補照片
Clearudio outer limit & locator
國外訂價USD 1250,和Clearaudio Ebony唱臂差不多。
Stereophile Recommended Component April 2003
 "...blackened  backgrounds, solidified images, and made them 'pop' in three  dimensions."
VPI periphery ring clamp
訂價約USD 600,好像是VPI盤專用
The                Periphery Ring Clamp greatly improves the performance of  VPI turntables                by flattening the outer edges of LPs, increasing the  cartridge’s                tracking ability, removing resonance and aiding detail  retrieval.                A massive ring designed to sit just outside the lead-in  groove,                the PeripheryRing Clamp's weight flattens the record onto  the platter,                eliminating edge warps and more completely coupling the  record to                the platter.
Universal  Record Stabilizing Ring
                    The                      Universal Record Stabilizing Ring:
Optimum                          Coupling of Record to Turntable Platter / Mat as  no other                          device can achieve
Lowers                          Noise Floor Significantly
Eliminates                          Resonances and Lowers Distortion and End-Of-Side  Distortion
Provides                          Pure Signal Retrieval
Gives                          Realistic Sound Reproduction
Improves                          Stereo Image and Focussing
Stabilizes                          Sound Image
Seperates                          Instruments and Groups of Instruments
Less                          Record Wear as a Lower Downforce is Possible
Will                          flatten most warped records
For                          Musiclover, Analog Fan and High-End Adept
Gives                          Improved Signal when Burning Quality CDs from  LPs
 Kenwood Outer Disk Stabilizer Ring
