第7頁,共21頁 第一第一 ... 5678917 ... 最後最後
顯示結果從 61 到 70 共計 204 條
  1. #61
    The original A5
    The small A5 managed to make itself a big name in both professional environments as well as in computer or desktop applications. A wealth of truly outstanding reviews and many awards helped to establish this speaker as one “of the best small monitors” and a “great choice for the small studio.” (Future Music, 01/2009).
    The new A5X
    The similar dimensions and name could make one believe that the A5X is nothing more than a new version of the A5. A quick listening however leaves no doubt that the A5X is much more than that.
  2. #62
    ARTist 5
    The similar dimensions and name could make one believe that the ARTist 5 is nothing more than a revamped version of the multiple awards winning A5. Comparing the sound of the A5 to the ARTist 5 however leaves no doubt that the ARTist 5 is much more than that.
    应该是A5后才延伸出这两个型号,以价格来说,他比较接近Artist5,A5X才几百块美金而已,A5近千了,Artist 5可能刚好破千,以前A5在网站是放在Home Audio下的
  3. #63
    應該是ADAM發現要專業家用一魚兩吃有困難,無論是價格或性能上,所以在A5之後做了這樣的決策...分開!
  4. #64
    以這網站查價
    http://www.vintageking.com
    ADAM A5 USD 699 (網站無,使用之前資訊)
    DYNAUDIO BM5A COMPACT USD 999
    FOCAL CMS 40 單支USD 395,1對就是790
    (A5X 單支USD 449,1對就是USD 898)
    價格:BM5A > CMS 40 > A5
  5. #65
    果然旧款的不值钱......
  6. #66
    以20Hz到20KHz完全一致為前提的EQ最適化建議値(測試環境影響計入後)。
    水平上方者為建議補正,下方的則是建議削減 。
    K&H O300D
    ADAM A5
    DYNAUDIO ACOUSTIC BM5A Compact
    FOCAL CMS 40
  7. The Following 2 Users Say Thank You to さおり For This Useful Post:
  8. #67
    今回各喇叭20Hz到20KHz的周波數特性(測試環境影響計入後)
    K&H O300D
    ADAM A5
    FOCAL CMS 40
  9. #68
    會不會換條訊號線或電源線, 這測出來的周波數特性又不一樣了?
  10. #69
    當然是會有改變
    基本上這是在大家用同一電源線、訊號線下測的 :O
    引用 作者: Musk 查看文章
  11. #70
