第24頁,共31頁 第一第一 ... 142223242526 ... 最後最後
顯示結果從 231 到 240 共計 302 條
主題: 音響兩三事
  1. #231
    Audioquest總裁表示在研發USB DAC 與 耳機中了........
    数々の高品位な映像/音声ケーブルを世に送り出してきた米AudioQuest(オーディオクエスト)社。26日、同社CEOのウィリアム・E・ロウ氏が来社し、自社ブランドのUSB-DACとイヤホンを開発中であることを明かした。
  3. #232
  4. #233
    The new KingRex UC192 is described as "a very high-quality computer audio transport interface for those wishing to stream high-resolution files to an existing DAC. The UC192 can transfer from PC or Mac at 16/44.1 or up to 32/192 through its S/PDIF & I-squared-S outputs. The UC192 runs isochronous with an adaptive clock generator to auto sync with the host. The master clock generator is a classy 1ppm TCXO unit with proprietary low-jitter drivers for Windows & Mac. Kernel streaming, Direct Sound, ASIO4ALL and WASAPI are all supported and run smoothly. The UC192 is housed in an oval cross-section aluminum case with black hairbrush polish. It measures 88 x 82 x 24mm."
  5. #234
    預設 Sovereign ultimate mono power amplifiers
    Ultimate mono power amplifiers from Germany
    Price €99000 pr
    Output power (3-phase driven)
    8/4/2/1 ohm - 1800/3000/5000/10000 watt
    WxDxH 30x38x155cm
    125kg each
  6. #235
  7. #236
    Oracle 推出新唱盤啦--Paris黑膠唱盤
    The Paris analog record player …
    Designing an analog record player is no simple task … re-designing the Paris after developping the 30th anniversary of the Delphi MK VI was an extremely challenging venture !
    The complexity of this exercise lies in the ability to integrate simplicity and accuracy.
    A record player is a mechanical device capable of delivering an outstanding performance level only “IF” each and every of its components and mechanisms interact as a system in total harmony. The Paris turntable has been designed with all the above clearly and very well understood !
    Although very different from the Delphi MK VI, the Paris meets in every aspects all the critical issues we had to address with the Delphi MK VI.
    o Ajustable feet made of Delrin
    o The main bearing system uses the same Peek material as for the Delphi
    o The semi floating suspension system uses Sorbothane
    o The platter is made of acrylic
    o The record clamp is made of Delrin and it is simply the best there is !
    The Paris has been very elegantly dressed in a low reasonnance medium density fiber to maximize the vibration rejection. The suspension system design has been developped to reproduce a similar result than the MK VI Micro Vibration Sabilizer System.
    The Paris is a very unique and high performance player that will deliver a truly outstanding act, a life like and totally involving analog music reproduction.
    http://www.oracle-audio.com/?action=...c_desc=1&lg=en
  8. #237
    不知道是不是新款的ODIN喇叭線
    每條由原來的6芯*4變成7芯*4
    最邊上的兩芯用黑色與紅色隔離絲區分正負極...
  9. #238
    又是匪區仿品.. :S
  10. #239
    DALIから、新コンセプトスピーカー「ME9」登場!!!
      2012年発売予定。
  11. #240
    尺寸似乎比台灣鐘大不少. . .
    引用 作者: DeadHeart 查看文章
    這不就是魔鐘嗎:^)
