第64頁,共79頁 第一第一 ... 1454626364656674 ... 最後最後
顯示結果從 631 到 640 共計 790 條
  1. #631
    好哇~
    可是要可以打趴新款的Linn Akurate和Amarra + Weiss
  2. #632
    哈誤會馬大意思啦...
    對對是想這樣用沒錯...但是要有AES/EBU啦
    引用 作者: Musk 查看文章
    Mega應該也是想這麼用吧~:P
  3. #633
    功能定位不一樣耶
    看來Mega大是陷入混戰了
    引用 作者: Mega 查看文章
    好哇~
  4. #634
    Olive有iMaestro很吸引人是真的
    因為iPhone用遠端桌面有一點麻煩:(
    想搭個有開發app的
  5. #635
    引用 作者: Mega 查看文章
    想搭個有開發app的
    我會買iphone4也是為了Olive 4HD, 要不還是比較習慣原來的手機...
    不過準備買ipad了...
  6. The Following User Says Thank You to Musk For This Useful Post:
  7. #636
    偶有一種想直接衝新款11吋MBA的衝動,哈哈哈
    但是這樣好像不能跑app就是了
  8. #637
    引用 作者: Mega 查看文章
    但是這樣好像不能跑app就是了
    會長 ~ 沒錯 不能跑 iPad 上的 iMaestro 觸控很頓 不知哪的問題 .. iOS 3.2 以下的 iphone 不支援 2.0 版的 iMaestro 歐 :|
    虛空有時盡 我願仍無窮
  9. The Following User Says Thank You to kib For This Useful Post:
  10. #638
    預設 O6HD FEATURE NO. 2
    FEATURE NO. 2
    Audiophile Sound Quality
    Designed for audiophiles, the O6HD delivers a warm, full-bodied, and spacious sound with an exceptionally realistic soundstage.
    - Signal to Noise ratio of 124 dB means that the sound comes from a truly black background, revealing all the nuances and subtleties
    - Upsampling to 384 khz/24-bit, offering incredible purity in high frequencies and low-level detail
    - Ultra low jitter master clock, with jitter of less than 10 picosends after reclocking. That translates into a sound picture of unequalled transparency and tonal accuracy
  11. #639
    FEATURE NO. 3
    Revolutionary Design.
    The O6HD features a completely re-designed form factor unlike any digital audio component you've ever seen. Among its unique characteristics:
    - A wide-aspect 10.1'' glass-on-glass high-resolution (800 x 480 pixels) touch screen, which fuses simplicity and useability in the user interface
    - A solid anodized fine-grade aluminum shell, which reduces vibrations, resonances and operational noise while retaining simplicity
    - A distinctive angled front for optimal access to buttons and screen, which allows easy viewing from a distance and subtly hides connectors
    - Custom built in the USA in limited quantities
  12. #640
    O6HD :P
    不知何時問世?
    到時候還會有團嗎?
