第77頁,共288頁 第一第一 ... 2767757677787987127177 ... 最後最後
顯示結果從 761 到 770 共計 2874 條
  1. #761
    引用 作者: DeadHeart 查看文章
    Brazilian Rosewood多用於Fretboard
    高階吉他廠如PRS甚至會做整隻琴頸皆為Brazilian Rosewood材質的款式:O
    不過前幾年Brazilian Rosewood因為過度開採急遽減少
    因此巴西官方下令禁伐
    有Brazilian Rosewood的琴價也水漲船高...
    據說聲音十分特別:)
    這有三种不同木質的琴頸約6-700美元一支
    鳥眼木心木材是我最喜愛的
  2. #762
    Super High Grade Flame Maple
  3. #763
    Warmoth耶,專門賣這些材料可以組裝,但是實際買這些材料去組裝好像不會比較便宜(sweat)
  4. #764
    貴因為是零售[而且好木料價不一樣],但是自己可買最好材質的裝配,如花2000多美金就可有非常好聲的高級電吉他,有朋友就是自己組裝今天還試了一支音質很好:)
  5. #765
    這支是新配件真仿老舊Fender早年吉他的,音質不錯今天是三把 Stratocaster在比較,才試出的較正確的答案 网上照片不是很清~
    A Custom built relic Nitrocellulose Stratocaster
    這標牌是仿的
  6. #766
    引用 作者: 999369 查看文章
    不過有時候拿一堆好料來組還不見得好聽
    某方面跟音響很像
  7. #767
    引用 作者: 999369 查看文章
    這標牌是仿的
    琴頭後可以再貼個V型的Custom Shop標誌:P:P
  8. #768
    不過有時候拿一堆好料來組還不見得好聽
    某方面跟音響很像
    玩[作] 不能瞎玩瞎搞 理念 技術 經驗,選材用料都會重視所需要方向目標[外形 音質],這次用了兩支Fender正廠的吉他做音質比較來確定的!
  9. #769
    不過有時候拿一堆好料來組還不見得好聽
    某方面跟音響很像
    像我自已愛瞎搞改這換換小東西[零件線材],但改完了都會請專玩樂器的朋友聽聽,是否音質音色還是保持原有的[如Fender]該有的聲音。
    改:琴更安靜 清晰[解晰更好] 頻響更好
  10. #770
    不過有時候拿一堆好料來組還不見得好聽
    某方面跟音響很像
    這是這位製造[組合]的老兄寫的介紹短文,裝完了還請專修吉他的作全部琴身調整[檢查]約140-150美元
    For Sale or Trade, A Custom built relic Nitrocellulose Stratocaster
    For Sale or Trade, A Custom built relic Nitrocellulose Stratocaster, this Strat is as good if not better than any Fender custom shop, the body is vintage specs done in Ice Blue Metallic by MJT Guitars, the neck is a B. Hefner Lic. by Fender which are some of the best necks made, 60s style finished in Nitro with proper dated Fender waterslide, the pickups are handwound vintage specs by Dawgtown pickups that sound amazing, the bridge is a big block steel vitage spec with Pat. Pending Fender stamped saddles which I got from Germany and they were not cheap. I have put alot of time and money into this guitar and I would put it up against any Strat out there, I just have to many Strats at the moment and am always looking for somthing different, so if you ever wanted a custom shop Fender but did not want to pay 3 to 5 grand then hear ya go, will consider trades for other guitars or amps, let me know what ya got? Thanks.
    我是不懂這些零件用料
