第175頁,共355頁 第一第一 ... 75125165173174175176177185225275 ... 最後最後
顯示結果從 1,741 到 1,750 共計 3546 條
  1. #1741
    Stage III Concepts A.S.P. Reference Minotaur power cable
    Fred Crowder
    Specifications:
    6 palladium/silver alloy AeroStrand Ultra™ conductors (2.5mm x 0.55mm) for each polarity in a tubular helix geometry with alternating positive and negative conductors.
    Air dielectric with FEP Teflon air tubes. 100% radiation invulnerable shielding uses exclusive H.D.A. (High Density Alloy) foil, plus silver plated copper braid, with individually protected ground.
    Multi-layer construction with silica/ceramic/ferrite mechanical damping layer. Custom handmade polymer-filled, carbon fiber plug housings help eliminate external vibrations. Exclusive Hyperion Ceramic plugs with Silver/Copper alloy electrical contacts, Palladium plated and Cryo-treated (custom made by Stage III Concepts).
    Inevitably, the choices made by a cable designer, conductor type, dielectric, spacing, geometry and shielding, and how these are balanced, determine the electrical properties and thus the cable's sound. Stage III Concepts has been designing and meticulously hand crafting audio cables since 1996. My initial experience with their cabling was the purchase of one of their "Heighliner" power cords about ten years ago. At the time it represented the top of their AC product line. Its massive conductor array and extremely low resistance made it a natural partner for high powered transistor amplifiers, while its ability to lower the noise floor and deal with EMI and RFI made it an excellent choice for source components. During the intervening period, Stage III further refined their technology. The result of that effort was first the A.S.P. Reference Zyklop power cable and more recently the A.S.P. Reference Minotaur power cable. The Minotaur was designed at the request of customers who wanted the excellent sound of the Zyklop in a more compact, flexible cable at a lower price.
  2. The Following 2 Users Say Thank You to 999369 For This Useful Post:
  3. #1742
    這算是預言將軍大也要''抱賽桶''了嗎?? (請用台語)
    引用 作者: 將軍 查看文章
    同樣的,
    在我家要讓我驚豔的,也似乎越來越少了...(sweat)
    似乎,必須再搞個更大的空間才能滿足我....:o
  4. #1743
    將軍大 跟 Andy兄 可謂不同世代的代表人物之一
    你們這種玩法太恐怖了拉!!8):P
    (好羨慕喔~~~:):P)
  5. The Following 2 Users Say Thank You to chsiang For This Useful Post:
  6. #1744
    說真的,
    夠大的專屬空間及空間處理其實比器材貴多了
    將軍瀟灑氣魄
    無不激起我努力賺錢的鬥志
    大丈夫亦若是!:):):)
    引用 作者: 將軍 查看文章
    說到"達文西密碼"的電影原聲這張CD,是我今天第一次在MUSK的店裡聽到.
    說來好笑,MUSK第一次放時,我還請人家換掉;
    MUSK請我聽第二次時,口吻中帶有"耐心"的意味存在.
    我聽著聽著,還差點睡著,不過當低頻出來時,我發現這張的CD有料哦!!
    到了Andy家,又放這張CD,低頻共振在Andy家有稍微出現,不過至少證明這張CD絕對有料!!
    跑了老闆娘的店和佳佳唱片都說缺片中,無法度只好和Andy情商先借回試聽.
    這張CD在第12軌的3分20秒開始,會有極低的低頻出現,不但有量感,還能測驗你的音響空間是否會產生那個頻段(不知)的共振.
    所以,不要以為低音量夠大是一定正確,先解決該有的頻段又不會共振才是首要;
    聽音響,又不是在拚誰大聲就是第一名,要大聲,卡拉OK最大聲啦!!
    試問,整個空間"嘎嘎"又"轟轟"作響,低音只會塞滿整個空間卻毫無層次,那又到底算是在聽些甚麼??
    對我而言,這就真的只是用錢堆出來的系統,而且只是個笑話罷了!!
  7. The Following 2 Users Say Thank You to chanc95 For This Useful Post:
  8. #1745
    我還好啦! 我現在只是做該做的,要出關了,之前都在閉關瞎玩,現在也只是一舉做到早該做的事,不玩了,也算對得起小高這對喇叭了,什麼聲音都出過,好的爛的,在現在腦裡已經對音響搭配完全沒有迷思了。
    你們這種玩法太恐怖了拉!!8):P
    (好羨慕喔~~~:):P)
  9. #1746
    超期待的線材心得終於出爐了~~感謝將軍大哥的分享囉~~:)
    越來越期待線材到港了:P
    唯有質近,方得共鳴
  10. The Following User Says Thank You to heartsnow For This Useful Post:
  11. #1747
    到台灣港啦...哈....應該會很爽!
  12. #1748
    到了就會到了......
    唯有質近,方得共鳴
  13. The Following User Says Thank You to heartsnow For This Useful Post:
  14. #1749
    引用 作者: heartsnow 查看文章
    到了就會到了......
    記得PO個心得文吧~~
  15. #1750
    沒禮貌.....我寫得有比較差嗎,照片也比較屌
