第19頁,共31頁 第一第一 ... 9171819202129 ... 最後最後
顯示結果從 181 到 190 共計 302 條
主題: 音響兩三事
  1. #181
  2. #182
    有異曲同工之妙耶~~~~
    Dartzeel NHB-458 Monoblock
  3. #183
    Unison Research phono stage「PHONO ONE」
    £1249.99
    Phono One was for many years one of the most appreciated models in the Unison Research catalogue. It has now been completely renewed and improved, although its look of elegant and timeless simplicity remains the same.
    An all-tube design with elastic suspension, it uses five ECC83 double triode valves in parallel configuration to give excellent low noise and distorsion characteristics. Cross-talk also is  extremely low at -90dB. Overall gain of the Phono One is 54dB, and switchable resistance and capacitance loading makes it suitable for all MM and most MC cartridges.The sound is pure, with supreme natural detail and great clarity. Truly a top class phono stage.
  4. #184
    Unison Research Malibran
    £19500.00
    Malibran is the first loudspeaker system designed by Opera and produced by Unison Research. It is named in homage to the great 19th Century soprano Maria Malibran, whose remarkable life and talent was cut short at the age of just 28. She is remembered today as a legend in Venice, where a Theatre is named after her.
    The Malibran loudspeaker incorporates all the important technical solutions and innovations developed by Opera in recent years, including the inward-firing sub-bass section, the progressive low-pass filter, the Cross-Linked Dipole rear tweeter array and the TEB (totally enclosed box) with sealed enclosures for each bass driver.
    The Malibran cabinet and is made up of an inner cabinet of multi-layer plywood and thick MDF, with an outer layer of finely sculpted and highly polished real wood. The overall volume is 146 litres and weight is 120kgs, the whole structure being virtually inert and resonance-free.
    Wheels are fitted for easy movement.
    Although there are 12 drive units in total, Malibran is in reality an extended two-way system, with powerful passive sub-woofer and cross-linked dipole radiating system all in the same cabinet. Its particular design makes it easy to use in any room, whether large or small.
    System: Floor-standing - TEB
    Finish: Cherry wood and leather
    Drive Units: 3 x sub-woofers, aluminium cone
    4 x 5-inch midrange, magnesium cone
    1 x 1-inch treble unit, silk dome
    CLD rear radiating system (4 tweeters)
    Frequency response: 20Hz - 20kHz
    Max. Long-term power: 750 Watts RMS
    Suggested amplifier: from 10-15 Watts (no clipping)
    Sensitivity: 89dB/w/m
    Nominal impedance: 4 Ohm (minimum 3.2 Ohm)
    Dimensions: 140 x 39 x 80
    Crated weight: 150kgs each
  5. #185
    dCS新的遙控器
    Euro 300
    dCS have begun production of a new premium remote handset for Paganini systems and Puccini player.
    The new remote handset is available in black only, is housed in a solid aluminium case and weighs in at 440g.
    It has most of the same features as the previous remote handset, but will also support upsamplers, thus it can be used to operate a 4 box Paganini or Scarlatti system.
    Although this means an increase in price to Puccini, something as necessary as the remote needs to be, and is now, of the same style and build quality as the player itself. It is also worth pointing out that new Puccini owners will now get a number of new features including; upsampling on the digital inputs (upon registering and loading a license key) and clocking for the digital inputs, all included in this new price.
    For existing Paganini and Puccini owners the remote is available to buy as a separate and comes in a special presentation box. The end user price is ca €300. These remotes will comefully tested and with standard three year warranty as per the dCS warranty policy.
  6. #186
    The Signature Titan Speaker:
      number #001: $2,000,000 for a pair
      number #002: $1,000,000 for a pair
      number #003: $500,000 for a pair
     ・ The MoonAudio TITAN is a state of the art audio transducer system designed to outperform
      any other speaker system currently made in the world today.
     ・ Unique to the audio world is that it will be a strictly limited edition run of only 3 pairs with
      each pair hand-signed by the designer. Each pair will also be named after its buyer and once
      the third pair is built – no more will be constructed.
     ・MoonAudio guarantee support for the Titan for 10 years from its purchase date.
     ・ Each unit is hand-crafted using the world’s best materials, parts and drivers and
      manufactured in the USA.
     ・ The pair of speakers will weigh over one ton due to their proprietary construction design
      engineered to remove virtually all vibration from the cabinet and system.
     ・ Auto-room tune calibration is built into the speaker so it can tune itself for the room.
     [Specifications]
      ・Frequency response: 15Hz-90kHz
      ・Impedance: 8ohms
      ・Efficiency: 96dB
      ・Bi-wire and Bi-amp
      ・Weight:1270kg(pair)
      ・Size: 183 cm x 47 cm x 81 cm (hxwxd).
  7. #187
    Weight:1270kg(pair)
    太驚人的體重了
  8. #188
    不錯
     [Specifications]
      ・Impedance: 8ohms
      ・Efficiency: 96dB
      ・Bi-wire and Bi-amp
    Super speaker ..........wow(music)(music)(music)(music)
  9. #189
  10. #190
