第11頁,共30頁 第一第一 ... 91011121321 ... 最後最後
顯示結果從 101 到 110 共計 300 條
  1. #101
    非常好的想法,感謝呀
    (1) 麥克風到麥克風放大前級的線要短 => 相對的是pre會離錄音點近,受到影響,這點我再想看看
    (2) MR-1000有耳機可直接輸出聽,每個人都會準備自己習慣的耳機,我是HD800,另外耳擴的部份我再想看看
  2. #102
    麥克風到麥克風放大前級的線 還有一個問題,就是麥克風擺位問題
    要短也很難耶......
  3. #103
    請問需要先發動捐款活動來支持一下嗎?看來光前期的花費就要幾萬了,還不包含中、後半段的花費,光靠小葉太吃力了吧
  4. #104
    我怕錄出來不好,要收大家的錢真是過意不去呀............
    但是不找財源,又太傷了.....
    我再來想想好方法呀....
  5. #105
    耳擴或許可考慮SPL Phonitor這種比較監聽背景的...
  6. #106
  7. #107
    要短也很難耶......
    如果不擔心被人踢到(很難,我知道),麥克風前級就放在舞台上!
  8. #108
    當天人員應該不是太多,有機會這樣控制吧
  9. #109
    不開放,人很少,頂多是加幾個會員....
  10. #110
    要短也很難耶......
    Ai......
    I've really see enought, what you're missing is a producer
    A producer is not just a recording engineer, but a budgeting, musician/tech/marketing all in one
    e.g if you hv to use short cable simply put the mic-pre close to the mic-stand.There's many micpre with remote, special for this purpose.Then link the output to BEST protools HD.Since aft mic pre the signal boost enought even travel 100M will be OK.Or if you really fussy , can use 5M audiophile silver cable to link between mic-pre and protool A/D
    For headset/headphones the best recording never use HS.Like Snow rose there is no HS. I can't tell how easy this is, but like Timbre of Sax recording in Sanfrancisco, Unplug Golden gate recording in a Italian rest in SF.all without HS.Of course then you need a pro-mixer and pro-mic handler.
    Well,do you think Y.K Chan Editor of Audiophile Editor states Unplug Golden Gate sounds better than Jazz at the pawn shop is water-blowing!!
    You hv to listen on his Westlake tower to be his level.
    But if you insist on HS monitoring, then use in ear, never use big hs, and musician hate cable, so better no cable use wireless, bluwtooth...
