful guitar, but I am moving and need all the money I can get. Specifications are below. Text only please.
    Product Features
    Traditional Rounded Neck Profile
    BurstBucker Pro Pickups
    Traditional Mahogany Back and Maple Top
    22-Fret Rosewood Fingerboards
    Chambered Body for Perfect Tone Balance and Weight
    Gibson's Les Paul Studio offers traditional Les Paul performance with a modern, no-frills attitude. Introduced as a guitar mainly for studio musicians, the Les Paul Studio has become one of the most desired--and popular--Les Pauls for its tremendous harmonic and sonic qualities. All of the essential elements of a Les Paul Standard are there, including a carved maple top, solid mahogany back and genuine Gibson humbucker pickups. What the Les Paul Studio lacks in extras, it makes up for in performance. Ask any one of the thousands of musicians who call it their No. 1 axe.
    Traditional Les Paul Performance Meets Modern Tone and Playability
    Available Finishes
    Take your pick between four gorgeous finishes--Ebony, Wine Red, Classic White and Fireburst--all of which are applied by hand in a process that demands several coats and many hours. Unlike a lot of our competitors, who settle for a polyurethane finish, Gibson opts for a nitrocellulose finish that will encourage the natural vibration of the instrument for a purer tone. In addition, a nitro finish is very porous and actually gets thinner over time. That way your guitar's wood can breathe and age beautifully, like it's supposed to.
    Fast & Comfortable Rounded Neck Profile
    Gibson's traditional rounded neck profile, which graces the neck of each Les Paul Studio, is a thicker, rounder profile, emulating the neck shapes of the iconic Les Paul Standards of the late 1950s. Each neck is machined in Gibson's rough mill using wood shapers to make the initial cuts. But once the fingerboard gets glued on, the rest--including the final sanding--is done by hand. That means each neck ends up with ever-so-subtle differences that make each one as exceptional--and unique--as the next.
    A thicker, rounder neck profile emulates the neck shapes of the iconic Les Paul Standards of the late 1950s.
    Gibson pickups crank out modern tone with a vintage edge.
    Gibson's 490R and 498T Pickups
    The mid to late 1960s saw the emergence of a very different type of music coming from the clubs of England. This new genre's players were demanding more powerful amplifiers with increased volume outputs to satisfy their sonic explorations. This led to a call for a more versatile pickup, and Gibson answered the call with the 490T and 490R pickups ("T" for treble, and "R" for rhythm), humbuckers with the tonal characteristics of an original PAF, but with a slight increase in upper mid-range response. The Gibson 498T bridge pickup is the 490's ideal complement. Taking the 490 one step further, the 498 swaps the Alnico II magnet to an Alnico V, thus making it slightly hotter with emphasis on mid-ranges and highs. The pole pieces on the 498T are also aligned a little further apart to accommodate the spacing of the strings at the bridge, which is different than the spacing of the strings at the neck.
    There isn't anything more critical than the marriage of the Les Paul's mahogany back with a maple cap, as well as the regimen involved in selecting the right wood and the formula to dry it out. First, the wood is personally inspected and qualified by Gibson's team of skilled wood experts before it enters the Gibson factories. These onsite inspectors also ensure that the plain maple comes from corporations adhering to the forest-saving standards of the Rainforest Alliance, of which Gibson is a proud member and sponsor. Inside the Gibson factories, humidity is maintained at 45 percent, and the temperature at 70 degrees. This ensures all woods are dried to a level of "equilibrium," where the moisture content does not change during the manufacturing process. This guarantees tight-fitting joints and no expansion, and controls the shrinkage and warping of the woods, in addition to reducing the weight. It also improves the woods' machinability and finishing properties, and adherence to glue. Consistent moisture content means that a Gibson guitar will respond evenly to temperature and humidity changes long after it leaves the factory.
    Chambered Body
    There's something about playing a guitar with perfect tone, balance, and weight. One of the ways the expert craftsmen at Gibson USA achieve this equilibrium is by carving carefully mapped-out chambers in the Les Paul's solid mahogany back using a Computer Numeric Controlled (CNC) router before the maple top is glued on. The positioning of the routes was established after careful examination of the resonant characteristics of the Les Paul. Gibson approached this process with the awareness that every change to the formula would have repercussions on the instrument's sound. So, in addition to relieving the stress on a player's back and shoulder, these lighter Gibson guitars also enhance the tone palette in a manner unique only to these guitars. The results are comfortable, lightweight guitars that are acoustically louder, with increased sustain and resonance.
    Ebony or Rosewood Fingerboard
    The fingerboards on Gibson's Les Paul Studios are constructed from the highest grade rosewood and ebony on the planet. Both are personally inspected and qualified by Gibson's team of skilled wood experts before they enter the factories to be fitted onto the neck of the Les Paul Studio. The resilience of these dense and durable woods makes these fingerboards extremely balanced and stable, and gives each chord and note unparalleled clarity and bite. The 12-inch radius of the fingerboard provides smooth note bending capabilities and eliminates "dead" or "choked out" notes. The ebony fingerboard is only available on the Classic White Les Paul Studio, and the rosewood fingerboard is available on the Ebony, Wine Red, and Fireburst models.
    Enjoy Enhanced Tone With Gibson's Lightweight, Chambered Body
    The expert craftsmen at Gibson USA carve carefully mapped-out chambers in the Les Paul Studio's solid mahogany back using a Computer Numeric Controlled (CNC) router before the maple top is glued on. The positioning of the routes was established after careful examination of the resonant characteristics of the Les Paul. Gibson approached this process with the awareness that every change to the formula would have repercussions on the instrument's sound. So, in addition to relieving the stress on a player's back and shoulder, these lighter Gibson guitars also enhance the tone palette in a manner unique only to these guitars. The results are comfortable, lightweight guitars that are acoustically louder, with increased sustain and resonance.
    Tune-O-Matic Bridge
    The Tune-o-matic bridge was the brainchild of legendary Gibson president Ted McCarty in 1954. At the time, it was a true revelation in intonation, and set a standard for simplicity and functionality that has never been bettered. This pioneering piece of hardware provides a firm seating for the strings, allowing the player to adjust and fine-tune the intonation and string height in a matter of minutes. It also yields a great union between the strings and body, which results in excellent tone and sustain. It is combined with a separate "stopbar" tailpiece, essentially a modified version of the earlier wraparound bridge. To this day, the Tune-o-matic remains the industry standard. It is the epitome of form and function in electric guitar bridge design, and is one of the most revered and copied pieces of guitar hardware ever developed.
  5. #794
    今天上了油[手指板]曝光暗了些 色夠深了吧?昨天有些曝光過度
  6. #795
    Tune-O-Matic Bridge都拆下來了
    工程好大:O
  7. #796
    工程好大:O
    拿下來擦灰塵順便擦亮些,這支琴新約1100-1200[金色配件有透明烤漆外膜]另加盒子170 加稅大概100美元[明天去拉斯維加斯樂器行看看],賣方要价1000最後談到750美元但長途取回本錢該是800美元,本該說到700美元[現二手行情都低],想算了因為聲音非常好聽:)
  8. #797
    引用 作者: 999369 查看文章
    D兄 今天去看這個 PRS McCarty Goldtop 20th
    今天降到1800美元了~~~
  9. #798
    美國的吉他真的比較便宜
    而且量多質也夠8)
  10. #799
    Mesa Rect-O-Verb Combo Single Rectifier Guitar Amplifier
    Features:
    • Handbuilt in Petaluma, California
    • 50 Watts, Class A/B Power / 2x6L6, 5x12AX7
    • Bias Select Switch (6L6/EL34)
    • Fixed Bias for Consistent, Maintenance Free Performance
    • 2 Channels, 5 Modes (Channel 1=Clean or Pushed, Channel 2=Raw, Vintage High Gain or Modern High Gain)
    • Independent Gain, Treble, Mid, Bass, Presence, Reverb and Master Controls per Channel
    • Spring Reverb
    • Output Level Control (over all channels)
    • Footswitchable Solo Level Control - Patent 6,724,897
    • Parallel FX Loop w/Mix Control
    • Slave Out
    • 3 Button Footswitch (Channel, Solo & Reverb)
    • Slip Cover
    • Standard Finish: Black Taurus, Black Chassis and Polished Diamond Plate
    • 1x12 3/4-Back? Combo, C90 (Width 26-7/8 inches)
  11. #800
    拉斯維加斯~~~~~~~~
