第79頁,共293頁 第一第一 ... 2969777879808189129179 ... 最後最後
顯示結果從 781 到 790 共計 2930 條
  1. #781
    引用 作者: 999369 查看文章
    Gibson Les Paul Studio 2007年[加級金色配件]這支看得上嗎?中意話將來加一點~~讓給你
    或是PRS 這琴精工細緻[製]越看越好看:)[如能1600到手]對方是有錢人難殺價|-)
    感謝抬愛
    不過換琴日子良久
    我可能先增進手上功夫要緊
    而且有時候品牌商標不能代表琴的好壞:)
    現在如果有機會倒是想加一把Stratocaster就是
  2. #782
    引用 作者: DeadHeart 查看文章
    感謝抬愛
    不過換琴日子良久
    我可能先增進手上功夫要緊
    而且有時候品牌商標不能代表琴的好壞:)
    也行我目前有兩支:)
  3. #783
    引用 作者: 999369 查看文章
    也行我目前有兩支:)
    9兄真是客氣
    說到Fender,Made In Mexico的Road Worn series相當不錯,算是相對低價($30000~32000TWD)又能擁有好聲音的Fender;舊化的不只是外觀,連guitar tone都有老fender的樣子,小弟試過一把甚是喜歡:),音色不輸一些美廠的Deluxe:O
    不過話說回來,其實美廠和墨廠的區別並沒有想像中的高,小弟得知不少墨廠琴是先在美國的工廠先初步加工再至Mexico做最後組裝;也因此有時候會挑到不那麼好的MIA Fender,有時會碰到出乎意料之外的MIM Fender。Leo Fender當年能設計出這幾款相對低成本製作但又有出色優點的吉他,真是厲害(clap)
  4. #784
    9兄真是客氣
    MIU MIM 吉他上配件就不同 琴身內在木質也不同 如果是玩鄉村或爵士吉他本身音還是不同[好音箱好線材比較]
  5. #785
    9兄真是客氣
    Guitars: Does the Wood Really Matter?
    September 11, 2009 | Posted by Billy Penn
    I get alot of emails from players asking about the woods that guitars are made out of and if the wood really matters. The questions come moslty from players with solid body guitars so we will adress this question in regards to the solid body guitar.
    So…….on a solid body guitar does the wood really matter? One word, YES! The quality and type of wood definitely matters. Some players have a point saying that because the guitar’s body is solid then it really shouldn’t make that much of a difference. I can tell you from all of my experience building, repairing and restoring guitars that if you have bad wood you have a bad guitar. Period.
    Let’s take two extreme guitars for the sake of example. The first guitar is made of decent quality plywood and the second guitar is made of ash. Let’s also say that each guitar weighs in at about the same weight. Both guitars are both in fact made of wood but that’s where the similarity ends. How resonant do you think a piece of plywood really is? You guessed it, not very resonant at all because of all the thin wood layers and glue. So if the body wood is not resonant then what would you expect the sound to be like when it gets to your amp even if you have the best possible pickups in your guitar? On the other hand the guitar made from the piece of ash will be more resonant and have a more pleasing tone from the start before it even gets to your amp. See where we’re going with this??
    Different species of wood have a different impact on the overall tone of your guitar as well. In other words not all wood sounds the same. Ash has a nice bright, clear, “pop” sort of sound. Alder is not as bright as ash and has a bit of a pronounced midrange. Maple is bright with alot of clarity. Mahogany has a rich bottom pronounced midrange and smooth treble response. You get the picture. Also to note is that not every piece of alder will sound the same. I have built several Telecaster type guitars made from ash. Each and every one sounds different! What’s more is that each one is about the same weight, with a thin nitrocellulose lacquer finish and has a one piece maple neck. Go figure. Wood is an organic material and each piece is unique and has its individual properties.
    In this article we will not even delve into the debate over one-piece vs multi-piece bodies, old growth vs new growth wood, type of neck wood, neck construction, fingerboard wood and how a finish can affect the wood which can either enhance or dampen the guitar body’s resonance. (There is most definitely alot going on with guitar construction!)
    So in the end when building a solid body guitar or choosing to buy a solid body guitar the wood absolutely matters and can influence how a guitar sounds, feels and can help determine what type of music the guitar is best suited for. Don’t underestimate the effect of the type of wood for a solid body guitar!
    Resources: Musikraft Guitar Bodies & Necks.
    Read an interview with Musikraft’s Scott Smith here. This interview is packed with great content with many questions about guitar bodies and necks answered.
  6. The Following User Says Thank You to 999369 For This Useful Post:
  7. #786
    9兄真是客氣
    這少近一半价 可買到全新MIUSA附原裝手提箱 我紅色的那支全新二手還不到~~~
  8. #787
    引用 作者: 999369 查看文章
    台灣琴應該賣得比美國貴一些;(
  9. #788
    Gibson Les Paul Studio 早上出發取回剛到家順便拜訪了朋友 這琴4年很少彈弦都有些生銹了
  10. #789
    台灣琴應該賣得比美國貴一些;(
    熱門貨貴超過兩倍 在這買都儘力在殺價了 回台時一問价 哇!:O
  11. #790
    引用 作者: 999369 查看文章
    Fretboard顏色淺了些,個人淺見:)
