第20頁,共31頁 第一第一 ... 10181920212230 ... 最後最後
顯示結果從 191 到 200 共計 302 條
主題: 音響兩三事
  1. #191
    法老的棺木. . .:O
    The Signature Titan Speaker:
  2. #192
    ORBブランドの電源タップ「TP-4」「TP-4 Gold」を2月14日より発売する。価格はTP-4が26,040円(税込)、TP-4 Goldが31,290円(税込)。
    http://orb-audio.jp/
  3. #193
    SONY 支援3D的AV擴大機
    supporting 3-D audio and video
    HDMI™ 1.4 3D pass-through technology
    http://news.sel.sony.com/en/press_ro...ase/56527.html
    STR-DN1010 AV receiver will be available this June for about $500.
    The 7.1 channel STR-DN1010 AV receiver (110 watts power per channel @8-Ohms, 1kHz, 1% THD) features full high-definition 1080/24p support and seven HD inputs in total (four HDMI and three component) allowing for connection to a wide variety of HD devices. The receiver’s HDMI 3D pass through technology supports 3D video from connected devices and passes them through to a 3D compatible high-definition television, while decoding high-resolution audio codecs.
    The receiver also features an icon-driven menu system for simple device and content navigation and has the ability to upscale analog video sources to 1080p resolution via HDMI. The model also boasts a sleek piano black gloss design that matches Sony’s line of Blu-ray Disc players and televisions.
    The STR-DN1010 is compatible with all advanced audio codecs, including Dolby® TrueHD, dts®-HD Master Audio and features wireless 2nd zone capabilities through Sony’s S-AIR® wireless technology. With the addition of an S-AIR transmitter (model EZW-T100) and separate S-AIR speakers (sold separately), the receiver can also drive wireless audio in up to 10 additional rooms.
    The STR-DN1010 receiver also features a Digital Media Port (DMP) input for simple connection to external sources including an iPod® and iPhone® (compatible DMP accessories required and sold separately) and is compatible with both Deep Color™ and x.v.Color™.
    STR-DH810 AV Receiver
    Available in March for about $400
    • 7.1 channel (110 watts power per channel @8-Ohms, 1 kHz, 1% THD)
    • Seven HD connections (4 HDMI / 3 component)
    • Upscales incoming analog video signals to 1080p
    • 2nd Zone wireless audio (S-AIR ready)
    • Compatible with Dolby® TrueHD, dts®-HD Master Audio
    • Fully Assignable audio and video inputs
    • Audio Return Channel using just one cable for TV audio
    • Stand by pass-through of Audio & Video via HDMI connected devices
    • Universal Remote
    STR-DH710 AV Receiver
    Available in March for about $300
    • 7.1 channel (105 watts power per channel @8-Ohms, 1 kHz, 1% THD)
    • Six HD connections (3 HDMI / 3 component)
    • Fully assignable inputs allows for use of all connections
    STR-DH510 AV Receiver
    Available in March for about $230
    • 5.1 channel (100 watts power per channel @8-Ohms, 1 kHz, 1% THD)
    • Five HD connections (3 HDMI / 2 component)
    • HDMI™ Repeater for simplified audio and video signal management
    • Blu-ray Disc™ Audio Decoding (Linear PCM Only)
  4. #194
    Spendor ST Carbon
    Highlights of the Spendor stand will be its new ST Carbon speaker (£5,995) featuring a piano black finish with carbon fibre inlays, and the Spendor A9.
    The company will also show the S3/5R, the SA1 mini monitor and the new A5 and Award-winning A6 floorstanding loudspeakers.
  5. #195
  6. #196
    感覺像是 chord gem 吧 ? 但是沒有dac功能 ..
    虛空有時盡 我願仍無窮
  7. #197
    IsoTek Syncro
    The IsoTek Syncro goes on sale in April for £875.
  8. #198
  9. #199
  10. #200
