第14頁,共52頁 第一第一 ... 4121314151624 ... 最後最後
顯示結果從 131 到 140 共計 516 條
  1. #131
  2. #132
    預設 Tekton Design Speakers
    http://www.tektondesign.com/
    小公司!!!!!
  3. #133
    預設 10 MHz Rubidium Atomic Audio Clock
    Stanford Research Systems, Inc 10 MHz Rubidium Atomic Audio Clock
    http://www.thinksrs.com/products/PERF10.htm
  4. #134
    http://www.pureaudio.co.nz/
    Pure Reference Class A Power Amplifier
    Pure Control Preamplifier
    Pure Vinyl Phono Preamplifier
  6. #135
    外型設計的真好,像建築物, 唯一缺點就是露出的螺絲有點LOW, 聲音不知道聽起來怎樣, 應該也賣很貴吧:^)
  7. #136
    Analog Domain
    這家德國做擴大機的前兩年就在慕尼黑音響展上引起我的注意,東西相當雄狀威武,也很精緻,不過主事者好像有點怪怪地,不太容易溝通,我想這也是這家公司沒有很多代理商的原因吧(HK有引進,不曉得怎麼搞定的),希望有人可以把他們搞定,大家可上他們的網站看看嘍~~~
    http://analogdomain.eu/
    Prices
    Calysto from €72000 pr
    Artemis from €90000 pr
  8. #137
    DalbyAudioDesign
    來自英國的管機,很貴很漂亮~~~~
    http://www.dalbyaudiodesign.co.uk
    DalbyAudioDesign D7 Ultimate Line Preamplifier
    Price is £52000 including isolating Capacitor Bank.
    Product Dna
    X4 12B4A ultra linear signal valves
    Specially designed KYOKU transformers
    GZ37 or EZ81 valve rectification
    Solid silver RCA inputs x3
    Silver litz and mineral loaded pure silver wiring
    2m mineral loaded (80 strand) pure silver umbilical cord
    Shinkoh resistors
    Duelund output capacitors
    Copper screening and silicone dampening to power supply capacitors
    Tri-composite chassis system:
    9 carat gold over solid brass exterior
    31mm solid Mahogany support frame
    Copper internal screening platforms
    Carbon fibre-ceramic isolation feet
    External Isolation capacitor bank
    with 2 additonal preamp outputs (silver wired)
    Configurations:
    D7-L Preamplifier
    Ultimate dual chassis Line stage preamplifier with external PSU.
    Valve compliment: OC3A x4, 12B4A x4, EZ81/GZ37 x1
    D7-P Preamplifier
    Ultimate dual chassis Phono preamplifier (battery biased)
    with external PSU. Valve compliment: OC3A x4,
    6SN7GT x1, 12B4A x4, EZ81/GZ37 x1
    D7-LP Preamplifier
    Ultimate dual chassis Line / Phono integrated preamplifier
    (battery biased phono stage) with external PSU.
    Valve compliment: OC3A x4, 12B4A x4, 6GK5 x2,
    417A x2, EZ81/GZ37 x1
    Exclusively handmade in England.
  9. #138
    ARACRAFT Tedius AL100ND
    曾在JBL與Sansui的設計師所設計的
    新ブランド「アラクラフト」のデビュー作
    金属製エンクロージュアによる2ウェイコンパクトスピーカー
    型番 Tedius AL100ND 価格 184,800円(税込) 送料 無料
    金属製エンクロージュアと振動板を持つコンパクト・スピーカーの新鋭
     日本の新進ブランド、アラクラフト(ARACRAFT)がデビュー作となる小型スピーカー・システム「Tedius AL100ND」を発表した。ブラック・ヘアライン仕上げが施されたアルミニウム製エンクロージュアをまとう本機からは、精悍な印象を受けると同時に上質な道具が持つ品位を感じることができる。
     このTedius AL100NDは、日本のオーディオ界において辣腕をふるった熟練クラフトマンによって設計されたスピーカーだ。つまり、第一線で知り得たノウハウを自らのブランドのためにコンパクトにまとめ上げた作品、といってもよい。
    細部まで入念な設計がされ適材適所に厳選パーツを投入
     エンクロージュアは、フロントとリアバッフル、ロの字型に押し出し一体成型された上下左右バッフルからなる3ピース構造となっている。
    アルミ材の厚さは12mmとなっている。だから、手にとってみると、高さ20cm弱、横幅15cmに満たないサイズに比してずっしりと重い。
    ユニットは、11.5cmの逆ドーム型ウーファーと、フロントバッフルを切削して作ったショート・ホーンに1.9cmコンプレッション・ドライバーを組合せたトゥイーターを搭載。バスレフポートはリア側に設けられている。
    ウーファー、トゥイーターともに振動板をアルミ・マグネシウム合金製とすることで音色の統一が図られている上、両者とも磁気回路にネオジムマグネットを搭載している。クロスオーバー周波数は5.5kHz。
     また、先述したエンクロージュアのロの字部分の内側には、意図的に高低差3mm程度のゆるやかな起伏がつけられている。この工夫により内部定在波の発生を抑えるとともに、十分な強度を確保することができたということだ。
    サイズを超えたサウンド・スケープが広がる
     季刊ステレオサウンド178号 に掲載された本機の試聴記において和田博巳氏は、サウンドキャラクターについては『陽性の明快な音』、音楽の表現力については『ピンポイントの定位やS/Nの高さ、広大な音場感はもちろんこのスピーカーの得意とするところ』と、記している。
     多少オーバー・スペックであっても高品位なアンプをあてがうことで、このサイズのスピーカーが描出したとは思えないほどのサウンド・スケープが、眼前に広がることだろう。
     小型スピーカー愛好者はもちろん、これから本格的なオーディオを始めたいという方にもおすすめできる逸品だといえる。コストパフォーマンスの高さも魅力的だ。
    http://www.stereosound.co.jp/selection/item/034/
  10. #139
  11. #140
    Analog Domain amplifiers with Tidal Contriva Diacera in HK
