第65頁,共79頁 第一第一 ... 1555636465666775 ... 最後最後
顯示結果從 641 到 650 共計 790 條
  1. #641
    會有兩個方案
    O4HD升級 or O6HD預購......
  3. #642
  5. #643
  6. #644
    Fully balanced differential Digital Analog Converter (DAC)
    • Two TI 192khz/24-bit Burr- Brown PCM1792 running in mono mode
    • Ultra-low jitter master clock (10 picoseconds after re-clocking)
    • TI SRC4194 Asynchronous Sample Rate Converter (Up-sampling to 24-bit/384 kHz)
    • Ultra-fast op amps (< 20V/us slew-rate)
    • Analog filter: 2nd-order Bessel reconstruction filter
    State-of-the-art technology platform &
    high-speed processor
    • Flawless encoding and decoding of
      lossless audio format
    • Fast management and access to
      extensive music libraries
    • Supports simultaneous streaming of high
      quality audio to multiple rooms
    Hard Drive
    • Ultra-quiet 2TB AV hard drive
    • Holds almost 20,000 HD tracks or
      6,000 CDs in original quality
    • Cushioned in 8 layers of noise cancelling
      padding
    CDRW
    • High fidelity TEAC CDRW mechanism
    • Import: Audio CDs
    • Burn: Audio CDs, MP3 CDs, Data CDs
    High-end Headphone Output
    • Powered by...
    • Dedicated TI 192khz/24-bit Burr- Brown PCM1792
    • TI's top-of the line TPA6120A2 High Performance Audio Amplifier (current-feedback architecture)
    Audio Connectors
    • Analog Output:
      - 1x XLR (balanced), made by Neutrik
      - 1x RCA, (24k gold-plated)
      - 1x Headphone, stereo, 6.4 mm
    • Digital Output:
      - 1x AES/EBU (balanced), made by Neutrik
      - 1x S/P DIF optical Toslink,
      - 1x S/P DIF coaxial cinch, 24k gold-plated
    Supported Audio Formats
    • Bit rate: 16-bit, 20-bit, 24-bit
    • Sampling Frequency: 10kHz up to
      200kHz
    • WAV, FLAC, MP3 (128 and 320 kbit/s),
      AAC (128 kbit/s)
    Networking
    • Wireless, 802.11n (54 Mbit/s),
      Encryption:
      WEP, WPA, WPA2, 64- and 128-bit
    • 1x Wired Gigabit Ethernet
    Other Ports
    • 1 x HDMI (480p, 60Hz)
    • 1 x USB 1.1/2.0
    • Infrared Receiver Input
    Color touch-screen
    • 10.1'' wide-aspect ratio
    • High-resolution (800 x 480 pixels)
    • Glass-on-Glass touch-screen technology
    High-precision linear power supply
    • Separate supplies for analog and digital components
    • High-performance AC line filter
      (ultra-high noise attenuation at close to 80db)
    • Custom-built toroidal transformer
    • Large reservoir capacitors
    • Ultra-low noise linear regulators
      (two stages of regulation, dedicated linear regulator for the clock generator)
    • Passive cooling concept no fan
  7. #645
    請問06HD(或就04HD的使用經驗)
    是否能夠將預先擁有的.wav或flac上傳到他的硬碟呢??
  8. #646
    沒有預先這個事呀,除非是現有的用家,可以請代理對拷硬碟
    若是新用家,就透過網路把歌丟進去呀
  9. #647
    網兄 Armiba 曾分享過
    http://www.myav.com.tw/bbs/showthrea...23#post4515723
    小弟也曾經跟著做過
    缺點是 沒有 ALBUM 的圖片 得自行加入
    還有曲目的順序會變動 ....
    虛空有時盡 我願仍無窮
  10. The Following User Says Thank You to kib For This Useful Post:
  11. #648
    06HD 的外觀還真是不錯看 ~ 只是有點傾斜的上蓋設計 使用上會不會麻煩些一(如果不是擺在最上層的架上 平面桌上應該是沒問題) 端子真的是更齊全了 .. 連 XLR 都有了 WIFI 天線好像是兩根耶 .. 真是蠻令人心動的 不知聲音有沒有更HI-END 啊 ~ 應該來辦個試聽會啦 :P :*
    虛空有時盡 我願仍無窮
  12. #649
    到貨就辦辣妹巨乳發表會的啦.....
  13. #650
    到貨就辦辣妹巨乳發表會的啦.....
