第29頁,共83頁 第一第一 ... 1927282930313979 ... 最後最後
顯示結果從 281 到 290 共計 823 條
  1. #281
    TAS榜單常客美國Sander喇叭,可惜兩次都沒遇到展房有開
  2. #282
    EARO這家紅色大對Eight的使用一顆8" lowther單體的樣子,利用箱體設計發出很多的低頻,加上全音域,還蠻好聽的,旁邊白色小對的Thwulf是一顆5"非lowther單體,價格分別為USD 3800與2800
  3. #283
    KinSound Emoperor II
    真的是屏風喇叭了,每邊有三片屏風
  4. #284
    Jadis的喇叭,小對的是WR10,使用一顆4"的單體,外面那對則是prototype
  5. #285
    DSPeaker這家產品概念很酷,只要將麥克風接上喇叭就可自動調整房間聲音的EQ
  6. #286
    Krell的新產品
    Evolution 2250e and the Evolution 3250e to the e Series of power amplifiers.
    Evolution 2250e - $8,000
    Evolution 3250e - $10,000
    Blessed with a power supply outfitted with a 2,500 VA power transformer and 136,000 µF of capacitance, the Evolution 2250e is a powerhouse. Power output of 250 W per channel into 8 ohms and 500 W per channel into 4 ohms will drive any loudspeaker to its full dynamic capability. The Evolution 3250e design uses the same power transformer but with additional capacitance, 163,200 µF total, insuring full performance when all three channels are being called upon simultaneously. An additional transformer for control and protection circuitry also provides power for a new energy efficient standby mode. Similar to turning off a 150W light that is always on in your house; standby power draw is only 2W. This 99% reduction in electrical usage also reduces heat output substantially. The high-current and high-voltage analog supplies have additional noise filtration circuitry to reduce high-frequency switching noise. ''
    [img]http://www.my-hiend.com/leoyeh/2011a/IMG_4140e.jpg[/img
    Phantom Preamplifier - $17,500
    Phantom Crossover Option - $2,500
    右邊那台
  7. #287
    這對estelon Model XA搭配Burmester聲音相當好,在這次CES上也出了風頭,USD 43,900,使用11" Accuton陶磁低音及7"與1.2" Accuton陶磁中音與高音,內部用Kubala-Sosna配線,效率85dB,一支重85kg
  8. #288
    不錯
    魔鐘進化版, 魔杯, 魔碗, 魔鈸, 魔鑼....8)
    這個來調音才屌,PMR (Passive Multi-Vocal Resonator)有共大一個,USD 2,150,我猜效果絕對明顯
  9. #289
    Jeff Rowland前面有提到發表了Aeris DAC (USD 9800),USB可到24/96,toslink與spdif可到24/192,有XLR與RCA輸出,另外還有發表Corus前級(USD 12,800)與Model 625後級(USD 13,500),300W輸出(8 Ohms)
  10. #290
